120
DATA SHEET
ARRAY CHIP RESISTORS
YC/TC 124 (8Pin/4R)
5%, 1%
sizes 4 × 0402
Product specification – Mar 09, 2011 V.3 Supersedes Date of Mar. 06, 2003
RoHS compliant
Chip Resistor Surface Mount
YC/TC
SERIES
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes
YC124 (convex) and TC124 (concave)
series chip resistor arrays with
lead-free terminations made by
thick film process.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
Terminal for SDRAM and
DDRAM
Computer applications: laptop
computer, desktop computer
Consume electronic equipment:
PDAs, PNDs
Mobile phone, telecom…
2
9
124 (RoHS Compliant)
YAGEO BRAND ordering code
GLOBAL PART NUMBER
( PREFERRED )
YC
124 – X X X XX XXXX L
TC
(1) (2) (3) (4)
(5)
(6)
(1) TOLERANCE
F = ±1%
J = ±5% (for Jumper ordering, use code of J)
(2) PACKAGING TYPE
R = Paper taping reel
(3) TEMPERATURE COEFFICIENT OF RESISTANCE
– = Based on spec
FEATURES
RoHS compliant
Products with lead free
terminations meet RoHS
requirements
Pb-glass contained in electrodes
Resistor element and glass are
exempted by RoHS
Reduce environmentally
hazardous wastes
(4) TAPING REEL
07 = 7 inch dia. Reel
10 = 10 inch dia. Reel
13 = 13 inch dia. Reel
(5) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need
to mention the last zero after R/K/M, e.g.1K2, not 1K20.
Detailed resistance rules show in table of “Resistance rule of global part number”.
(6) DEFAULT CODE
High component and equipment
reliability
Save of PCB space
Letter L is the system default code for ordering only. (Note)
None forbidden-materials used
in products/production
number
Resistance code rule
Example
Halogen Free Epoxy
0R
0R = Jumper
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000 Ω
9M76= 9,760,000 Ω
ORDERING EXAMPLE
The ordering code of a YC124
convex chip resistor array, value
1,000 X with ±5% tolerance,
supplied in 7-inch tape reel is:
YC124-JR-071KL.
NOTE
1. All our RSMD products meet RoHS
compliant. "LFP" of the internal 2D reel
label mentions "Lead Free Process"
2. On customized label, "LFP" or specific
symbol printed and the optional "L" at
the end of GLOBAL PART NUMBER /
12NC can be added (both are on
customer request)
www.yageo.com
Mar 09, 2011 V.3
YC/TC
SERIES
3
9
PHYCOMP BRAND ordering codes
Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp
brand products.
GLOBAL PART NUMBER
( PREFERRED )
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
TC124 series is supplied and ordered by global part number only.
12NC
CODE
2350
XXX XXXXX L
(1)
(2)
(3)
Last digit of 12NC
Resistance decade (3)
(4)
TYPE/ START TOL. RESISTANCE
4×0402 IN (1)
RANGE
PAPER / PE TAPE ON REEL (units)
10,000
(2)
40,000
Last digit
0.01 to 0.0976 X
0.1 to 0.976 X
7
ARV341
2350
±5%
1 to 1 MΩ
033 11xxx
033 13xxx
1 to 9.76 X
ARV342
2350
±1%
1 to 1 MΩ
023 2xxxx
023 8xxxx
10 to 97.6 X
9
Jumper
2350
0Ω
033 91001
100 to 976 X
1
1 to 9.76 KX
2
10 to 97.6 KX
3
100 to 976 KX
4
1 to 9.76 MX
5
10 to 97.6 MX
6
(1) The resistors have a 12-digit ordering code starting with 2350.
(2) The subsequent 4 or 5 digits indicate the resistor tolerance and
packaging.
(3) The remaining 4 or 3 digits represent the resistance value with the
last digit indicating the multiplier as shown in the table of
“Last digit of 12NC”.
0.02 X
0200 or 200
0.3 X
3007 or 307
ORDERING EXAMPLE
1X
1008 or 108
The ordering code of a ARV341 resistor, value 1,000 X with ±5%
tolerance, supplied in tape of 10,000 units per reel is: 235003311102 (L)
or YC124-JR-071K(L).
33 KX
3303 or 333
10 MX
1006 or 106
(4) "L" is optional symbol
(Note) .
Example:
NOTE
1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process"
2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART
NUMBER / 12NC can be added (both are on customer request)
www.yageo.com
Mar 09, 2011 V.3
YC/TC
SERIES
4
9
MARKING
YC124
YNSC010
Fig. 1
Jumper = 0 Ω
E-24 series: 3 digits
2
YNSC029
Fig. 2
1-Digit marking
Value = 240 KΩ
First two digits for significant figure and 3rd digit for number of zeros
TC124
No marking
YNSC061
Fig. 3
For further marking information, please refer to data sheet “Chip resistors marking”.
www.yageo.com
Mar 09, 2011 V.3
YC/TC
5
9
SERIES
CONSTRUCTION
The resistor is constructed on top
of a high-grade ceramic body.
Internal metal electrodes are
added on each end to make the
contacts to the thick film resistive
element. The composition of the
resistive element is a noble metal
imbedded into a glass and
covered by a second glass to
prevent environment influences.
The resistor is laser trimmed to the
rated resistance value. The resistor
is covered with a protective epoxy
coat, finally the two external
terminations (matte tin on Ni-barrier)
are added, as shown in Fig 4.
OUTLINES
overcoat
resistive layer
inner electrode
termination
ceramic substrate
YNSC069
Fig. 4 Chip resistor outlines
DIMENSIONS
Table 1
TYPE
YC124
TC124
B (mm)
0.20 ±0.15
0.20 ±0.10
H (mm)
0.45 ±0.05
0.30 ±0.10
H1 (mm)
0.30 ±0.05
P (mm)
0.50 ±0.05
0.50 ±0.05
L (mm)
2.00 ±0.10
2.00 ±0.10
T (mm)
0.45 ±0.10
0.40 ±0.10
W1 (mm)
0.30 ±0.15
0.25 ±0.10
W2 (mm)
1.00 ±0.10
1.00 ±0.10
H
H1
H
a
B
T
a
W1
B
W2
a
P
L
YC124
P
L
TC124
a
YNSC054-2
Fig. 5 YC/TC124 series chip resistors dimension
SCHEMATIC
For dimension, please refer to Fig. 5 and Table 1
8
7
6
8
5
YC124
7
6
5
TC124
R1
R2
R3
R1
R4
R2
R3
R4
YNSC055-1
1
Fig. 6 Equivalent circuit diagram
2
R1 = R2 = R3 = R4
3
4
1
2
3
4
R1 = R2 = R3 = R4
www.yageo.com
Mar 09, 2011 V.3
YC/TC
SERIES
FOOTPRINT AND SOLDERING
ELECTRICAL CHARACTERISTICS
PROFILES
Table 2
YC124
CHARACTERISTICS
Operating Temperature Range
TC124
–55 °C to +155 °C –55 °C to +125 °C
Rated Power
1/16 W
1/16 W
Maximum Working Voltage
25 V
50 V
Maximum Overload Voltage
50 V
100 V
100 V
100 V
1 Ω to 1 MΩ
10 Ω to 1 MΩ
Dielectric Withstanding Voltage
Resistance Range
6
9
5% (E24)
1% (E24/E96)
Recommended footprint and
soldering profiles, please refer to
mounting”.
Zero Ohm Jumper < 0.05 Ω
Temperature Coefficient
Jumper Criteria
1 Ω ≤ R < 10 Ω ±250 ppm/°C
10 Ω ≤ R ≤ 1 MΩ ±200 ppm/°C
±200 ppm/°C
Rated Current
1.0 A
1.0 A
Maximum Current
2.0 A
1.5 A
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PRODUCT TYPE
PACKING STYLE
YC/TC124
Paper Taping Reel (R)
REEL DIMENSION
QUANTITY PER REEL
7" (178 mm)
10,000 units
10" (254 mm)
20,000 units
13" (330 mm)
40,000 units
NOTE
1. For paper tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”.
FUNCTIONAL DESCRIPTION
OPERATING TEMPERATURE RANGE
YC124: –55 °C to +155 °C
TC124: –55 °C to +125 °C
handbook, halfpage
P
(%Prated )
MLB206_3
100
POWER RATING
YC/TC 124 rated power at 70 °C is 1/16 W
RATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=√(P X R)
or max. working voltage whichever is less
YC124
50
TC124
70
100
125 155
o
Tamb ( C)
Fig. 7 Maximum dissipation (P) in percentage of rated power as a
function of the operating ambient temperature (Tamb)
Where
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (X)
www.yageo.com
Mar 09, 2011 V.3
YC/TC
SERIES
7
9
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Life/
Operational
Life/
Endurance
MIL-STD-202G-method 108A
1,000 hours at 70±5 °C applied RCWV
1.5 hours on, 0.5 hour off, still air required
±(2%+0.05 Ω)
