YC164-JR-0733RL
YC164-JR-0733RL
    YAGEO(国巨)
    RA_0603X4
    排阻/电阻网络 RA_0603X4 33Ω ±5% ±200ppm/℃
YC164-JR-0733RL 数据手册
120 DATA SHEET ARRAY CHIP RESISTORS YC/TC 164 (8Pin/4R) 5%, 1% sizes 4 × 0603 Product specification – Oct 27, 2008 V.3ate of Mar. 06, 2003 RoHS compliant Product specification Chip Resistor Surface Mount YC/TC SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes YC164 (convex) and TC164 (concave) series chip resistor arrays with lead-free terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. APPLICATIONS Terminal for SDRAM and DDRAM Computer applications: laptop computer, desktop computer Consume electronic equipment: PDAs, PNDs Mobile phone, telecom… 2 8 164 (RoHS Compliant) SERIES YAGEO BRAND ordering code GLOBAL PART NUMBER ( PREFERRED ) YC 164 – X X X XX XXXX L TC (1) (2) (3) (4) (5) (6) (1) TOLERANCE F = ±1% J = ±5% (for Jumper ordering, use code of J) (2) PACKAGING TYPE R = Paper taping reel (3) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec FEATURES RoHS compliant - Products with lead free terminations meet RoHS requirements - Pb-glass contained in electrodes - Resistor element and glass are exempted by RoHS Reducing environmentally hazardous wastes (4) TAPING REEL 07 = 7 inch dia. Reel 10 = 10 inch dia. Reel 13 = 13 inch dia. Reel (5) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed resistance rules show in table of “Resistance rule of global part number”. (6) OPTIONAL CODE High component and equipment reliability Saving of PCB space L = optional symbol (Note) None forbidden-materials used in products/production Resistance rule of global part number Resistance code rule Example Halogen Free Epoxy 0R 0R = Jumper XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω ORDERING EXAMPLE The ordering code of a YC164 convex chip resistor array, value 1,000 X with ±5% tolerance, supplied in 7-inch tape reel is: YC164-JR-071K(L). NOTE 1. All our RSMD products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Oct 27, 2008 V.3 Product specification Chip Resistor Surface Mount YC/TC SERIES 3 8 164 (RoHS Compliant) PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER ( PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2350 XXX XXXXX L (1) (2) (3) Last digit of 12NC Resistance decade (3) (4) TYPE/ START TOL. RESISTANCE 4×0603 IN (1) RANGE (%) PAPER / PE TAPE ON REEL (units) 5,000 (2) 20,000 Last digit 0.01 to 0.0976 X 0.1 to 0.976 X 0 8 7 ARV241 2350 ±5% 1 to 1 MΩ 035 10xxx 035 12xxx 1 to 9.76 X ARV242 2350 ±1% 1 to 1 MΩ 025 1xxxx 025 3xxxx 10 to 97.6 X 9 ARC241 2350 ±5% 10 to 1 MΩ 034 10xxx 013 3xxxx 100 to 976 X 1 ARC242 2350 ±1% 10 to 1 MΩ 024 1xxxx 013 3xxxx 1 to 9.76 KX 2 Jumper - 0Ω ARV241/YC164 035 91001 - 10 to 97.6 KX 3 ARC241/TC164 034 91001 - 100 to 976 KX 4 (1) The resistors have a 12-digit ordering code starting with 2350. 1 to 9.76 MX 5 (2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. 10 to 97.6 MX 6 2350 (3) The remaining 4 or 3 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. (4) "L" is optional symbol (Note) . Example: 0.02 X = 0200 or 200 0.3 X = 3007 or 307 1X = 1008 or 108 33 KX = 3303 or 333 10 MX = 1006 or 106 ORDERING EXAMPLE The ordering code of a ARV241 resistor, value 1,000 X with ±5% tolerance, supplied in tape of 10,000 units per reel is: 235003510102(L) or YC164-JR-071K(L). NOTE 1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Oct 27, 2008 V.3 Product specification Chip Resistor Surface Mount YC/TC 4 8 164 (RoHS Compliant) SERIES MARKING YC164 TC164 0 0 1-Digit marking YNSC032 YNSC010 Fig. 1 Jumper=0Ω Fig. 2 Jumper=0Ω 2 E-24 series: 3 digits 2 YNSC029 First two digits for significant figure and 3rd digit for number of zeros YNSC036 Fig. 3 Value = 240 KΩ Fig. 4 Value = 240 KΩ For further marking information, please see special data sheet “Chip resistors marking” CONSTRUCTION OUTLINES The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added. See fig.5 overcoat resistive layer inner electrode termination ceramic substrate YNSC069 Fig. 5 Chip resistor outlines DIMENSIONS Table 1 TYPE YC164 TC164 B (mm) 0.30 ±0.15 0.30 ±0.15 H (mm) 0.65 ±0.05 --- H1 (mm) 0.50 ±0.15 --- P (mm) 0.80 ±0.05 0.80 ±0.05 L (mm) 3.20 ±0.15 3.20 ±0.15 T (mm) 0.60 ±0.10 0.60 ±0.10 W1 (mm) 0.30 ±0.15 0.30 ±0.15 W2 (mm) 1.60 ±0.15 1.60 ±0.15 H H1 H a B T a W1 B W2 a L YC164 P L TC164 a YNSC054-1 Fig. 6 YC/TC164 series chip resistors dimension SCHEMATIC For dimension see Fig. 6 and Table 1 8 7 6 8 5 YC164 7 6 5 TC164 R1 R2 R3 R1 R4 R2 R3 R4 YNSC055 1 Fig. 7 Equivalent circuit diagram 2 R1 = R2 = R3 = R4 3 4 1 2 3 4 R1 = R2 = R3 = R4 www.yageo.com Oct 27, 2008 V.3 Product specification Chip Resistor Surface Mount YC/TC SERIES ELECTRICAL CHARACTERISTICS FOOTPRINT AND SOLDERING PROFILES Table 2 YC/TC164 1/16 W CHARACTERISTICS Operating Temperature Range –55 °C to +155 °C Maximum Working Voltage 50 V Maximum Overload Voltage 100 V Dielectric Withstanding Voltage 100 V Resistance Range 5% (E24), 1% (E24/E96) 5 8 164 (RoHS Compliant) YC164 1 Ω to 1 MΩ TC164 10 Ω to 1 MΩ For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”. Zero Ohm Jumper < 0.05 Ω Temperature Coefficient ±200 ppm/°C Jumper Criteria Rated Current 1.0 A Maximum Current 2.0 A PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PRODUCT TYPE PACKING STYLE REEL DIMENSION QUANTITY PER REEL YC/TC164 Paper Taping Reel (R) 7" (178 mm) 5,000 units 10" (254 mm) 10,000 units 13" (330 mm) 20,000 units NOTE 1. For paper tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”. FUNCTIONAL DESCRIPTION POWER RATING YC/TC 164 rated power at 70 °C is 1/16 W RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less handbook, halfpage P (%Prated ) MLB206_2 100 50 0 55 0 50 70 100 155 o Tamb ( C) Where V=Continuous rated DC or AC (rms) working voltage (V) Fig. 8 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (Tamb) P=Rated power (W) R=Resistance value (X) www.yageo.com Oct 27, 2008 V.3 Product specification Chip Resistor Surface Mount YC/TC SERIES 6 8 164 (RoHS Compliant) TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Life/ Operational Life/ Endurance MIL-STD-202G-method 108A 1,000 hours at 70±5 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required ±(2%+0.05 Ω)
YC164-JR-0733RL 价格&库存
很抱歉,暂时无法提供与“YC164-JR-0733RL”相匹配的价格&库存,您可以联系我们找货
YC164-JR-0733RL
    库存:248230
    YC164-JR-0733RL
    • 1+0.14200
    • 100+0.07790
    • 1000+0.04760
    • 2500+0.03210
    • 5000+0.02290
    库存:203719
    YC164-JR-0733RL
    • 50+0.02575
    • 500+0.02327
    • 5000+0.02162
    • 10000+0.02080
    • 30000+0.01997
    • 50000+0.01948
    库存:3453
    YC164-JR-0733RL
      库存:248230
