Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
BAS85
Schottky barrier diode
Rev. 6 — 10 September 2010
Product data sheet
1. Product profile
1.1 General description
Planar Schottky barrier diode with an integrated guard ring for stress protection,
encapsulated in a small hermetically sealed glass SOD80C Surface-Mounted
Device SMD package with tin-plated metal discs at each end. It is suitable for
“automatic placement” and as such it can withstand immersion soldering.
1.2 Features and benefits
Low forward voltage
High breakdown voltage
Guard-ring protected
Hermetically sealed glass SMD package
1.3 Applications
Ultra high-speed switching
Voltage clamping
Protection circuits
Blocking diodes
1.4 Quick reference data
Table 1.
Symbol
Parameter
Min
Typ
Max
Unit
IF
forward current
Conditions
200
mA
VR
reverse voltage
30
V
VF
forward voltage
800
mV
IF = 100 mA
BAS85
NXP Semiconductors
2. Pinning information
Table 2.
Pinning
Pin
Description
1
cathode
2
anode
Simplified outline
Graphic symbol
[1]
k
1
a
2
sym001
[1]
The marking band indicates the cathode.
3. Ordering information
Table 3.
Type number
BAS85
Package
Name
Description
Version
hermetically sealed glass surface-mounted package;
2 connectors
SOD80C
4. Marking
Table 4.
Marking codes
Type number
Marking code
BAS85
marking band
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VR
reverse voltage
IF
forward current
Product data sheet
Min
[1]
Max
Unit
30
V
200
mA
200
mA
IF(AV)
average forward current
IFRM
repetitive peak forward
current
tp ≤ 1 s; δ ≤ 0.5
300
mA
IFSM
non-repetitive peak
forward current
tp = 10 ms
5
A
Tj
junction temperature
125
°C
Tamb
ambient temperature
−65
+125
°C
Tstg
storage temperature
−65
+150
°C
[1]
BAS85
Conditions
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
All information provided in this document is subject to legal disclaimers.
© NXP B.V. 2010. All rights reserved.
2 of 10
BAS85
NXP Semiconductors
6. Thermal characteristics
Table 6.
Symbol
Rth(j-a)
[1]
Parameter
Conditions
thermal resistance from
junction to ambient
in free air
[1]
Min
Typ
Max
Unit
320
K/W
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
7. Characteristics
Table 7.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VF
forward voltage
IF = 0.1 mA
240
mV
IF = 1 mA
320
mV
IF = 10 mA
400
mV
IF = 30 mA
500
mV
800
mV
2.3
μA
10
pF
IF = 100 mA
IR
reverse current
VR = 25 V
Cd
diode capacitance
VR = 1 V; f = 1 MHz
[1]
BAS85
Product data sheet
[1]
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
3 of 10
BAS85
NXP Semiconductors
mra540
IF(AV)
(mA)
mld358
103
250
IF
(mA)
200
(1) (2) (3)
102
150
10
100
(1)
(2) (3)
1
50
100
150
10−1
0.8
Tamb (°C)
VF (V)
1.2
(1) Tamb = 125 °C
FR4 PCB, standard footprint
(2) Tamb = 85 °C
(3) Tamb = 25 °C
Fig 1.
Average forward current as a function of
ambient temperature; derating curve
Fig 2.
mgc682
105
IR
(nA)
Forward current as a function of forward
voltage; typical values
mgc681
12
(1)
Cd
(pF)
104
8
103
(2)
102
4
10
1
(3)
10−1
VR (V)
(1) Tamb = 85 °C
10
VR (V)
30
f = 1 MHz; Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −40 °C
Fig 3.
Reverse current as a function of reverse
BAS85
Product data sheet
Fig 4.
Diode capacitance as a function of reverse
4 of 10
BAS85
NXP Semiconductors
8. Package outline
0.3
0.3
1.60
1.45
3.7
3.3
Dimensions in mm
Fig 5.
06-03-16
Package outline SOD80C
9. Packing information
Table 8.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
BAS85
[1]
BAS85
Product data sheet
Package Description
SOD80C
4 mm pitch, 8 mm tape and reel
Packing quantity
2500
10000
-115
-135
For further information and the availability of packing methods, see Section 13.
5 of 10
BAS85
NXP Semiconductors
10. Soldering
4.55
4.30
2.30
solder lands
solder paste
2.25 1.70 1.60
solder resist
occupied area
Dimensions in mm
0.90
(2x)
Fig 6.
sod080c
Reflow soldering footprint SOD80C
6.30
4.90
2.70
1.90
solder lands
solder resist
occupied area
2.90 1.70
tracks
Dimensions in mm
sod080c
Fig 7.
BAS85
Product data sheet
Wave soldering footprint SOD80C
6 of 10
BAS85
NXP Semiconductors
11. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BAS85_6
20100910
Product data sheet
BAS85_5
Modifications:
Section 4 “Marking”: updated
Section 12 “Legal information”: updated
BAS85_5
20090325
Product data sheet
BAS85_4
BAS85_4
20000525
Product specification
BAS85_3
BAS85_3
19961001
BAS85_2
BAS85_2
19960320
BAS85
Product data sheet
7 of 10
BAS85
NXP Semiconductors
12. Legal information
12.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, NXP Semiconductors does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using NXP Semiconductors products, and NXP Semiconductors
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the NXP
Semiconductors product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
BAS85
Product data sheet
8 of 10
BAS85
NXP Semiconductors
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific NXP Semiconductors product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. NXP
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without NXP Semiconductors’ warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
NXP Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies NXP Semiconductors for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond NXP Semiconductors’
standard warranty and NXP Semiconductors’ product specifications.
12.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
13. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
BAS85
Product data sheet
9 of 10
BAS85
NXP Semiconductors
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
12.1
12.2
12.3
12.4
13
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 5
Packing information . . . . . . . . . . . . . . . . . . . . . 5
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 7
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 8
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 8
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Contact information. . . . . . . . . . . . . . . . . . . . . . 9
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2010.
Date of release: 10 September 2010
Document identifier: BAS85
