IP4220CZ6,125
IP4220CZ6,125
    NEXPERIA(安世)
    TSOP6
    ESD suppressor 4 Channel VRWM=5.5 V VBR(Min)=6 V TSOP6_3.1X1.7MM
IP4220CZ6,125 数据手册
IP4220CZ6 Dual USB 2.0 integrated ESD protection Rev. 5 — 8 July 2011 Product data sheet 1. Product profile 1.1 General description The IP4220CZ6 is designed to protect I/O lines sensitive to capacitive load, such as USB 2.0, ethernet, Digital Video Interface (DVI) and so on, from damage due to ElectroStatic Discharge (ESD). It incorporates four pairs of ultra low capacitance rail-to-rail ESD protection diodes plus a Zener diode to provide protection to signal and supply components from ESD voltages up to 8 kV contact discharge. Protection is supply voltage independent due to the rail-to-rail diodes being connected to the Zener diode. The device is encapsulated in a small 6-lead SOT457 (SC-74) Surface-Mounted Device (SMD) plastic package. 1.2 Features and benefits  Pb-free, Restriction of Hazardous Substances (RoHS) compliant and free of halogen and antimony (Dark Green compliant)  ESD protection up to 8 kV contact discharge; IEC 61000-4-2, level 4 compliant  Four pairs of ultra low input capacitance (CI = 1 pF) ESD rail-to-rail protection diodes  Low voltage clamping due to integrated Zener diode  Small 6-lead TSOP6 (SOT457) SMD package 1.3 Applications  General-purpose downstream ESD protection for high-frequency analog signal ports and high-speed serial data transmission ports in:  Cellular phone and Personal Communication System (PCS) mobile handsets  PC/notebook USB 2.0/IEEE1394 ports  DVI  Cordless telephones  Wireless data (WAN/LAN) systems  Mobile Internet Devices (MID)  Portable media Players (PMP)  High-Definition Multimedia Interface (HDMI) IP4220CZ6 Nexperia Dual USB 2.0 integrated ESD protection 2. Pinning information Table 1. Pinning Pin Symbol Description Simplified outline 1 I/O 1 ESD protection 2 GND ground 3 I/O 2 ESD protection 4 I/O 3 ESD protection 5 VP supply voltage 6 I/O 4 ESD protection 6 5 4 1 2 3 Graphic symbol 6 5 4 1 2 3 018aaa142 3. Ordering information Table 2. Ordering information Type number IP4220CZ6 Package Name Description Version SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 4. Marking Table 3. Marking codes Type number Marking code IP4220CZ6 20 5. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VI input voltage VESD electrostatic discharge voltage Tstg storage temperature Min Max Unit 0 5.5 V 8 +8 kV 55 +125 C Min Typ Max Unit 40 - +85 C IEC 61000-4-2, level 4, contact; all pins 6. Recommended operating conditions IP4220CZ6 Product data sheet Table 5. Operating conditions Symbol Parameter Tamb ambient temperature Conditions All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 July 2011 © Nexperia B.V. 2017. All rights reserved 2 of 9 IP4220CZ6 Nexperia Dual USB 2.0 integrated ESD protection 7. Characteristics Table 6. Characteristics Tamb = 25 C; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit - 1.0 - pF C(I/O-GND) input/output to ground capacitance VI = 0 V; f = 1 MHz; VP = 3 V [1] C(zd-GND) Zener diode to ground capacitance VI = 0 V; f = 1 MHz; VP = 3 V [3] - 40 - pF IRM reverse leakage current VI = 3 V [2] - - 100 nA I = 1 mA [3] 6 - 9 V - 0.7 - V VBRzd Zener diode breakdown voltage VF forward voltage [1] Pins 1, 3, 4 and 6. [2] Pins 1, 3, 4 and 6 to ground. [3] Pin 5 to pin 2. 8. Application information 8.1 Universal serial bus 2.0 protection The device is optimized to protect, for example, two USB 2.0 ports from ESD. Each device can protect both USB data lines and the VBUS supply line. A typical application is shown in Figure 1. VBUS D+ D– GND IP4220CZ6 USB 2.0 IEEE1394 CONTROLLER 4 3 5 2 6 1 VBUS D+ D– GND 018aaa143 Fig 1. IP4220CZ6 Product data sheet Typical application of IP4220CZ6 All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 July 2011 © Nexperia B.V. 2017. All rights reserved 3 of 9 IP4220CZ6 Nexperia Dual USB 2.0 integrated ESD protection 9. Package outline Plastic surface-mounted package (TSOP6); 6 leads D SOT457 E B y A HE 6 5 X v M A 4 Q pin 1 index A A1 c 1 2 3 Lp bp e w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT457 Fig 2. JEITA EUROPEAN PROJECTION ISSUE DATE 05-11-07 06-03-16 SC-74 Package outline SOT457 (SC-74) IP4220CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 July 2011 © Nexperia B.V. 2017. All rights reserved 4 of 9 IP4220CZ6 Nexperia Dual USB 2.0 integrated ESD protection 10. Soldering 3.45 1.95 0.45 0.55 (6×) (6×) 0.95 solder lands solder resist 3.3 2.825 0.95 solder paste occupied area 0.7 (6×) Dimensions in mm 0.8 (6×) 2.4 Fig 3. sot457_fr Reflow soldering footprint SOT457 (SC-74) 5.3 1.5 (4×) solder lands 1.475 solder resist 0.45 (2×) 5.05 occupied area 1.475 Dimensions in mm preferred transport direction during soldering 1.45 (6×) 2.85 Fig 4. IP4220CZ6 Product data sheet sot457_fw Wave soldering footprint SOT457 (SC-74) All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 July 2011 © Nexperia B.V. 2017. All rights reserved 5 of 9 IP4220CZ6 Nexperia Dual USB 2.0 integrated ESD protection 11. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes IP4220CZ6 v.5 20110708 Product data sheet - IP4220CZ6 v.4 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • Legal texts have been adapted to the new company name where appropriate. • • • • • • Section 1 “Product profile”: updated Section 2 “Pinning information”: updated Section 4 “Marking”: added Table 4 and 6: parameters VI/O; Vesd; CI/O(n); VI/O(n); IL(n); Cd(Zener) and VBR(Zener) redefined respectively to VI; VESD; C(I/O-GND); VI; IRM; C(zd-GND) and VBRzd. Figure 1: updated Figure 2 “Package outline SOT457 (SC-74)”: updated Section 8.2. IP4220CZ6 spice model: deleted Section 10 “Soldering”: added Abbreviation table: deleted Section 12 “Legal information”: updated IP4220CZ6 v.4 20050912 Product data sheet - IP4220CZ6 v.3 IP4220CZ6 v.3 20050712 Product data sheet - IP4220CZ6 v.2 IP4220CZ6 v.2 20050608 Product data sheet - IP4220CZ6_N v.1 IP4220CZ6_N v.1 20040917 Preliminary specification - IP4220CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 July 2011 - © Nexperia B.V. 2017. All rights reserved 6 of 9 IP4220CZ6 Nexperia Dual USB 2.0 integrated ESD protection 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. IP4220CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 July 2011 © Nexperia B.V. 2017. All rights reserved 7 of 9 IP4220CZ6 Nexperia Dual USB 2.0 integrated ESD protection Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com IP4220CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 July 2011 © Nexperia B.V. 2017. All rights reserved 8 of 9 IP4220CZ6 Nexperia Dual USB 2.0 integrated ESD protection 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 8 8.1 9 10 11 12 12.1 12.2 12.3 12.4 13 14 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description . . . . . . . . . . . . . . . . . . . . . Features and benefits . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Recommended operating conditions. . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Application information. . . . . . . . . . . . . . . . . . . Universal serial bus 2.0 protection . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . Contact information. . . . . . . . . . . . . . . . . . . . . . Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 08 July 2011 1 1 1 1 2 2 2 2 2 3 3 3 4 5 6 7 7 7 7 8 8 9
IP4220CZ6,125 价格&库存
很抱歉,暂时无法提供与“IP4220CZ6,125”相匹配的价格&库存,您可以联系我们找货
IP4220CZ6,125
  • 20+9.63850
  • 100+5.75000
  • 800+4.02500
  • 3000+2.87500
  • 6000+2.73120
  • 30000+2.53000
IP4220CZ6,125
    IP4220CZ6,125
    • 5+1.05728
    • 20+0.99008
    • 100+0.92288
    • 500+0.85568
    • 1000+0.82432
    • 2000+0.80192
