LLZ5221B - LLZ5263B
Taiwan Semiconductor
Small Signal Product
CREAT BY ART
Hermetically Sealed Glass Zener Voltage Regulators
FEATURES
- Zener voltage range 2.4 to 56 volts
- Ideal for automated placement
- Hermetically sealed glass
- Compression bonded construction
- All external surfaces are corrosion
resistant and leads are readily solderable
- RoHS compliant
- Matte Tin (Sn) lead finish
MINI MELF
- Blue color band indicates negative polarity
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
PARAMETER
Power Dissipation
Forward Voltage
Storage Temperature Range
Document Number: DS_S1408020
IF = 200 mA
SYMBOL
VALUE
UNIT
PD
500
mW
VF
1.1
TJ, TSTG
- 65 to +200
V
o
C
Version: C15
LLZ5221B - LLZ5263B
ELECTRICAL CHARACTERISTICS ( TA= 25oC unless otherwise noted )
Device
Vz @ Izt
(Volts)
Nom
IZT
(mA)
ZZT @ IZT
(Ω)
Max.
ZZK @ IZK
=0.25mA
(Ω)
Max.
IR @ VR
(μA)
Max.
VR
(Volts)
LLZ5221B
2.4
1200
100
1.0
LLZ5222B
2.5
1250
100
1.0
LLZ5223B
2.7
1300
75
1.0
LLZ5224B
2.8
1400
75
1.0
LLZ5225B
3.0
1600
50
1.0
LLZ5226B
3.3
1600
25
1.0
LLZ5227B
3.6
1700
15
1.0
LLZ5228B
3.9
1900
10
1.0
LLZ5229B
4.3
2000
5.0
1.0
LLZ5230B
4.7
1900
5.0
2.0
LLZ5231B
5.1
1600
5.0
2.0
LLZ5232B
5.6
1600
5.0
3.0
LLZ5233B
6.0
16900
5.0
3.5
LLZ5234B
LLZ5235B
6.2
6.8
5
1000
750
5.0
3.0
4.0
5.0
LLZ5236B
7.5
500
3.0
6.0
LLZ5237B
8.2
500
3.0
6.5
LLZ5238B
8.7
600
3.0
6.5
LLZ5239B
9.1
600
2.0
7.0
LLZ5240B
10
600
1.0
8.0
LLZ5241B
11
600
0.5
8.4
LLZ5242B
12
600
0.1
9.1
LLZ5243B
13
9.5
13
600
0.1
9.9
LLZ5244B
14
9.0
15
600
0.1
10
LLZ5245B
15
8.5
16
600
0.1
11
LLZ5246B
16
7.8
17
600
0.1
12
LLZ5247B
16
7.4
19
600
0.1
13
LLZ5248B
18
7.0
21
600
0.1
14
LLZ5249B
19
6.6
23
600
0.1
14
LLZ5250B
25
600
0.1
15
LLZ5251B
22
5.6
29
600
0.1
17
LLZ5252B
24
5.2
33
600
0.1
18
LLZ5253B
25
5.0
35
600
0.1
19
LLZ5254B
27
5.0
41
600
0.1
21
LLZ5255B
28
4.5
44
600
0.1
21
LLZ5256B
30
4.2
49
600
0.1
23
LLZ5257B
33
3.8
58
700
0.1
25
LLZ5258B
36
3.4
70
700
0.1
27
LLZ5259B
39
3.2
80
800
0.1
30
LLZ5260B
43
3.0
93
900
0.1
33
LLZ5261B
47
2.7
105
1000
0.1
36
LLZ5262B
51
2.5
125
1100
0.1
39
LLZ5263B
56
2.2
150
1300
0.1
Notes : 1. The type numbers listed have zener voltage as shown and have a standard tolerance on the nominal zener voltage
43
of ±5% in Blue marking, suffix A=±10% in Orange marking and D=±1% in Yellow marking.
2. For detailed information on price, availability and deliver of nominal zener voltages between the voltages shown
and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative.
3. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an RMS
value equal to 10% of the dc zener current (IZT or IZK) is superimposed to IZT or IZK.
Version: C15
LLZ5221B - LLZ5263B
ORDER INFORMATION (EXAMPLE)
LLZ5221B L0G
Green compound code
Packing code
Part no.
PACKAGE OUTLINE DIMENSION
C
DIM.
B
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
3.30
3.70
0.130
0.146
B
1.40
1.60
0.055
0.063
C
0.20
0.50
0.008
0.020
A
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
A
1.25
0.049
B
2.00
0.079
C
2.50
0.098
D
5.00
0.197
DIM.
Version: C15
LLZ5221B - LLZ5263B
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied,to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or seling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: C15
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Taiwan Semiconductor:
LLZ5221B LLZ5222B LLZ5223B LLZ5224B LLZ5225B LLZ5226B LLZ5227B LLZ5228B LLZ5229B LLZ5230B
LLZ5231B LLZ5232B LLZ5233B LLZ5234B LLZ5235B LLZ5236B LLZ5237B LLZ5238B LLZ5239B LLZ5240B
LLZ5241B LLZ5242B LLZ5243B LLZ5244B LLZ5245B LLZ5246B LLZ5247B LLZ5248B LLZ5249B LLZ5250B
LLZ5251B LLZ5252B LLZ5253B LLZ5254B LLZ5255B LLZ5256B LLZ5257B LLZ5258B LLZ5259B LLZ5260B
LLZ5261B LLZ5262B LLZ5263B LLZ5246B L1 LLZ5254B L0 LLZ5253B L1G LLZ5234B L1 LLZ5230B L1G
LLZ5249B L0G LLZ5246B L0 LLZ5239B L1 LLZ5253B L0G LLZ5236B L0G LLZ5228B L0 LLZ5226B L0G
LLZ5235B L0G LLZ5241B L1G LLZ5261B L1G LLZ5254B L1G LLZ5225B L0 LLZ5244B L1 LLZ5227B L0
LLZ5263B L0G LLZ5237B L1 LLZ5263B L1G LLZ5252B L1G LLZ5240B L0 LLZ5255B L0 LLZ5230B L1 LLZ5248B
L1G LLZ5233B L1G LLZ5238B L0G LLZ5259B L1G LLZ5251B L1G LLZ5221B L0G LLZ5234B L1G LLZ5227B
L0G LLZ5244B L0G LLZ5226B L1G LLZ5234B L0 LLZ5225B L0G LLZ5263B L0 LLZ5222B L1G LLZ5252B L0
LLZ5250B L0 LLZ5235B L0 LLZ5249B L0 LLZ5261B L0 LLZ5226B L0 LLZ5246B L0G LLZ5232B L0G LLZ5242B
L0 LLZ5255B L0G LLZ5230B L0G LLZ5238B L1G LLZ5235B L1G LLZ5237B L1G LLZ5240B L0G LLZ5223B L1G
LLZ5231B L1
很抱歉,暂时无法提供与“LLZ5231B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 20000+0.2615620000+0.03380
