S1GM RSG
S1GM RSG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMA(DO-214AC)
    VR=400V IF=1A 5pF Trr=780ns
S1GM RSG 数据手册
S1GM - S1JM Taiwan Semiconductor 1A, 400V - 600V Surface Mount Rectifier FEATURES KEY PARAMETERS ● ● ● ● ● ● AEC-Q101 qualified Ideal for automated placement Low forward voltage drop Glass passivated chip junction Moisture sensitivity level: level 1, per J-STD-020 Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF(AV) 1 A VRRM 400 - 600 V IFSM 20 A TJ MAX 175 °C Package Micro SMA APPLICATIONS ● ● ● ● Converter Free wheeling LED lighting Adapters MECHANICAL DATA ● ● ● ● ● ● Case: Micro SMA Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.006 g (approximately) Micro SMA ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Forward current Surge peak forward current, 8.3 ms single half sine-wave superimposed on rated load per diode SYMBOL VRRM IF(AV) S1GM S1JM A5 400 A7 600 UNIT 1 V A IFSM 20 A Junction temperature TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C 1 Version:G1805 S1GM - S1JM Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP. UNIT Junction-to-lead Thermal Resistance RӨJL 30 °C/W Junction-to-ambient thermal resistance RӨJA 110 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) Reverse current @ rated VR per diode Junction capacitance Reverse recovery time IF = 1A,TJ = 25°C (2) TJ = 25°C TJ = 125°C 1 MHz, VR=4.0V IF=0.5A ,IR=1.0A IRR=0.25A SYMBOL TYP. MAX. UNIT VF - 1.10 V - 1 µA - 50 µA CJ 5 - pF trr 780 - ns IR Notes: 1. Pulse test with PW=0.3 ms 2. Pulse test with PW=30 ms ORDERING INFORMATION PART NO. PACKAGE PACKING S1GMHRSG Micro SMA 3000 / 7" Plastic reel S1JMHRSG Micro SMA 3000 / 7" Plastic reel 2 Version:G1805 S1GM - S1JM Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10 CAPACITANCE (pF) 1 0.8 0.6 0.4 0.2 RESISTIVE OR INDUCTIVE LOAD 0 1 25 50 75 100 125 150 175 1 10 100 LEAD TEMPERATURE (oC) REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics Fig.4 Typical Forward Characteristics 100 10 TJ=125°C 1 TJ=75°C 0.1 TJ=25°C 0.01 0.001 10 0.1 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C 0.01 Pulse width 0.001 0.1 0.3 0.4 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) TJ=25°C 0.1 1 (A) 0 INSTANTANEOUS REVERSE CURRENT (μA) f=1.0MHz Vsig=50mVp-p INSTANTANEOUS FORWARD CURRENT (A) AVERAGE FORWARD CURRENT (A) 1.2 0.4 0.6 0.5 0.8 0.6 1 0.7 1.2 Pulse Width=300μs 1% 0.8 Duty 0.9Cycle1 1.1 1.4 1.6 1.8 2 FORWARD VOLTAGE (V) 3 Version:G1805 1.2 S1GM - S1JM Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-repetitive Forward Surge Current PEAK FORWARD SURGE URRENT(A) 100 8.3ms Single Half Sine Wave 10 1 1 10 100 NUMBER OF CYCLES AT 60 Hz Fig.6 Reverse Recovery Time Characteristic And Test Circuit Diagram 4 Version:G1805 S1GM - S1JM Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS Micro SMA SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N YW 5 = Marking Code = Date Code Version:G1805 S1GM - S1JM Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version:G1805 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Taiwan Semiconductor: S1GM RSG S1JM RSG S1GMHRSG S1JMHRSG
S1GM RSG 价格&库存
很抱歉,暂时无法提供与“S1GM RSG”相匹配的价格&库存,您可以联系我们找货
S1GM RSG
  • 18000+1.2698518000+0.16447
