PDZ15B,115
PDZ15B,115
    NEXPERIA(安世)
    SOD-323
    安世 SOD-323 0.9V 0.4W 5mA
PDZ15B,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET PDZ-B series Voltage regulator diodes Product data sheet Supersedes data of 2002 Feb 18 2004 Mar 22 NXP Semiconductors Product data sheet Voltage regulator diodes PDZ-B series FEATURES PINNING • Total power dissipation: max. 400 mW ;; PIN • Small plastic package suitable for surface mounted design 1 2 • Wide variety of voltage ranges: nominal 2.4 to 36 V (E24 range) • Tolerance approximately ±2%. handbook, halfpage • General voltage regulation. cathode anode 1 APPLICATIONS DESCRIPTION 2 Top view MAM387 The marking bar indicates the cathode. DESCRIPTION Fig.1 Low-power general purpose voltage regulator diodes in a small plastic SMD SOD323 (SC-76) package. Simplified outline (SOD323; SC-76) and symbol. MARKING TYPE NUMBER MARKING CODE TYPE NUMBER MARKING CODE TYPE NUMBER MARKING CODE TYPE NUMBER MARKING CODE PDZ2.4B Z0 PDZ5.1B Z8 PDZ11B ZG PDZ24B ZQ PDZ2.7B Z1 PDZ5.6B Z9 PDZ12B ZH PDZ27B ZR PDZ3.0B Z2 PDZ6.2B ZA PDZ13B ZJ PDZ30B ZS PDZ3.3B Z3 PDZ6.8B ZB PDZ15B ZK PDZ33B ZT PDZ3.6B Z4 PDZ7.5B ZC PDZ16B ZL PDZ36B ZU PDZ3.9B Z5 PDZ8.2B ZD PDZ18B ZM PDZ4.3B Z6 PDZ9.1B ZE PDZ20B ZN PDZ4.7B Z7 PDZ10B ZF PDZ22B ZP ORDERING INFORMATION TYPE NUMBER PDZ2.4B to PDZ36B 2004 Mar 22 PACKAGE NAME − DESCRIPTION plastic surface mounted package; 2 leads 2 VERSION SOD323 NXP Semiconductors Product data sheet Voltage regulator diodes PDZ-B series LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. − IF continuous forward current IZSM non-repetitive peak reverse current tp = 100 μs; square wave; Tamb = 25 °C prior to surge Ptot total power dissipation Tamb = 25 °C; note 1; see Fig.2 Tstg Tj UNIT 200 mA see Table 2 − 400 mW storage temperature −65 +150 °C junction temperature − 150 °C Note 1. Device mounted on a printed-circuit board measuring 11 × 25 × 1.6 mm. THERMAL CHARACTERISTICS SYMBOL PARAMETER CONDITIONS Rth(j-s) thermal resistance from junction to soldering point Rth(j-a) thermal resistance from junction to ambient note 1 Note 1. Device mounted on a printed-circuit board measuring 11 × 25 × 1.6 mm. 2004 Mar 22 3 VALUE UNIT 130 K/W 340 K/W NXP Semiconductors Product data sheet Voltage regulator diodes PDZ-B series CHARACTERISTICS Table 1 Total series Tj = 25 °C unless otherwise specified. SYMBOL PARAMETER VF forward voltage IR reverse current PDZ2.4B PDZ2.7B PDZ3.0B PDZ3.3B PDZ3.6B PDZ3.9B PDZ4.3B PDZ4.7B PDZ5.1B PDZ5.6B PDZ6.2B PDZ6.8B PDZ7.5B PDZ8.2B PDZ9.1B PDZ10B PDZ11B PDZ12B PDZ13B PDZ15B PDZ16B PDZ18B PDZ20B PDZ22B PDZ24B PDZ27B PDZ30B PDZ33B PDZ36B 2004 Mar 22 CONDITIONS 4 MAX. UNIT IF = 10 mA; see Fig.3 IF = 100 mA; see Fig.3 0.9 1.1 V V VR = 1 V VR = 1 V VR = 1 V VR = 1 V VR = 1 V VR = 1 V VR = 1 V VR = 1 V VR = 1.5 V VR = 2.5 V VR = 3 V VR = 3.5 V VR = 4 V VR = 5 V VR = 6 V VR = 7 V VR = 8 V VR = 9 V VR = 10 V VR = 11 V VR = 12 V VR = 13 V VR = 15 V VR = 17 V VR = 19 V VR = 21 V VR = 23 V VR = 25 V VR = 27 V 50 20 10 5 5 3 3 2 2 1 500 500 500 500 500 100 100 100 100 50 50 50 50 50 50 50 50 50 50 μA μA μA μA μA μA μA μA μA μA nA nA nA nA nA nA nA nA nA nA nA nA nA nA nA nA nA nA nA 5 TEMP. COEFF. SZ (mV/K) at IZ = 5 mA (see Figs 4 and 5) DIODE CAP. Cd (pF) at f = 1 MHz; VR = 0 NON-REPETITIVE PEAK REVERSE CURRENT IZSM (A) at tp = 100 μs; Tamb = 25 °C MAX. MAX. at IZ (mA) MAX. at IZ (mA) TYP. MAX. MAX. 2.43 2.69 2.85 3.32 3.60 3.89 4.17 4.55 4.96 5.48 6.06 6.65 7.28 8.02 8.85 9.77 10.78 11.74 12.91 14.34 15.85 17.56 19.52 21.54 23.72 26.19 29.19 32.15 35.07 2.63 2.91 3.07 3.53 3.85 4.16 4.48 4.75 5.20 5.73 6.33 6.93 7.60 8.36 9.23 10.21 11.22 12.24 13.49 14.98 16.51 18.35 20.39 22.47 24.78 27.53 30.69 33.79 36.87 1 000 1 000 1 000 1 000 500 500 600 600 250 100 80 60 60 60 60 60 60 80 80 80 80 80 100 100 120 150 200 250 300 0.5 0.5 0.5 0.5 1.0 1.0 1.0 1.0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 100 100 95 95 90 90 90 90 60 50 50 40 10 10 10 10 10 10 10 15 20 20 20 25 30 40 40 40 60 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 −1.6 −2.0 −2.1 −2.4 −2.4 −2.5 −2.5 −1.4 0.3 1.9 2.7 3.4 4.0 4.6 5.5 6.4 7.4 8.4 9.4 11.4 12.4 14.4 16.4 18.4 20.4 23.4 26.6 29.7 33.0 450 440 425 410 390 370 350 325 300 275 250 215 170 150 120 110 108 105 103 99 97 93 88 84 80 73 66 60 59 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 5.5 5.5 5.5 5.5 3.5 3.5 3.5 3.5 3.0 3.0 2.5 2.0 1.5 1.5 1.5 1.3 1.3 1.0 1.0 0.9 0.8 Product data sheet MIN. PDZ-B series PDZ2.4B PDZ2.7B PDZ3.0B PDZ3.3B PDZ3.6B PDZ3.9B PDZ4.3B PDZ4.7B PDZ5.1B PDZ5.6B PDZ6.2B PDZ6.8B PDZ7.5B PDZ8.2B PDZ9.1B PDZ10B PDZ11B PDZ12B PDZ13B PDZ15B PDZ16B PDZ18B PDZ20B PDZ22B PDZ24B PDZ27B PDZ30B PDZ33B PDZ36B DIFFERENTIAL RESISTANCE rdif (Ω) NXP Semiconductors TYPE NUMBER WORKING VOLTAGE VZ (V) at IZ = 5 mA Voltage regulator diodes 2004 Mar 22 Table 2 Per type Tj = 25 °C unless otherwise specified. NXP Semiconductors Product data sheet Voltage regulator diodes PDZ-B series GRAPHICAL DATA MBK245 500 MBG781 300 handbook, halfpage handbook, halfpage Ptot (mW) IF (mA) 400 200 300 200 100 100 0 0.6 0 0 50 100 150 200 Tamb (°C) 0.8 1 VF (V) Tj = 25 °C. Fig.3 Forward current as a function of forward voltage; typical values. Fig.2 Power derating curve. MGL273 MGL274 0 10 handbook, halfpage handbook, halfpage 12 SZ (mV/K) SZ (mV/K) 4.3 11 10 −1 9.1 5 3.9 8.2 7.5 6.8 3.6 −2 6.2 5.6 5.1 0 3.3 4.7 3.0 2.4 2.7 −3 0 20 40 IZ (mA) −5 60 0 4 PDZ2.4B to PDZ4.3B. Tj = 25 °C to 150 °C. PDZ4.7B to PDZ12B. Tj = 25 °C to 150 °C. Fig.4 Fig.5 Temperature coefficient as a function of working current; typical values. 2004 Mar 22 6 8 12 16 IZ (mA) 20 Temperature coefficient as a function of working current; typical values. NXP Semiconductors Product data sheet Voltage regulator diodes PDZ-B series PACKAGE OUTLINE Plastic surface-mounted package; 2 leads SOD323 A D E X v HD M A Q 1 2 bp A A1 (1) c Lp detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E HD Lp Q v mm 1.1 0.8 0.05 0.40 0.25 0.25 0.10 1.8 1.6 1.35 1.15 2.7 2.3 0.45 0.15 0.25 0.15 0.2 Note 1. The marking bar indicates the cathode OUTLINE VERSION SOD323 2004 Mar 22 REFERENCES IEC JEDEC JEITA SC-76 7 EUROPEAN PROJECTION ISSUE DATE 03-12-17 06-03-16 NXP Semiconductors Product data sheet Voltage regulator diodes PDZ-B series DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. DISCLAIMERS above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions 2004 Mar 22 8 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content, except for package outline drawings which were updated to the latest version. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands R76/05/pp9 Date of release: 2004 Mar 22 Document order number: 9397 750 12615
PDZ15B,115 价格&库存
很抱歉,暂时无法提供与“PDZ15B,115”相匹配的价格&库存,您可以联系我们找货
PDZ15B,115
    PDZ15B,115
      • 1+0.62161
      • 10+0.60481
      • 100+0.55441
      • 500+0.54433
      PDZ15B,115
      • 20+4.82060
      • 100+2.87500
      • 800+2.01230
      • 3000+1.43750
      • 6000+1.36550
      • 30000+1.26440
