PESD5V0L2UU,115
PESD5V0L2UU,115
    NEXPERIA(安世)
    SOT-323
    ESD抑制器/TVS二极管 单向 5V 5.5A 70W SOT-323
PESD5V0L2UU,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PESD5V0L2UU; PESD6V0L2UU Low capacitance unidirectional ESD protection diodes Rev. 01 — 11 March 2009 Product data sheet 1. Product profile 1.1 General description Low capacitance unidirectional double ElectroStatic Discharge (ESD) protection diodes in a very small Surface-Mounted Device (SMD) plastic package designed to protect up to two signal lines from the damage caused by ESD and other transients. Table 1. Product overview Type number PESD5V0L2UU Package Package configuration NXP JEITA SOT323 SC-70 very small PESD6V0L2UU 1.2 Features n Unidirectional ESD protection of up to two lines n Low diode capacitance: Cd = 34 pF n Max. peak pulse power: PPP = 70 W n Low clamping voltage: VCL = 13 V n Ultra low leakage current n ESD protection up to 30 kV n IEC 61000-4-2; level 4 (ESD) n IEC 61000-4-5 (surge); IPP = 6.5 A n AEC-Q101 qualified 1.3 Applications n Audio and video equipment n Computers and peripherals n Cellular handsets and accessories n Communication systems n Portable electronics n Subscriber Identity Module (SIM) card protection 1.4 Quick reference data Table 2. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter VRWM reverse standoff voltage Conditions Min Typ Max Unit PESD5V0L2UU - - 5.0 V PESD6V0L2UU - - 6.0 V PESD5V0L2UU; PESD6V0L2UU NXP Semiconductors Low capacitance unidirectional ESD protection diodes Table 2. Quick reference data …continued Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Cd diode capacitance f = 1 MHz; VR = 0 V PESD5V0L2UU PESD6V0L2UU Min Typ Max Unit [1] - 19 23 pF [2] - 38 46 pF [1] - 17 20 pF [2] - 34 40 pF [1] Bidirectional configuration: measured from pin 1 to 2 or pin 2 to 1. [2] Unidirectional configuration: measured from pin 1 to 3 or pin 2 to 3. 2. Pinning information Table 3. Pinning Pin Description 1 cathode (diode 1) 2 cathode (diode 2) 3 common anode Simplified outline Graphic symbol 3 1 3 2 1 2 006aaa154 3. Ordering information Table 4. Ordering information Type number PESD5V0L2UU Package Name Description Version SC-70 plastic surface-mounted package; 3 leads SOT323 PESD6V0L2UU 4. Marking Table 5. Marking codes Type number Marking code[1] PESD5V0L2UU H1* PESD6V0L2UU H2* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 2 of 13 PESD5V0L2UU; PESD6V0L2UU NXP Semiconductors Low capacitance unidirectional ESD protection diodes 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit peak pulse power tp = 8/20 µs - 70 W - 60 W PESD5V0L2UU - 6.5 A PESD6V0L2UU - 5.5 A Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C Per diode PPP [1][2] PESD5V0L2UU PESD6V0L2UU peak pulse current IPP tp = 8/20 µs [1][2] [1] Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5. [2] Measured from pin 1 or 2 to pin 3. Table 7. ESD maximum ratings Tamb = 25 °C unless otherwise specified. Symbol VESD Parameter Conditions electrostatic discharge voltage Min Max Unit IEC 61000-4-2 (contact discharge) [1] - 30 kV MIL-STD-883 (human body model) [2] - 16 kV [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 1 or 2 to pin 3. Table 8. ESD standards compliance Standard Conditions IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3 (human body model) > 4 kV PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 3 of 13 PESD5V0L2UU; PESD6V0L2UU NXP Semiconductors Low capacitance unidirectional ESD protection diodes 001aaa631 IPP 001aaa630 120 100 % 90 % 100 % IPP; 8 µs IPP (%) 80 e−t 50 % IPP; 20 µs 40 10 % 0 10 20 30 30 ns 40 t (µs) Fig 1. t tr = 0.7 ns to 1 ns 0 8/20 µs pulse waveform according to IEC 61000-4-5 60 ns Fig 2. ESD pulse waveform according to IEC 61000-4-2 PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 4 of 13 NXP Semiconductors PESD5V0L2UU; PESD6V0L2UU Low capacitance unidirectional ESD protection diodes 6. Characteristics Table 9. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter VRWM reverse standoff voltage IRM VBR Cd Conditions Min Typ Max Unit PESD5V0L2UU - - 5.0 V PESD6V0L2UU - - 6.0 V reverse leakage current PESD5V0L2UU VRWM = 4.0 V - 20 90 nA PESD6V0L2UU VRWM = 4.3 V - 1.5 18 nA PESD5V0L2UU VRWM = 5.0 V - 430 - nA PESD6V0L2UU VRWM = 6.0 V - 310 - nA PESD5V0L2UU 5.8 6.2 6.6 V PESD6V0L2UU 6.4 6.8 7.2 V [1] - 19 23 pF [2] - 38 46 pF [1] - 17 20 pF [2] - 34 40 pF PESD5V0L2UU - - 13 V PESD6V0L2UU - - 13.5 V PESD5V0L2UU - - 25 Ω PESD6V0L2UU - - 30 Ω breakdown voltage diode capacitance IR = 5 mA f = 1 MHz; VR = 0 V PESD5V0L2UU PESD6V0L2UU VCL rdif clamping voltage differential resistance IPP = 5.5 A IR = 5 mA [1] Bidirectional configuration: measured from pin 1 to 2 or pin 2 to 1. [2] Unidirectional configuration: measured from pin 1 to 3 or pin 2 to 3. [3] Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5. [4] Measured from pin 1 or 2 to pin 3. PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet [3][4] © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 5 of 13 PESD5V0L2UU; PESD6V0L2UU NXP Semiconductors Low capacitance unidirectional ESD protection diodes 006aab435 40 006aab436 40 Cd (pF) Cd (pF) 30 30 (1) (1) 20 20 (2) (2) 10 10 0 0 0 2 4 6 0 2 4 6 VR (V) VR (V) f = 1 MHz; Tamb = 25 °C f = 1 MHz; Tamb = 25 °C (1) unidirectional (1) unidirectional (2) bidirectional (2) bidirectional Fig 3. PESD5V0L2UU: Diode capacitance as a function of reverse voltage; typical values Fig 4. PESD6V0L2UU: Diode capacitance as a function of reverse voltage; typical values I IPP −VCL −VBR −VRWM V −IRM −IR − −VCL −VBR −VRWM IR IRM −IRM −IR VRWM VBR VCL + P-N − −IPP + −IPP 006aaa676 006aaa407 Fig 5. V-I characteristics for a unidirectional ESD protection diode Fig 6. V-I characteristics for a bidirectional ESD protection diode PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 6 of 13 PESD5V0L2UU; PESD6V0L2UU NXP Semiconductors Low capacitance unidirectional ESD protection diodes ESD TESTER 450 Ω RZ RG 223/U 50 Ω coax 4 GHz DIGITAL OSCILLOSCOPE 10× ATTENUATOR 50 Ω CZ IEC 61000-4-2 network CZ = 150 pF; RZ = 330 Ω DUT (DEVICE UNDER TEST) vertical scale = 10 A/div horizontal scale = 15 ns/div vertical scale = 20 V/div horizontal scale = 50 ns/div GND GND unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) clamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) vertical scale = 10 A/div horizontal scale = 15 ns/div vertical scale = 20 V/div horizontal scale = 50 ns/div GND GND unclamped −8 kV ESD pulse waveform (IEC 61000-4-2 network) Fig 7. clamped −8 kV ESD pulse waveform (IEC 61000-4-2 network) 006aab437 PESD5V0L2UU: ESD clamping test setup and waveforms PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 7 of 13 PESD5V0L2UU; PESD6V0L2UU NXP Semiconductors Low capacitance unidirectional ESD protection diodes 7. Application information PESD5V0L2UU and PESD6V0L2UU are designed for the protection of up to two unidirectional data or signal lines, or for the protection of one bidirectional data or signal line, from the damage caused by ESD. For unidirectional protection, the devices may be used on lines where the signal polarities are positive with respect to ground, and for bidirectional protection, the devices may be used on lines where the signal polarities are both, positive and negative with respect to ground. For an 8/20 µs waveform, the PESD5V0L2UU provides a surge capability of up to 70 W per line, and the PESD6V0L2UU provides a surge capability of up to 60 W per line. line 1 to be protected line 1 to be protected line 2 to be protected DUT GND bidirectional protection of one line DUT GND unidirectional protection of two lines 006aab252 Fig 8. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD and Electrical Fast Transient (EFT). The following guidelines are recommended: 1. Place the devices as close to the input terminal or connector as possible. 2. The path length between the device and the protected line should be minimized. 3. Keep parallel signal paths to a minimum. 4. Avoid running protected conductors in parallel with unprotected conductors. 5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. 6. Minimize the length of the transient return path to ground. 7. Avoid using shared transient return paths to a common ground point. 8. Ground planes should be used whenever possible. For multilayer PCBs, use ground vias. PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 8 of 13 PESD5V0L2UU; PESD6V0L2UU NXP Semiconductors Low capacitance unidirectional ESD protection diodes 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 2.2 1.8 1.1 0.8 0.45 0.15 3 2.2 1.35 2.0 1.15 1 2 0.4 0.3 0.25 0.10 1.3 Dimensions in mm Fig 9. 04-11-04 Package outline SOT323 (SC-70) 10. Packing information Table 10. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PESD5V0L2UU Package SOT323 Description 4 mm pitch, 8 mm tape and reel Packing quantity 3000 10000 -115 -135 PESD6V0L2UU [1] For further information and the availability of packing methods, see Section 14. PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 9 of 13 PESD5V0L2UU; PESD6V0L2UU NXP Semiconductors Low capacitance unidirectional ESD protection diodes 11. Soldering 2.65 1.85 1.325 solder lands solder resist 2 2.35 0.6 (3×) 3 solder paste 1.3 1 occupied area 0.5 (3×) Dimensions in mm 0.55 (3×) sot323_fr Fig 10. Reflow soldering footprint SOT323 (SC-70) 4.6 2.575 1.425 (3×) solder lands solder resist occupied area 1.8 3.65 2.1 09 (2×) Dimensions in mm preferred transport direction during soldering sot323_fw Fig 11. Wave soldering footprint SOT323 (SC-70) PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 10 of 13 PESD5V0L2UU; PESD6V0L2UU NXP Semiconductors Low capacitance unidirectional ESD protection diodes 12. Revision history Table 11. Revision history Document ID Release date PESD5V0L2UU_PESD6V0L2UU_1 20090311 Data sheet status Change notice Supersedes Product data sheet - - PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 11 of 13 NXP Semiconductors PESD5V0L2UU; PESD6V0L2UU Low capacitance unidirectional ESD protection diodes 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. ESD protection devices — These products are only intended for protection against ElectroStatic Discharge (ESD) pulses and are not intended for any other usage including, without limitation, voltage regulation applications. NXP Semiconductors accepts no liability for use in such applications and therefore such use is at the customer’s own risk. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PESD5V0L2UU_PESD6V0L2UU_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 March 2009 12 of 13 NXP Semiconductors PESD5V0L2UU; PESD6V0L2UU Low capacitance unidirectional ESD protection diodes 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Application information. . . . . . . . . . . . . . . . . . . 8 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Quality information . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Packing information. . . . . . . . . . . . . . . . . . . . . . 9 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 11 March 2009 Document identifier: PESD5V0L2UU_PESD6V0L2UU_1
PESD5V0L2UU,115 价格&库存
很抱歉,暂时无法提供与“PESD5V0L2UU,115”相匹配的价格&库存,您可以联系我们找货
PESD5V0L2UU,115
  • 5+0.59400
  • 20+0.55350
  • 100+0.51300
  • 500+0.47250
  • 1000+0.45360
  • 2000+0.44010
PESD5V0L2UU,115
  • 1+2.060471+0.26781
  • 10+1.9300610+0.25086
  • 25+1.7996525+0.23391
  • 100+1.46059100+0.18984
  • 250+1.19107250+0.15481
  • 500+0.96503500+0.12543
  • 1000+0.773761000+0.10057
  • 3000+0.730293000+0.09492
PESD5V0L2UU,115
