PMEG3002TV,115
PMEG3002TV,115
    NEXPERIA(安世)
    SOT666
    直流反向耐压(Vr):30V 平均整流电流(Io):200mA 正向压降(Vf):480mV@200mA
PMEG3002TV,115 数据手册
PMEG3002TV 0.2 A very low VF MEGA Schottky barrier dual rectifier in SOT666 package Rev. 02 — 15 January 2010 Product data sheet 1. Product profile 1.1 General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier dual rectifier with an integrated guard ring for stress protection, encapsulated in a SOT666 ultra small and flat lead Surface Mounted Device (SMD) plastic package. Table 1. Product overview Type number Package Configuration Nexperia JEITA PMEG3002TV SOT666 - dual isolated 1.2 Features „ „ „ „ Forward current: ≤ 0.2 A Reverse voltage: ≤ 30 V Very low forward voltage Ultra small and flat lead SMD plastic package 1.3 Applications „ „ „ „ „ Low voltage rectification High efficiency DC-to-DC conversion Switch mode power supply Inverse polarity protection Low power consumption applications 1.4 Quick reference data Table 2. Symbol Quick reference data Parameter Conditions IF forward current Tamb ≤ 25 °C [1] VR reverse voltage VF forward voltage IF = 200 mA [2] Min Typ Max Unit - - 0.2 A - - 30 V - 420 480 mV Per diode [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. PMEG3002TV Nexperia 0.2 A very low VF MEGA Schottky barrier dual rectifier 2. Pinning information Table 3. Pinning Pin Description 1 anode (diode 1) 2 not connected 3 cathode (diode 2) 4 anode (diode 2) 5 not connected 6 Simplified outline cathode (diode 1) 6 5 4 1 2 3 Symbol 6 5 4 1 2 3 006aaa440 3. Ordering information Table 4. Ordering information Type number PMEG3002TV Package Name Description Version - plastic surface mounted package; 6 leads SOT666 4. Marking Table 5. Marking codes Type number Marking code PMEG3002TV 2M PMEG3002TV_2 Product data sheet Rev. 02 — 15 January 2010 2 of 10 © Nexperia B.V. 2017. All rights reserved PMEG3002TV Nexperia 0.2 A very low VF MEGA Schottky barrier dual rectifier 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit - 30 V - 0.2 A Per diode VR reverse voltage IF forward current IFRM repetitive peak forward current tp ≤ 1 ms; δ ≤ 0.25 Tamb ≤ 25 °C [1] - 1 A - 2.5 A IFSM non-repetitive peak forward current square wave; tp = 8 ms [1] Ptot total power dissipation Tamb ≤ 25 °C [1] - 200 mW [2] - 300 mW [1] - 300 mW [2] - 400 mW Per device total power dissipation Ptot Tamb ≤ 25 °C Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions thermal resistance from junction to ambient in free air Min Typ Max Unit [1][2] - - 416 K/W [1][3] - - 318 K/W [4] - - 195 K/W Per device Rth(j-a) Rth(j-sp) thermal resistance from junction to solder point [1] For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. Nomograms for determining the reverse power losses PR and IF(AV) rating are available on request. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [4] Soldering point of cathode tab. PMEG3002TV_2 Product data sheet Rev. 02 — 15 January 2010 3 of 10 © Nexperia B.V. 2017. All rights reserved PMEG3002TV Nexperia 0.2 A very low VF MEGA Schottky barrier dual rectifier 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit IF = 0.1 mA - 130 190 mV IF = 1 mA - 190 250 mV IF = 10 mA - 255 300 mV IF = 100 mA - 355 400 mV IF = 200 mA - 420 480 mV VR = 10 V - 3 10 μA Per diode VF IR Cd [1] [1] forward voltage reverse current diode capacitance VR = 30 V - 10 30 μA VR = 10 V; Tamb = 100 °C - 400 - μA VR = 1 V; f = 1 MHz - 20 25 pF Pulse test: tp ≤ 300 μs; δ ≤ 0.02. PMEG3002TV_2 Product data sheet Rev. 02 — 15 January 2010 4 of 10 © Nexperia B.V. 2017. All rights reserved PMEG3002TV Nexperia 0.2 A very low VF MEGA Schottky barrier dual rectifier 006aaa660 103 IR (μA) IF (mA) 102 006aaa661 104 (1) 103 (2) 102 (3) (1) 10 (2) 10 (4) 1 10−1 (3) (4) (5) 10−2 1 (5) 10−3 10−1 10−4 0 0.2 0.4 0.6 0 5 10 15 20 25 VF (V) (1) Tamb = 125 °C (1) Tamb = 125 °C (2) Tamb = 100 °C (2) Tamb = 100 °C (3) Tamb = 85 °C (3) Tamb = 85 °C (4) Tamb = 25 °C (4) Tamb = 25 °C (5) Tamb = −40 °C (5) Tamb = −40 °C Fig 1. Forward current as a function of forward voltage; typical values Fig 2. 30 VR (V) Reverse current as a function of reverse voltage; typical values 001aaa353 40 Cd (pF) 30 20 10 0 0 10 20 30 VR (V) Tamb = 25 °C; f = 1 MHz Fig 3. Diode capacitance as a function of reverse voltage; typical values PMEG3002TV_2 Product data sheet Rev. 02 — 15 January 2010 5 of 10 © Nexperia B.V. 2017. All rights reserved PMEG3002TV Nexperia 0.2 A very low VF MEGA Schottky barrier dual rectifier 8. Package outline 1.7 1.5 6 0.6 0.5 5 4 0.3 0.1 1.7 1.5 1.3 1.1 pin 1 index 1 2 3 0.18 0.08 0.27 0.17 0.5 1 Dimensions in mm Fig 4. 04-11-08 Package outline SOT666 9. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package PMEG3002TV SOT666 [1] Description Packing quantity 4000 8000 2 mm pitch, 8 mm tape and reel - -315 4 mm pitch, 8 mm tape and reel -115 - For further information and the availability of packing methods, see Section 13. PMEG3002TV_2 Product data sheet Rev. 02 — 15 January 2010 6 of 10 © Nexperia B.V. 2017. All rights reserved PMEG3002TV Nexperia 0.2 A very low VF MEGA Schottky barrier dual rectifier 10. Soldering 2.75 2.45 2.10 1.60 0.15 (4x) solder lands 0.40 (6x) 0.075 solder resist 0.55 2.00 1.70 1.00 (2x) 0.30 (2x) placement area 0.375 (4x) occupied area 1.20 2.20 2.50 mgx367 Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 5. Reflow soldering footprint SOT666 PMEG3002TV_2 Product data sheet Rev. 02 — 15 January 2010 7 of 10 © Nexperia B.V. 2017. All rights reserved PMEG3002TV Nexperia 0.2 A very low VF MEGA Schottky barrier dual rectifier 11. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PMEG3002TV_2 20100115 Product data sheet - PMEG3002TV_1 Modifications: PMEG3002TV_1 • This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content. 20051021 Product data sheet - - PMEG3002TV_2 Product data sheet Rev. 02 — 15 January 2010 8 of 10 © Nexperia B.V. 2017. All rights reserved PMEG3002TV Nexperia 0.2 A very low VF MEGA Schottky barrier dual rectifier 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 12.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PMEG3002TV_2 Product data sheet Rev. 02 — 15 January 2010 9 of 10 © Nexperia B.V. 2017. All rights reserved Nexperia PMEG3002TV 0.2 A very low VF MEGA Schottky barrier dual rectifier 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6 Packing information . . . . . . . . . . . . . . . . . . . . . 6 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Contact information. . . . . . . . . . . . . . . . . . . . . . 9 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 January 2010
PMEG3002TV,115
物料型号:PMEG3002TV
器件简介: - PMEG3002TV是一款具有极低正向电压的MEGA Schottky势垒二极管,封装在SOT666超小型和扁平的表面贴装设备(SMD)塑料封装中。它具有集成的防护环,用于应力保护。
引脚分配: - 引脚1:二极管1的阳极 - 引脚2:未连接 - 引脚3:二极管2的阴极 - 引脚4:二极管2的阳极 - 引脚5:未连接 - 引脚6:二极管1的阴极
参数特性: - 正向电流:≤ 0.2 A - 反向电压:≤ 30 V - 正向电压:在200mA电流下,典型值为420mV至480mV
功能详解: - 低电压整流 - 高效率DC-DC转换 - 开关电源 - 反极性保护 - 低功耗应用
应用信息: - 适用于低电压整流、高效率DC-DC转换、开关电源、反极性保护以及低功耗应用。
封装信息: - 封装类型:SOT666 - 封装描述:塑料表面贴装封装;6个引脚
PMEG3002TV,115 价格&库存
很抱歉,暂时无法提供与“PMEG3002TV,115”相匹配的价格&库存,您可以联系我们找货
PMEG3002TV,115
  • 1+4.939311+0.64196
  • 10+3.0436010+0.39558
  • 50+2.2089350+0.28710
  • 100+1.93551100+0.25156
  • 500+1.45421500+0.18901
库存:9377
PMEG3002TV,115
  • 5+0.72583
  • 20+0.66290
  • 100+0.59996
  • 500+0.53703
  • 1000+0.50766
  • 2000+0.48668
PMEG3002TV,115
  • 1+6.528051+0.84845
  • 10+3.9878710+0.51831
  • 100+2.56101100+0.33286
  • 500+1.86656500+0.24260
  • 1000+1.712241000+0.22254
  • 2000+1.147652000+0.14916
  • 4000+0.918684000+0.11940
  • 8000+0.861438000+0.11196
库存:6000
