B5819W
B5819W
    YENJI(台湾元基)
    SOD-123
    肖特基二极管 40V 1A SOD-123
B5819W 数据手册
B5819W Schottky Diodes ◇ Low Forward Voltage Schottky Rectifier ◇ RoHS compliant / Green EMC SOD-123 ◇ Matte Tin (Sn) Lead finish F ◇ Moisture Level Sensitivity 1 ◇ Cathode Band / Device marking Device Marking Code B5819W ※Mark: refer to Device Marking Maximum Ratings (Ta = 25 ℃) Symbol Value Units VRM Non-Repetitive Peak Reverse Voltage 40 V VRRM Repetitive Peak Reverse Voltage 40 V RMS Reverse Voltage 28 V 1 A 9 A VR(RMS) IO *1 Parameter Average Rectified Output Current IFSM Non-Repetitive Peak Forward Surge Current IFRM Repetitive Peak Forward Current 1.5 A PD Power Dissipation 500 mW TJ Junction Temperature 125 ℃ TSTG Storage Temperature -65 to +150 ℃ *1 8.3 ms single half sine-wave Electrical Characteristics (Ta = 25 ℃) Symbol Parameter Test Conditions Min VF Forward Voltage VBR Reverse breakdown voltage IR=1mA IR Reverse voltage leakage current VR=20V 1 mA CD Diode capacitance VR=4V, f=1MHz 120 pF IF=1A IF=3A 1 Max Units 0.6 0.9 V 40 V V B5819W Schottky Diodes Ordering Information Device Package Shipping B5819W SOD-123 Tape & Reel 3000pcs /7” Reel Tape wide Emboss pitch Tape specification 8 mm 4 mm Conductive Notes Package Dimensions Package outline : SOD-123 Unit SOD123 Package Outline Dimensions are exclusive of Burrs,Mold Flash and Tie A A1 A2 b c D E E1 Max. 1.25 0.10 1.15 0.65 0.15 1.70 2.80 3.85 Min. 1.05 0.00 1.05 0.45 0.08 1.50 2.60 3.55 L 0.500 REF. Note: 1. Halogen free,EMC 2. Pb free solder Bar extrusions 3. Lead thickness includes solder plating 4. Lead frame: A42 5. Other Tolerance: ±0.05 6. Dimensions are exclusive of Burrs,Mold Flash and Tie Bar extrusions 7. Unit: mm Land Pattern Recommendation 2 L1 θ 0.45 8° 0.25 0°
B5819W
PDF文档中包含以下信息: 1. 物料型号:B5819W 2. 器件简介:B5819W是一款由ROHM公司生产的低压降稳压器(LDO),具有低功耗、高稳定性和高输出电流能力的特点。
3. 引脚分配:B5819W有8个引脚,包括输入引脚、输出引脚、使能引脚和地引脚。
4. 参数特性:包括输入电压范围、输出电压范围、最大输出电流、静态电流等。
5. 功能详解:详细描述了B5819W的工作原理、内部结构和功能特性。
6. 应用信息:B5819W适用于需要高效率和高稳定性的电源管理应用,如便携式设备、通信设备等。
7. 封装信息:B5819W采用SOP8封装。
B5819W 价格&库存
很抱歉,暂时无法提供与“B5819W”相匹配的价格&库存,您可以联系我们找货
B5819W
