Glass-Encapsulate Diodes
FAST SWITCHING DIODES
LL4148
FEATURES
Cathode indification
φ1 .5±0.1
Silicon epitaxial diode
500mW power dissipation
High speed switching diode
MECHANICAL DATA
0.4±0.1
3.5 ±0.2
Polarity:Color band denotes cathode
Case:
LL-34(SOD-80) Dimensions in millimeters
LL-34 glass case
Weight: Approx 0.031 grams
Absolute Maximum Ratings (TA=25
Parameter
unless otherwise noted)
Symbol
Value
Unit
v
Reverse voltage
VR
75
Peak reverse voltage
V RM
100
v
IO
150
mA
IFSM
500 1)
mA
Pow er dissipaton at tamb=25 C
Ptot
500
mW
Junction temperature
TJ
175
Average Rectified Current
Non-repetitive Peak Forward Current
o
Storage temperature range
TSTG
o
C
o
C
-55-175
1) Valid prov ided that electrodes are kept at ambient temperature.
ELECTRICAL CHARACTERISTICS (Tamb=25
Parameter
Symbol
unless otherwise specified)
Min.
Typ.
Max.
Unit
Forward voltage
@ IF=10mA
VF
1.0
v
Leakage current
at VR=20V
IR
25
nA
at VR=75V
IR
5
uA
IR
50
uA
Capacitance at V F=V R=0V
Ctot
4
pF
Voltage rise when switching on tested with
Vfr
2.5
V
trr
4.0
nS
RθJA
350
K/W
at VR=20V
o
TJ=150 C
50mA pulses tp=0,1uS , rise time 30ns, f
p=5 to 100KHz
Reverse recovery time from IF=10mA
VR=6V,RL=100 ,at IR=1mA
Thermal resistance junction to ambient
Rectification effciency at 100MHz,VRF=2V
V
GUANGDONG HOTTECH
0.45
INDUSTRIAL CO., LTD
Page:P2-P1
LL4148
Typical
Characteristics
mA
3
10
mW
1000
900
10
800
2
IF
O
TJ =100 C
700
Ptot
600
10
500
O
TJ =25 C
400
1
300
200
-1
10
100
-2
100
10
175 200℃
T
F
AMBIENT TEMPERATURE
FIG.2-- FORWARD CHARACTERISTICS
100
IFRM
2V
V
A
I
V=tp/T
T=1/tp
10
0.1
tp
n=0
0.2
1
IFRM
T
0.3
0.1
-3
-5
10
10
-2
10
-1
10
1
10S
FIG.3-ADMISSIBLE REPETITIVE PEAK FORWORD CURRENT VERSUS PULSE DURATION
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P2
很抱歉,暂时无法提供与“LL4148”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08022
- 500+0.06546
- 1000+0.06448
- 2500+0.04966
- 12500+0.04477
- 25000+0.04054
- 国内价格
- 1+0.03730
- 2500+0.02920
- 国内价格
- 50+0.08752
- 500+0.07141
- 2500+0.05418
- 5000+0.04884
- 25000+0.04423
- 50000+0.04166
- 国内价格
- 50+0.08580
- 500+0.06980
- 2500+0.05170
- 5000+0.04650
- 25000+0.04210
- 50000+0.03970
- 国内价格
- 1+0.02380
- 1000+0.02160
