PMPR473J630D02
PMPR473J630D02
    TENTA(天泰)
    CAP_18.5X8.5MM_TM
    薄膜电容 CAP_18.5X8.5MM_TM 47nF ±5% 18.50 x 8.50mm 630V
PMPR473J630D02 数据手册
版 本 描 述 日 期 客户 CUSTOMER 品名 PART NAME 天泰料号 TENTA Material Number 客户料号 CUSTOMER Material Number 编制/Edition 检查/Checked 确认/Confirmed 孙兰金 徐志钦 杨再军 承认/Admit 审核/Auditing 批准/Approved 天泰電機工業有限公司 TENTA ELECTRIC INDUSTRIAL CO., LTD. 台中縣梧棲区自強二街 86 巷 61 號 NO.61, Lane 86, Tzchiang 2st St. Wu-Chi Township, Taichung County 435, TAIWAN R.O.C TEL:(886-04)26398618 FAX:(886-04)26392549 深圳天泰電器元件有限公司 SHEN ZHEN TENTA ELECTRICAL APPLIANCE LTD. 公司:深圳市南山區白石洲中國原子能第二工業區第二棟六樓 6/F NO.2, Pirector Atom 2th Industry, Baishizhou , Shenzhen, CHINA TEL:(0755)86327963、26921158 FAX:(0755)86297411 工厂:深圳市寶安區福永街道橋頭社區富橋第四工業區 A5 棟 No.A5,FU Qiao 4th Industrial area,Qiaotou Community,Fuyong Street,Bao An District,Shen Zhen TEL:(0755)29604898 FAX:(0755)29604891 TENTA ELECTRIC INDUSTRIAL CO., LTD. SPECIFICATIONS METALLIZED POLYPROPYLENE FILM CAPACITORS FOR DC VOLTAGE ……PMPR SPECIFICATIONS: 1. Flame retardation epoxy resin powder coating provides safety and the identical outer appearance 2. The flame-retarded rating meet UL94V-0 requirement 3. CAPACITANCE TOLERANCE: J (±5%), K( ±10%) 4. RATED VOLTAGE: 100VDC, 250VDC, 400VDC, 630V DC 5. CAPACITANCE RANGE: 0.001µF to 10 µF 6. OPERATING TEMPERATURE: -40℃ to +85℃ 7. WITHSTAND VOLTAGE: Between Electrodes 175% of the rated voltage for 5 sec. 8. DISSIPATION FACTOR (tan δ) : Max. 0.1% when measured at 1 kHz & 25℃ 9. INSULATION RESISTGANCE: Between Electrodes (1) Less than or equal to 0.33µF≧30,000 MΩ (2) More than 0.33µF≧10,000 MΩ/µF MEASURED AT 100VDC, 60 SEC. AND 20℃ 10. TENSILE STRANGTH OF ELECTRODES: TEST CONDITION Load force : 1.0kg Holding Times: 10±1 sec. TEST CRITERIA No wire breakage and no damage of the capacitor. 11. BENDING STRENGTH OF ELECTRODES: TEST CONDITION Load Force : 0.5kg Bending Times: Two consecutive bends(4X90℃)in 5 sec. TEST CRITERIA No wire breakage and no damage of the capacitor. 12. VIBR ATION RESISTANCE: TEST CONDITION Frequency cycle : 1 minute per cycles 10-55-10Hz Test Duration : Perpendicular direction with the same method for 45 minutes esth, total of 90 mimutes. TEST CRITERIA (1) Appearance : No visible damage (2) Contact : Normal 13. SOLDERABILITY: TEST CONDITION Solder Bath Temperature : 260±5℃ Solder Time : 2±0.5 sec. TEST CRITERIA 3/4 of the surface tinning 14. HEAT SHOCK TEST: TEST CONDITION The Electrodes of capacitor shall be immersed in the emitting solder. Solder Bath Temperature : 260±5℃ Solder Time : 3±0.5sec. Testing Voltage : 175% of the rated voltage for 1 minute TEST CRITERIA (1) Appearance : No visible damage (2) Withstand Voltage : Normal (3) Capacitance Change : ≦ ±3% of the initial value. 15. COLD RESISTANCE: TEST CONDITION Test Temperature : -40 ± 2 ℃ Test Duration : 2 hrs TEST CRITERIA (1) Appearance : No visible damage (2) Capacitance Change : ≦ +0%, -5%(-40℃) of the initial value. 16. DRY HEAT RESISTANCE: TEST CONDITION Test Temperature : 85 ± 2℃ Test Duration : 2 hrs TEST CRITERIA(at 85℃) Capacitance Change : ≦ +5%, -2% of the initial value 17. HUMIDITY RESISTANCE: TEST CONDITION Test Temperature : 40 ± 2℃ Relative Humidity: 90 to 95% Test Duration : 240 ± 8 hrs than condition at standard state 16 hrs. Test Voltage : 175% of the rated voltage for 1 minute TEST CRITERIA (1) Appearance : No visible damage (2) Capacitance Change : ≦ ± 5% of the initial value (3) IR : Over 3000MΩ/µF (4) Withstand Voltage : Normal 1.5max W max MARKING T max MARKING MARKING 5mm(max) P p 2A(100VDC) W H T P dØ 5mm(max) p Lo Lo Pediform.C#(内弯) Pediform.B#(弯脚) Pediform.A#(长脚) 5mm(max) p L0 d+/-0.05 Lo20min Capacitance MARKING MARKING H max 2E(250VDC) W H T P dØ p Pediform.E#(短脚) Pediform.D#(外弯) 2G(400VDC) W H T P dØ L0 2J(630VDC) W H T P dØ symbo uf 102 0.001 9.5 8.5 4.5 7.5 0.6 152 0.0015 9.5 8.5 4.5 7.5 0.6 222 0.0022 9.5 9.0 5.0 7.5 0.6 332 0.0033 9.5 8.5 5.0 7.5 0.6 13.0 9.0 5.0 10.0 0.6 472 0.0047 9.5 .9.5 5.0 7.5 0.6 13.0 9.0 5.0 10.0 0.6 682 0.0068 9.5 9.5 5.0 7.5 0.6 13.0 9.0 5.0 10.0 0.6 103 0.01 13.0 8.5 5.0 10.0 0.6 13.0 10.0 6.0 10.0 0.6 153 0.015 13.0 9.0 5.0 10.0 0.6 13.0 12.0 7.0 10.0 0.6 223 0.022 13.0 9.0 5.0 10.0 0.6 13.0 10.5 5.5 10.0 0.6 18.0 10.5 6.5 15.0 0.6 333 0.033 13.0 9.0 5.0 10.0 0.6 13.0 12.0 6.5 10.0 0.6 18.0 12.5 7.5 15.0 0.6 473 0.047 13.0 9.0 5.0 10.0 0.6 13.0 10.0 5.5 10.0 0.6 13.0 13.0 7.5 10.0 0.6 18.0 14.0 8.5 15.0 0.8 683 0.068 13.0 9.5 5.0 10.0 0.6 13.0 11.5 6.5 10.0 0.6 18.0 12.5 6.5 15.0 0.8 18.0 15.5 10.0 15.0 0.8 104 0.1 13.0 10.5 6.0 10.0 0.6 13.0 12.5 7.5 10.0 0.6 18.0 13.5 8.0 15.0 0.8 24.0 15.0 9.0 20.0 0.8 154 0.15 13.0 11.5 7.0 10.0 0.6 13.0 11.0 6.0 15.0 0.6 18.0 15.5 9.0 15.0 0.8 24.0 16.0 10.0 20.0 0.8 224 0.22 18.0 12.0 6.0 15.0 0.6 18.0 13.0 7.0 15.0 0.6 26.0 15.5 8.0 22.5 0.8 26.0 17.0 9.5 22.5 0.8 334 0.33 18.0 13.0 7.0 15.0 0.8 18.0 14.5 8.0 15.0 0.8 26.0 17.0 9.0 22.5 0.8 26.0 18.0 10.0 22.5 0.8 474 0.47 18.0 14.0 8.5 15.0 0.8 18.0 16.0 10.0 15.0 0.8 26.0 18.0 10.0 22.5 0.8 31.0 18.0 11.0 27.5 0.8 684 0.68 24.0 15.0 8.0 20.0 0.8 24.0 17.0 10.0 20.0 0.8 26.0 19.0 10.0 22.5 0.8 31.0 20.0 12.0 27.5 0.8 105 1.0 24.0 16.0 9.0 20.0 0.8 24.0 18.0 11.0 20.0 0.8 31.0 20.0 12.0 27.5 0.8 31.0 24.0 15.0 27.5 0.8 155 1.5 24.0 18.0 10.0 20.0 0.8 24.0 21.0 13.0 20.0 0.8 31.0 23.0 13.0 27.5 0.8 225 2.2 31.0 18.0 11.0 27.5 0.8 31.0 21.0 13.0 27.5 0.8 31.0 26.0 15.5 27.5 0.8 335 3.3 31.0 21.0 12.0 27.5 0.8 31.0 25.0 15.5 27.5 0.8 475 4.7 31.0 26.0 15.0 27.5 0.8 685 6.8 34.0 28.0 16.0 31.0 0.8 P 10.0 15.0 22.5 27.5 31.0 106 10.0 34.0 31.0 18.5 31.0 0.8 TOL ±1.0 ±1.0 ±1.0 ±1.5 ±1.5 *Please contact us for special item or size not listed 我司料号 µF / V Tolerance Wmax Hmax Tmax Pediform P L0 dØ PMPR103J630D01 PMPR104J630D03 PMPR104J400D02 0.01µF / 630VDC 0.1µF / 630VDC 0.1µF / 400VDC ±5% ±5% ±5% 13.0 18.0 13.0 11.0 14.0 13.0 7.0 8.5 7.5 A# A# A# 10.0 15.0 10.0 0.6 0.8 0.6 PMPR104J100D01 0.1µF / 100VDC ±5% 13.0 11.0 7.0 A# 10.0 0.6 PMPR224K100D01 0.22µF / 100VDC ±10% 18.0 12.0 7.5 A# 15.0 0.8 PMPR473J630D02 0.047µF / 630VDC ±5% 18.5 14.0 8.5 A# 15.0 0.8 PMPR224J400D02 0.22µF / 400VDC ±5% 18.0 15.5 10.0 A# 15.0 0.8
PMPR473J630D02 价格&库存
很抱歉,暂时无法提供与“PMPR473J630D02”相匹配的价格&库存,您可以联系我们找货
