Plastic-Encapsulate Diodes
SCHOTTKY DIODES
FEATURES
SS12---SS1200
Plastic package has Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
52
Metal silicon junction, majority carrier conduction
4.50
7
Built-in strain relief, ideal for automated placement
Low power loss, high efficiency.
High forward surge current capability
MECHANICAL DATA
SMA (DO-214AC) molded plastic body
DO-214AC (SMA)
leads solderable per MIL-STD-750, Method 2026
color band denotes cathode end
MAXIMUM RATINGS
AND ELECTRICAL CHARACTERISTICS
Ratings at 25OC ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For
capacitive load, derate current by 20%.
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SYMBOLS SS12 SS13 SS14
VRRM
VRMS
VDC
21
30
SS15
SS16
50
35
50
60
42
60
40
28
40
SS18 SS110 SS1150 SS1200
80
56
80
100
70
100
150
105
150
200
140
200
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
1.0
Amp
IFSM
30.0
Amps
VF
0.45
0.5
10.0
IR
CJ
RθJA
TJ,
TSTG
0.70
0.55
0.85
5.0
90
110
88.0
-50 to +125
-50 to +150
-50 to +150
0.95
0.2
2.0
Volts
mA
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P1
SS12---SS1200 Typical Characteristics
FIG.1-FORWARD CURRENT DERATING CURVE
Fig.2- MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
40
PEAK FORWARD SURGE
CURRENT, A
AVERAGE FORWARD RECTIFIED
CURRENT, A
1.0
SS12-SS14
0.8
SS15-SS110
0.6
0.4
0.2
Single phase, half wave 60Hz,
32
24
16
8
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
75
50
1
NUMBER OF CYCLES AT 60 Hz
AMBIENT TEMPERATURE, ( C)
Fig.3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
Fig.4- TYPICAL REVERSE CHARACTERISTICS
Tj=25o C
1000
INSTANTANEOUS REVERSE CURRENT,
MILLAMPERES
INSTANTANEOUS FORWARD CURRENT, A
50
100
10
10
1
0.1
100
TJ =100 oC
10
o
TJ =75 C
1.0
o
TJ =25 C
0.01
SS12-SS14
60
80
100
SS15-SS16
SS18-SS110
PERCENT OF RATED PEAK REVERSE
VOLTAGE,%
0.01
0.8
1.0 1.2 1.4 1.6
INSTANTANEOUS FORWARD VOLTAGE, V
Fig.5- TYPICAL JUNCTION CAPACITANCE
Fig.6- TYPICAL TRANSIENT THERMAL IMPEDANCE
Tj=25 C
200
100
TRANSIENT THERMAL
IMPEDANCE, C/W
JUNCTION CAPACITANCE,pF
400
SS12-SS14
SS15-SS110
1
2
0.1
1
10
100
0.1
0.01
0.1
1
10
100
REVERSE VOLTAGE, V
PULSE DURATION, sec.
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P2
很抱歉,暂时无法提供与“SS14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06731
- 150+0.05741
- 1000+0.04751
- 5000+0.04355
- 国内价格
- 1+0.10483
- 50+0.05247
- 2000+0.03960
- 国内价格
- 50+0.06920
- 150+0.06400
- 1000+0.05860
- 5000+0.05330
- 国内价格
- 50+0.09610
- 500+0.07450
- 2000+0.06490
- 4000+0.05780
- 24000+0.05160
- 50000+0.04830
- 国内价格
- 50+0.11256
- 500+0.08732
- 2000+0.07634
- 4000+0.06793
- 24000+0.06065
- 50000+0.05674
