LM321
LM321
    PJ(平晶)
    SOT23-5
    低功耗单运算放大器 24V/±12V Vos=±2mV Vsr=0.4V/μs SOT-23-5
LM321 数据手册
LM321 Low Power Single Operational Amplifier Description SOT-23-5 LM321 is a low power, wide power range performance operational amplifier;The static current is only 430 μA per amplifier (5V) with high unit gain frequency and A voltage swing 4.OUT 5.V+ rate of 0.4V/μs.Input common model circuit includes ground, so the device can operate in single - and dual-power applications.It can also comfortably drive large capacity loads. Features ⚫ Low quiescent current ⚫ Low input bias current ⚫ Wide range of supply voltage ⚫ High capacity load stability 1.+IN 2.V- 3.-IN Application ⚫ Communication infrastructure ⚫ Battery charger ⚫ Power supply Pin arrangement diagram www.pingjingsemi.com Revision:1.0 Jul-2019 1/5 LM321 Low Power Single Operational Amplifier Absolute Maximum Ratings (TA =25℃) Parameter Symbol VCC Value 24 or ±12 Units V Differential Input Voltage VID 24 V Input Voltage VIN -0.3~VCC V Power Dissipation PD 530 mW IO Continuous IIN 50 mA TJ 150 °C Operating Temperature Range TOPR 0 to 70 °C Storage Temperature Range TSTG -65 to 150 °C Supply Voltage Output Short Circuit to GND Input Current VIN
LM321 价格&库存
很抱歉,暂时无法提供与“LM321”相匹配的价格&库存,您可以联系我们找货
