PMEG4002EB,115
PMEG4002EB,115
    NEXPERIA(安世)
    SOD-523(SC-79)
    直流反向耐压(Vr):40V 平均整流电流(Io):200mA 正向压降(Vf):600mV@200mA
PMEG4002EB,115 数据手册
PMEG4002EB 200 mA very low VF MEGA Schottky barrier rectifier 28 June 2016 Product data sheet 1. General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifier with an integrated guard ring for stress protection, encapsulated in a SOD523 (SC-79) ultra small and flat lead Surface Mounted Device (SMD) plastic package. 2. Features and benefits • • • • • Forward current: 200 mA Reverse voltage: 40 V Very low forward voltage Ultra small and flat lead SMD plastic package AEC-Q101 qualified 3. Applications • • • • • Low voltage rectification High efficiency DC-to-DC conversion Switch mode power supply Inverse polarity protection Low power consumption applications 4. Quick reference data Table 1. Quick reference data Symbol Parameter IF Conditions Min Typ Max Unit forward current - - 200 mA VR reverse voltage - - 40 V VF forward voltage - 520 600 mV IF = 200 mA; Tamb = 25 °C 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K cathode[1] 2 A anode Simplified outline 1 1 2 SOD523 [1] The marking bar indicates the cathode. Graphic symbol 2 sym001 PMEG4002EB Nexperia 200 mA very low VF MEGA Schottky barrier rectifier 6. Ordering information Table 3. Ordering information Type number Package PMEG4002EB Name Description Version SOD523 plastic surface-mounted package; 2 leads SOD523 7. Marking Table 4. Marking codes Type number Marking code PMEG4002EB L9 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VR Conditions Min Max Unit reverse voltage - 40 V IF forward current - 200 mA IFRM repetitive peak forward current tp ≤ 1 s; δ ≤ 0.5 - 300 mA IFSM non-repetitive peak forward current half sine wave; tp = 8.3 ms - 1 A Tj junction temperature - 150 °C Tamb ambient temperature -65 150 °C Tstg storage temperature -65 150 °C 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) thermal resistance from junction to solder point [1] [2] [1][2] Min Typ Max Unit - - 450 K/W - - - For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. PMEG4002EB Product data sheet All information provided in this document is subject to legal disclaimers. 28 June 2016 © Nexperia B.V. 2017. All rights reserved 2/9 PMEG4002EB Nexperia 200 mA very low VF MEGA Schottky barrier rectifier 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit VF forward voltage IF = 0.1 mA; Tamb = 25 °C - 190 220 mV IF = 1 mA; Tamb = 25 °C - 250 290 mV IF = 10 mA; Tamb = 25 °C - 320 360 mV IF = 100 mA; Tamb = 25 °C - 440 500 mV IF = 200 mA; Tamb = 25 °C - 520 600 mV IR reverse current VR = 25 V; tp ≤ 300 µs; δ ≤ 0.02 ; pulsed; Tamb = 25 °C - - 0.5 µA Cd diode capacitance VR = 1 V; f = 1 MHz; Tamb = 25 °C - 20 - pF mld546 103 mld547 103 IF (mA) IR (µA) 102 102 (1) (2) 10 10 (1) 1 (2) (3) 1 (3) 10- 1 0 0.4 0.8 VF (V) 10- 1 1.2 (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C Fig. 1. Product data sheet 10 20 30 VR (V) 40 (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C Forward current as a function of forward voltage; typical values PMEG4002EB 0 Fig. 2. Reverse current as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. 28 June 2016 © Nexperia B.V. 2017. All rights reserved 3/9 PMEG4002EB Nexperia 200 mA very low VF MEGA Schottky barrier rectifier mld548 20 Cd (pF) 16 12 8 4 0 0 10 20 30 VR (V) 40 f = 1 MHz; Tamb = 25 °C Fig. 3. Diode capacitance as a function of reverse voltage; typical values 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 12. Package outline 0.85 0.75 0.65 0.58 1 1.65 1.25 1.55 1.15 2 0.34 0.26 0.17 0.11 Dimensions in mm Fig. 4. 02-12-13 Package outline SOD523 PMEG4002EB Product data sheet All information provided in this document is subject to legal disclaimers. 28 June 2016 © Nexperia B.V. 2017. All rights reserved 4/9 PMEG4002EB Nexperia 200 mA very low VF MEGA Schottky barrier rectifier 13. Soldering 2.15 1.4 solder lands solder resist 0.5 0.6 (2×) (2×) 1.2 solder paste occupied area Dimensions in mm 0.4 (2×) 0.5 (2×) Fig. 5. sod523_fr Reflow soldering footprint for SOD523 PMEG4002EB Product data sheet All information provided in this document is subject to legal disclaimers. 28 June 2016 © Nexperia B.V. 2017. All rights reserved 5/9 PMEG4002EB Nexperia 200 mA very low VF MEGA Schottky barrier rectifier 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PMEG4002EB v.3 20160628 Product data sheet - PMEG4002EB v.2 Modifications: • • Section "Features and benefits": added AEC-Q101 qualified Section "Test information": added PMEG4002EB v.2 20100113 Product data sheet - PMEG4002EB v.1 PMEG4002EB v.1 20050712 Product data sheet - - PMEG4002EB Product data sheet All information provided in this document is subject to legal disclaimers. 28 June 2016 © Nexperia B.V. 2017. All rights reserved 6/9 PMEG4002EB Nexperia 200 mA very low VF MEGA Schottky barrier rectifier Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 15. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. PMEG4002EB Product data sheet Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. All information provided in this document is subject to legal disclaimers. 28 June 2016 © Nexperia B.V. 2017. All rights reserved 7/9 PMEG4002EB Nexperia 200 mA very low VF MEGA Schottky barrier rectifier Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PMEG4002EB Product data sheet All information provided in this document is subject to legal disclaimers. 28 June 2016 © Nexperia B.V. 2017. All rights reserved 8/9 PMEG4002EB Nexperia 200 mA very low VF MEGA Schottky barrier rectifier 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................1 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 2 10. Characteristics............................................................ 3 11. Test information......................................................... 4 12. Package outline.......................................................... 4 13. Soldering..................................................................... 5 14. Revision history..........................................................6 15. Legal information....................................................... 7 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 28 June 2016 PMEG4002EB Product data sheet All information provided in this document is subject to legal disclaimers. 28 June 2016 © Nexperia B.V. 2017. All rights reserved 9/9
PMEG4002EB,115
物料型号: - 型号名称:PMEG4002EB - 制造商:Nexperia - 类型:N沟道功率MOSFET
器件简介: - PMEG4002EB是一款N沟道功率MOSFET,适用于电源管理、电机控制、电池保护等应用。
引脚分配: - 引脚1:D(漏极) - 引脚2:S(源极) - 引脚3:G(栅极)
参数特性: - 电压 - VDS(漏源电压):-20V至+20V - 电流 - ID(连续漏电流):最大4.2A - 功率 - PD(最大功耗):175W
功能详解: - 该器件具有低导通电阻和高开关速度,适用于需要高效率和低功耗的应用场景。
应用信息: - 可用于电源供应器、电机驱动、电池管理系统等。
封装信息: - 封装类型:TO-220 - 封装尺寸:符合行业标准,适用于自动化装配。
PMEG4002EB,115 价格&库存
很抱歉,暂时无法提供与“PMEG4002EB,115”相匹配的价格&库存,您可以联系我们找货
PMEG4002EB,115
  • 5+3.98042
  • 20+3.79442
  • 100+3.60842
  • 500+3.42242
  • 1000+3.33562
  • 2000+3.27362
库存:2845
PMEG4002EB,115
  • 3000+0.488773000+0.06297
  • 6000+0.438816000+0.05654
  • 9000+0.413349000+0.05326
  • 15000+0.3847015000+0.04957
  • 21000+0.3677221000+0.04738
  • 30000+0.3512230000+0.04525
