Description
PJ4054B
Linear Lithium-ion Battery Charger
PJ4054B is a complete single lithium ion battery with constant current/constant voltage linear
charger. Its SOT package and small number of external components make the PJ4054B ideal for
portable applications.PJ4054B can be suitable for USB power and adapter power supply work.
Due to the internal PMOSFET architecture, plus the anti-inverted charging circuit, there is no
need for external detection resistor and isolation diode. Thermal feedback adjusts the charging
current to limit chip temperature at high power operation or ambient temperature conditions.The
charging voltage is fixed at 4.2V, and the charging current can be set externally through a resistor.
When the charging current reaches the final floating charging voltage and drops to the set value of
1/10,PJ4054B will automatically terminate the charging cycle.
When the input voltage (ac adapter or USB power supply) is removed, PJ4054B automatically
enters a low current state, reducing the battery leakage current below 1uA.PJ4054B can also be
placed in stop mode to reduce the power supply current to 25uA.Other features of the PJ4054B
include a charging current monitor, undervoltage latching, automatic recharging, and a status pin to
indicate the end of charging and input voltage access.
Features
500mA programmable charging current;
No MOSFET, test resistor or isolation diode required;
A complete linear charger with SOT-23-5 package for single lithium ion battery;
Constant current/voltage operation, with thermal regulation function;
Charge single lithium ion battery directly from USB port;
4.2V charging voltage is preset;
Output of charging current monitor for battery quantity detection;
1/10 Charge termination, automatic recharging;
Power supply current in standby mode is 25uA;
Soft boot limits the surge current;
2.9V trickle charge device version
Applications
Rprog resistance and charging current
Ibat corresponding table
Rprog
Ibat
Ibat=1000/Rprog
www.pingjingsemi.com
Revision:1.0
May-2019
10K
100mA
5K
200mA
3.3K
300mA
2.5K
400mA
2K
500mA
1.65K
600mA
1/6
PJ4054B
Pin Distribution
SOT-23-5
4.VCC
5.PROG
1.CHRG
2.GND
3.BAT
Pin Function
CHRG(Pin1)
Output of open drain charging state. The CHRG pin is pulled to low level by an
internal N-channel MOSFET during battery charging. When the charging cycle
ends, CHRG pin is off and all lights are off. When PJ4054B detects an under
voltage blocking condition, the CHRG pin is forced to a high impedance state.
GND(Pin2)
GND
BAT(Pin3)
Charging current output.The pin provides charging current to the battery and
adjusts the final floating charging voltage to 4.2V. A precise internal resistance
voltage divider of the pin sets the floating charging voltage. In the shutdown mode,
the internal resistance voltage divider is disconnected.
VCC(Pin4)
PROG(Pin5)
Revision:1.0
May-2019
Positive input power voltage.This pin supplies power to the charger.VCC shall vary
from 4.25V to 6.5V and shall be bypassed by at least one 1uF capacitor.When the
VCC drops to less than 30mV of BAT pin voltage,PJ4054B enters the stop mode,
and the Ibat falls below 2uA.
Charging current setting, charging current monitoring and stop pin.The charging
current can be set by connecting a 1% precision resistor Pprog between the pin
and the ground.When charging in constant current mode, the voltage of this pin is
maintained at 1V. In all modes, the voltage on this pin can be used to calculate the
charging current. The formula is Ibat=(Vprog/Rprog)*1000.Short connect the set
resistor to the ground, and an internal 2.5uA current pulls the PROG pin to a high
level.When the voltage of this pin reaches the stop threshold voltage of 1.21V, the
charger enters the stop mode, the charging stops and the input power current
drops to 25uA.Reconnecting the Rprog to the ground will restore the charger to
normal operation.
2/6
PJ4054B
Absolute Maximum Rating
Input Voltage
VSS-0.3V~VSS+7V
PROG
VSS-0.3V~VSS+0.3V
BAT
VSS-0.3V~VSS+7V
CHRG
VSS-0.3V~VSS+10V
BAT short-circuit period
Continue
BAT Pin Current
500mA
PROG Pin Current
800uA
-40℃~85℃
Operating Temperature Range
Storage Temperature
-65℃~125℃
Pin temperature (welding time: 10s)
260℃
Block Diagram
4
VCC
120℃
TA
TDIE
1X
1000X
BAT
5μA
MA
3
R1
VA
CA
SHDN
R2
C1
REF
1.21V
R3
1V
R4
1
0.1V
C2
CHRG
R5
STANDBY
3μA
C3
TO
BAT
2.9V
VCC
5
Revision:1.0
May-2019
GND
PROG
RPROG
2
3/6
PJ4054B
Electrical Characteristics
(TA =25℃ unless otherwise specified.)
Parameter
Symbol
Input Voltage
VCC
Input Current
ICC
Min.
Typ.
4.2
charging mode,Rprog=10K
5
300
standby mode(Charge termination)
50
150
25
50
Test Condition
stop mode(RPROG ununited)
VCC
很抱歉,暂时无法提供与“PJ4054B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.13851
- 500+0.12426
- 5000+0.11476
- 10000+0.11001
- 30000+0.10526
- 50000+0.10241
- 国内价格
- 10+0.30165
- 100+0.23901
- 300+0.20769
- 3000+0.16265
- 6000+0.14386
- 9000+0.13446
