120
DATA SHEET
ARRAY CHIP RESISTORS
YC/TC 164 (8Pin/4R)
5%, 1%
sizes 4 × 0603
Product specification – Oct 27, 2008 V.3ate of Mar. 06, 2003
RoHS compliant
Chip Resistor Surface Mount
YC/TC
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes
YC164 (convex) and TC164 (concave)
series chip resistor arrays with
lead-free terminations made by
thick film process.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
Terminal for SDRAM and
DDRAM
Computer applications: laptop
computer, desktop computer
Consume electronic equipment:
PDAs, PNDs
Mobile phone, telecom…
2
8
164 (RoHS Compliant)
SERIES
YAGEO BRAND ordering code
GLOBAL PART NUMBER
( PREFERRED )
YC
164 – X X X XX XXXX L
TC
(1) (2) (3) (4)
(5)
(6)
(1) TOLERANCE
F = ±1%
J = ±5% (for Jumper ordering, use code of J)
(2) PACKAGING TYPE
R = Paper taping reel
(3) TEMPERATURE COEFFICIENT OF RESISTANCE
– = Base on spec
FEATURES
RoHS compliant
Products with lead free
terminations meet RoHS
requirements
Pb-glass contained in electrodes
Resistor element and glass are
exempted by RoHS
Reducing environmentally
hazardous wastes
(4) TAPING REEL
07 = 7 inch dia. Reel
10 = 10 inch dia. Reel
13 = 13 inch dia. Reel
(5) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need
to mention the last zero after R/K/M, e.g.1K2, not 1K20.
Detailed resistance rules show in table of “Resistance rule of global part number”.
(6) OPTIONAL CODE
High component and equipment
reliability
Saving of PCB space
L = optional symbol (Note)
None forbidden-materials used
in products/production
number
Resistance code rule
Example
Halogen Free Epoxy
0R
0R = Jumper
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000 Ω
9M76= 9,760,000 Ω
ORDERING EXAMPLE
The ordering code of a YC164
convex chip resistor array, value
1,000 X with ±5% tolerance,
supplied in 7-inch tape reel is:
YC164-JR-071K(L).
NOTE
1. All our RSMD products meet RoHS
compliant. "LFP" of the internal 2D reel
label mentions "Lead Free Process"
2. On customized label, "LFP" or specific
symbol printed and the optional "L" at
the end of GLOBAL PART NUMBER /
12NC can be added (both are on
customer request)
www.yageo.com
Oct 27, 2008 V.3
YC/TC
SERIES
3
8
PHYCOMP BRAND ordering codes
Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp
brand products.
GLOBAL PART NUMBER
( PREFERRED )
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
12NC
CODE
2350
XXX XXXXX L
(1)
(2)
(3)
Last digit of 12NC
Resistance decade (3)
(4)
TYPE/ START TOL. RESISTANCE
4×0603 IN (1)
RANGE
PAPER / PE TAPE ON REEL (units)
5,000
(2)
20,000
Last digit
0.01 to 0.0976 X
0.1 to 0.976 X
7
ARV241
2350
±5%
1 to 1 MΩ
035 10xxx
035 12xxx
1 to 9.76 X
ARV242
2350
±1%
1 to 1 MΩ
025 1xxxx
025 3xxxx
10 to 97.6 X
9
ARC241 2350
±5%
10 to 1 MΩ
034 10xxx
013 3xxxx
100 to 976 X
1
ARC242 2350
±1%
10 to 1 MΩ
024 1xxxx
013 3xxxx
1 to 9.76 KX
2
Jumper
0Ω
ARV241/YC164 035 91001
10 to 97.6 KX
3
ARC241/TC164 034 91001
100 to 976 KX
4
(1) The resistors have a 12-digit ordering code starting with 2350.
1 to 9.76 MX
5
(2) The subsequent 4 or 5 digits indicate the resistor tolerance and
packaging.
10 to 97.6 MX
6
2350
(3) The remaining 4 or 3 digits represent the resistance value with the
last digit indicating the multiplier as shown in the table of
“Last digit of 12NC”.
(4) "L" is optional symbol (Note) .
Example:
0.02 X
0200 or 200
0.3 X
3007 or 307
1X
1008 or 108
33 KX
3303 or 333
10 MX
1006 or 106
ORDERING EXAMPLE
The ordering code of a ARV241 resistor, value 1,000 X with ±5%
tolerance, supplied in tape of 10,000 units per reel is: 235003510102(L)
or YC164-JR-071K(L).
NOTE
1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process"
2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART
NUMBER / 12NC can be added (both are on customer request)
www.yageo.com
Oct 27, 2008 V.3
YC/TC
4
8
SERIES
MARKING
YC164
TC164
1-Digit marking
YNSC032
YNSC010
Fig. 1 Jumper=0Ω
Fig. 2 Jumper=0Ω
2
E-24 series: 3 digits
2
YNSC029
First two digits for significant figure and 3rd digit
for number of zeros
YNSC036
Fig. 3 Value = 240 KΩ
Fig. 4 Value = 240 KΩ
For further marking information, please see special data sheet “Chip resistors marking”
CONSTRUCTION
OUTLINES
The resistor is constructed on top of a high-grade
ceramic body. Internal metal electrodes are added on
each end to make the contacts to the thick film resistive
element. The composition of the resistive element is a
noble metal imbedded into a glass and covered by a
second glass to prevent environment influences. The
resistor is laser trimmed to the rated resistance value.
The resistor is covered with a protective epoxy coat,
finally the two external terminations (matte tin on Nibarrier) are added. See fig.5
overcoat
resistive layer
inner electrode
termination
ceramic substrate
YNSC069
Fig. 5 Chip resistor outlines
DIMENSIONS
Table 1
TYPE
YC164
TC164
B (mm)
0.30 ±0.15
0.30 ±0.15
H (mm)
0.65 ±0.05
H1 (mm)
0.50 ±0.15
P (mm)
0.80 ±0.05
0.80 ±0.05
L (mm)
3.20 ±0.15
3.20 ±0.15
T (mm)
0.60 ±0.10
0.60 ±0.10
W1 (mm)
0.30 ±0.15
0.30 ±0.15
W2 (mm)
1.60 ±0.15
1.60 ±0.15
H
H1
H
a
B
T
a
W1
B
W2
a
L
YC164
P
L
TC164
a
YNSC054-1
Fig. 6 YC/TC164 series chip resistors dimension
SCHEMATIC
For dimension see Fig. 6 and Table 1
8
7
6
8
5
YC164
7
6
5
TC164
R1
R2
R3
R1
R4
R2
R3
R4
YNSC055
1
Fig. 7 Equivalent circuit diagram
2
R1 = R2 = R3 = R4
3
4
1
2
3
4
R1 = R2 = R3 = R4
www.yageo.com
Oct 27, 2008 V.3
YC/TC
SERIES
ELECTRICAL CHARACTERISTICS
FOOTPRINT AND SOLDERING
PROFILES
Table 2
YC/TC164 1/16 W
CHARACTERISTICS
Operating Temperature Range
–55 °C to +155 °C
Maximum Working Voltage
50 V
Maximum Overload Voltage
100 V
Dielectric Withstanding Voltage
100 V
Resistance Range
5% (E24), 1% (E24/E96)
5
8
YC164
1 Ω to 1 MΩ
TC164
10 Ω to 1 MΩ
For recommended footprint and
soldering profiles, please see the
mounting”.
Zero Ohm Jumper < 0.05 Ω
Temperature Coefficient
±200 ppm/°C
Jumper Criteria
Rated Current
1.0 A
Maximum Current
2.0 A
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PRODUCT TYPE
PACKING STYLE
REEL DIMENSION
QUANTITY PER REEL
YC/TC164
Paper Taping Reel (R)
7" (178 mm)
5,000 units
10" (254 mm)
10,000 units
13" (330 mm)
20,000 units
NOTE
1. For paper tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”.
FUNCTIONAL DESCRIPTION
POWER RATING
YC/TC 164 rated power at 70 °C is 1/16 W
RATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=√(P X R)
or max. working voltage whichever is less
handbook, halfpage
P
(%Prated )
MLB206_2
100
50
70
100
155
o
Tamb ( C)
Where
V=Continuous rated DC or
AC (rms) working voltage (V)
Fig. 8 Maximum dissipation (P) in percentage of rated power as a
function of the operating ambient temperature (Tamb)
P=Rated power (W)
R=Resistance value (X)
www.yageo.com
Oct 27, 2008 V.3
YC/TC
SERIES
6
8
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Life/
Operational Life/
Endurance
MIL-STD-202G-method 108A
1,000 hours at 70±5 °C applied RCWV
1.5 hours on, 0.5 hour off, still air required
±(2%+0.05 Ω)
