RC0805FR-07300KL
RC0805FR-07300KL
    YAGEO(国巨)
    贴片电阻 0805 300KΩ ±1% 1/8W ±100ppm/℃
RC0805FR-07300KL 数据手册
DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC_L series ±0.1%, ±0.5%, ±1%, ±5% Sizes 0075/0100/0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification – December 12, 2018 V.10 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SCOPE This specification describes RC series chip resistors with lead free terminations made by thick film process. RC_L SERIES 2 11 0075 to 2512 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RC XXXX X X X XX XXXX L APPLICATIONS  All general purpose application (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Halogen Free Epoxy  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes, resistors element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production (2) TOLERANCE B = ± 0.1% D = ± 0.5% F = ± 1.0% J = ± 5.0% (for jumper ordering, use code of J) (3) TAPING REEL & POWER R = Paper taping reel K = Embossed taping reel S = ESD safe reel (0075/0100 only) (4) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (5) TAPING REEL 07 = 7 inch dia. Reel 10=10 inch dia. Reel 13 =13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 7N = 7 inch dia. Reel, ESD safe reel (0075/0100 only) 3W = 13 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only.(Note) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩwith ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KL. NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Dec. 12, 2018 V.10 Product specification Chip Resistor Surface Mount RC_L SERIES 3 11 0075 to 2512 MARKING RC0075 / RC0100 / RC0201 / RC0402 No Marking Fig. 1 RC0603 0 1%, 0.5%,E24 exception values 10/11/13/15/20/75 of E24 series Fig. 2 240 = 24 × 100 = 24 88 1%, 0.5%, E96 refer to EIA-96 marking method, including values 10/11/13/15/20/75 of E24 series Fig. 3 88A = 806 × 100 = 806 Ω 03 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 4 Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC2010 / RC2512 00 1%, 0.5%, E24/E96 series : 4 digits First three digits for significant figure and 4th digit for numbe r of zeros Fig. 5 Value = 10 KΩ 03 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ RC1218 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 7 Value = 10 KΩ 00 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 8 Value = 10 KΩ For further marking information, please see special data sheet "Chip resistors marking". www.yageo.com Dec. 12, 2018 V.10 Product specification Chip Resistor Surface Mount SERIES RC_L 4 11 0075 to 2512 TAPING CODE & POWER Type Power, W (P70) Coding 07 0075 0100 0201 0402 0603 0805 1/50 1/32 1/20 1/16 1/10 1/8 7W 1/8 1/5 1/4 Type Power, W (P70) Coding 07 1206 1210 1218 2010 2512 1/4 1/2 1 3/4 1 CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Ni-barrier) are added, as shown in Fig.9. 7W 1/2 2 Outlines For dimensions, please refer to Table 1 9 Fig. 9 Chip resistor outlines DIMENSION Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RC0075 0.30±0.01 0.15±0.01 0.13±0.01 0.08±0.03 0.08±0.03 RC0100 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 RC0201 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 RC0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 RC0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 RC1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC1210 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC1218 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 www.yageo.com Dec. 12, 2018 V.10 Product specification Chip Resistor Surface Mount RC_L SERIES 5 11 0075 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS POWER OPERATING TEMPERATURER ANGE Fig. 4 Chip resistor outlines-55℃ to 125℃ RC0075 1/50 W MAXIMUM WORKING VOLTAGE 10V MAXIMUM DIELECTRIC OVERLOAD WITHSTANDING VOLTAGE VOLTAGE 25V 25V RESISTANCE RANGE TEMPERATURE COEFFICIENT JUMPER CRITERIA Rated Current 5% (E24) 10Ω≦R
RC0805FR-07300KL
物料型号:YAGEO Phicomp RC系列普通用途芯片电阻,包括不同的精度等级(±0.1%, ±0.5%, ±1%, ±5%)和尺寸(0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512)。
器件简介:RC系列芯片电阻采用无铅端子,通过厚膜工艺制造,符合RoHS标准,无卤素,减少环境有害废物。
引脚分配:文档中未明确指出引脚分配,但通常这类表面贴装电阻器有两端子用于连接。
参数特性:电阻的温度系数、最大工作电压、功率承受、额定电流等电气特性在文档中有详细说明。
功能详解:文档提供了电阻的详细规格,包括尺寸、公差、卷带类型、温度系数、电阻值等。
应用信息:适用于所有一般用途的应用场景。
RC0805FR-07300KL 价格&库存
很抱歉,暂时无法提供与“RC0805FR-07300KL”相匹配的价格&库存,您可以联系我们找货
RC0805FR-07300KL
  • 1+0.08811
  • 500+0.02937
  • 2500+0.01969
  • 5000+0.01606
库存:531
RC0805FR-07 300KL
  • 5000+0.041365000+0.00536
  • 15000+0.0405515000+0.00525
  • 25000+0.0340725000+0.00441
  • 50000+0.0275850000+0.00357
库存:1575000
RC0805FR-07300KL
  • 1+0.143481+0.01858
  • 10+0.0326810+0.00424
  • 25+0.0295025+0.00382
  • 100+0.02232100+0.00289
  • 250+0.00957250+0.00124
库存:294
RC0805FR-07300KL
  • 1042+0.074931042+0.00970
  • 5000+0.046245000+0.00599
  • 10000+0.0438410000+0.00568
  • 15000+0.0430515000+0.00558
  • 25000+0.0382625000+0.00496
  • 35000+0.0374735000+0.00485
  • 50000+0.0310950000+0.00403
库存:4600
RC0805FR-07300KL
  • 100+0.05416
  • 1300+0.05311
  • 2500+0.05207
库存:2300
RC0805FR-07300KL
  • 100+0.01182
  • 500+0.01122
  • 1000+0.01032
  • 5000+0.00912
  • 10000+0.00840
库存:2207
RC0805FR-07300KL
  • 5000+0.040665000+0.00527
  • 10000+0.0350810000+0.00454
  • 25000+0.0326825000+0.00424
  • 35000+0.0279035000+0.00362
  • 50000+0.0215350000+0.00279
库存:1575000
