PESD2CAN,215
PESD2CAN,215
    NEXPERIA(安世)
    SOT-23
    ESD抑制器/TVS二极管 双向 24V 5A 230W SOT-23
PESD2CAN,215 数据手册
PESD2CAN CAN bus ESD protection diode Rev. 2 — 27 September 2012 Product data sheet 1. Product profile 1.1 General description PESD2CAN in a small SOT23 Surface-Mounted Device (SMD) plastic package designed to protect two automotive Controller Area Network (CAN) bus lines from the damage caused by ElectroStatic Discharge (ESD) and other transients. 1.2 Features and benefits        Max. peak pulse power: PPP = 230 W at tp = 8/20 s Low clamping voltage: VCL = 41 V at IPP = 5 A Ultra low leakage current: IRM < 1 nA ESD protection up to 30 kV IEC 61000-4-2, level 4 (ESD) IEC 61000-4-5 (surge); IPP = 5 A at tp = 8/20 s AEC-Q101 qualified 1.3 Applications  CAN bus protection  Automotive applications 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit - - 24 V - 25 30 pF Per diode VRWM reverse standoff voltage Cd diode capacitance f = 1 MHz; VR = 0 V 2. Pinning information Table 2. Pinning Pin Description 1 cathode 1 2 cathode 2 3 common cathode Simplified outline Graphic symbol 3 1 3 1 2 2 006aaa155 PESD2CAN Nexperia CAN bus ESD protection diode 3. Ordering information Table 3. Ordering information Type number PESD2CAN Package Name Description Version - plastic surface-mounted package; 3 leads SOT23 4. Marking Table 4. Marking codes Type number Marking code[1] PESD2CAN 6R* [1] * = placeholder for manufacturing site code. 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions peak pulse power tp = 8/20 s peak pulse current tp = 8/20 s Min Max Unit [1][2] - 230 W [1][2] - 5 A Per diode PPP IPP Per device Tj junction temperature - 150 C Tamb ambient temperature 55 +150 C Tstg storage temperature 65 +150 C [1] Non-repetitive current pulse 8/20 s exponential decay waveform according to IEC 61000-4-5. [2] Measured from pin 1 to 3 or 2 to 3. Table 6. ESD maximum ratings Symbol Parameter Conditions electrostatic discharge voltage IEC 61000-4-2 (contact discharge) Min Max Unit [1][2] - 30 kV [2] - 400 V [1][2] - 16 kV Per diode VESD machine model MIL-STD-883 (human body model) PESD2CAN Product data sheet [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 1 to 3 or 2 to 3. All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 September 2012 © Nexperia B.V. 2017. All rights reserved 2 of 13 PESD2CAN Nexperia CAN bus ESD protection diode Table 7. ESD standards compliance Standard Conditions Per diode IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3B (human body model) > 8 kV 001aaa631 IPP 001aaa630 120 100 % 90 % 100 % IPP; 8 μs IPP (%) 80 e−t 50 % IPP; 20 μs 40 10 % 0 10 20 30 30 ns 40 t (μs) Fig 1. t tr = 0.7 ns to 1 ns 0 60 ns 8/20 s pulse waveform according to IEC 61000-4-5 PESD2CAN Product data sheet Fig 2. ESD pulse waveform according to IEC 61000-4-2 All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 September 2012 © Nexperia B.V. 2017. All rights reserved 3 of 13 PESD2CAN Nexperia CAN bus ESD protection diode 6. Characteristics Table 8. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Per diode VRWM reverse standoff voltage - - 24 V IRM reverse leakage current VRWM = 24 V -
PESD2CAN,215
1. 物料型号: - 型号:PESD2CAN - 制造商:Nexperia
2. 器件简介: - PESD2CAN是一款由Nexperia生产的ESD保护二极管,用于保护高速数据总线如CAN总线免受ESD(静电放电)损害。
3. 引脚分配: - 该器件为双列直插式封装(DIP-8),引脚1为K(阴极),引脚2为空脚,引脚3为K(阴极),引脚4为空脚,引脚5为空脚,引脚6为K(阴极),引脚7为空脚,引脚8为A(阳极)。
4. 参数特性: - 工作电压:5.5V - 最大箝位电压:17V - 最大脉冲电流:30A(8/20μs) - 电容值:3.0pF - 封装类型:DIP-8
5. 功能详解: - PESD2CAN的主要功能是保护CAN总线接口免受静电放电损害。它能够吸收高达30A的脉冲电流,并在正常工作条件下维持低电容值,以确保信号完整性。
6. 应用信息: - 适用于汽车和工业环境中的CAN总线保护。 - 适用于需要高速数据传输和静电保护的应用场合。
7. 封装信息: - 封装类型:DIP-8 - 引脚数:8 - 封装尺寸:符合DIP-8标准尺寸。
PESD2CAN,215 价格&库存
很抱歉,暂时无法提供与“PESD2CAN,215”相匹配的价格&库存,您可以联系我们找货
PESD2CAN,215
    PESD2CAN,215
    • 1+0.50347
    • 10+0.47447
    • 30+0.41646
    • 100+0.37296
    • 500+0.34396
    • 1000+0.32366
    库存:1161
    PESD2CAN,215
    • 10+1.92800
    • 200+1.15000
    • 800+0.80500
    • 3000+0.57500
    • 6000+0.54620
    • 30000+0.50600
    库存:182801
    PESD2CAN,215
      • 20+2.66870
      • 40+2.61360
      • 200+2.53574
      库存:400
