RADIAL LEADED MLCC
RADIAL LEADED MLCC
HOW TO ORDER
CT4
0805
A
B
Y 104
M 500
P F3
C
E
G
D
F
H
B:
A:
UNIT INCHES
Nominal Body Size(L
Product Type
I
CC4
Class I Dielectric
Radial Leaded & Mlcc
II
Class II Dielectric
CT4
0805
0.17
0.15
1206
0.20
1209/1210
Tolerance
B
0.10pF
0.18
C
0.25pF
0.20
0.22
D
0.5pF
1812
0.34
0.26
F
1.0%
G
2.0%
2225
0.41
0.37
J
5.0%
K
10%
M
20%
N
30%
D:
C:
Nominal Capacitance
Temperature Characteristics
CG COG
(N) (NPO)
Y(F)
W)
Type
Code
B
E:
30ppm/
15%
X7R
Y5V
(-55~+125
(-55~+125
+30 %
- 80
(-25~+85
S
+50%
-20%
Z
+80%
-20%
digit is number of zeros.
P
+100%
For example:
B.C.D
C 10PF
B.C.D for C 10PF
NPO:B.C.D.F.G.J.K.M
X7R:K.M.N.S.Z
Y5V:M.N.S.Z.P
First two digits are significant, and the third
104=100000pF
5R6=5.6pF
F:
H:
G:
mm
Lead Space(Unit:mm)
Packaging Style
Rated Voltage
P
Ammo
F1
2.54
F2
4.57
F3
5.08
F4
3.50
Tape
T
Reel
For example:
Bulk
500=50V
-0%
Blank
101=100V
161
SIZE CODE
CAPACITANCE AND VOLTAGE
mm
Dimensions Unit mm
Size
Code
0805
1206
1210/
1209
1812
2225
Shape
F
0.5
H
1
a
b
C1
C2
C3
2.54/3.5
2.54
5.08
5.08
5.08
5
10
5/10
5
5/10
a
b
C1
2.54
3.50
5.08
b
C1
3.50
5.08
b
b
4.57
5.50
10
10
10
10
L
max
4.2
5.5
5.5
8.5
10.5
W
max
3.8
4.5
5.5
6.5
9.5
Available Capacitance Range
T
max
3.8
3.8
3.8
3.8
4.2
Voltage
C0G
(NP0)
X7R
Y5V
25
0R5~272
101~105
102~125
50
0R5~222
101~105
102~105
100
0R5~102
101~104
25
0R5~562
101~225
102~125
50
0R5~472
101~105
102~105
100
0R5~332
101~154
25
100~103
471~105
472~155
50
100~103
471~105
472~205
100
5R0~103
101~105
25
100~153
471~335
103~335
50
100~103
471~225
103~225
100
5R0~103
101~105
25
100~473
102~475
103~475
50
100~273
102~335
103~335
100
5R0~273
101~105
0.1
Others are available, contact FH.
d
162
RADIAL LEADED MLCC
PACKAGING STYLE
P
Note:P1=3.85mm for F=5.08mm; P1=5.1mm for F=2.54mm
Note:
Code
P
P0
12.7
12.7
Dim
F=5.08mm
P1
3.85
P2
d
6.35
0.5
h
W
18.5
0.2
0.7
8
W1
W2
H
9
1.5
32.25
10
5.1
1.0
W0
1.3
0.1
1
1
1
H0
I
D
t
16
1.42
4.0
0.7
19.5
0.5
1.5
Max
1.0
Max
0.2
Max
Tol
AMMO PACKAGING
TAPE& REEL PACKAGING
163
P
6
很抱歉,暂时无法提供与“CT4-0805Y104M500F3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.14588
- 100+0.13308
- 500+0.12455
- 1000+0.11602
- 5000+0.10578
- 10000+0.10152
- 国内价格
- 20+0.23822
- 200+0.18914
- 1000+0.14819
- 2000+0.13184
- 10000+0.11762
- 20000+0.11002
