RC0805JR-0715ML
RC0805JR-0715ML
    YAGEO(国巨)
    贴片电阻 0805 15MΩ ±5% 1/8W ±200ppm/℃
RC0805JR-0715ML 数据手册
DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC_L series ±0.1%, ±0.5%, ±1%, ±5% Sizes 0075/0100/0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification –Mar. 7, 2017 V.7 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SCOPE This specification describes RC series chip resistors with lead free terminations made by thick film process. RC_L SERIES 2 10 0075 to 2512 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RC XXXX X X X XX XXXX L APPLICATIONS  All general purpose application (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Halogen Free Epoxy  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes, resistors element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production (2) TOLERANCE B = ± 0.1% D = ± 0.5% F = ± 1.0% J = ± 5.0% (for jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel S = ESD safe reel (0075/0100 only) (4) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (5) TAPING REEL 07 = 7 inch dia. Reel 10=10 inch dia. Reel 13 =13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 7N = 7 inch dia. Reel, ESD safe reel (0075/0100 only) (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only.(Note) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩwith ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KL. NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Jun. 22, 2017 V.7 Product specification Chip Resistor Surface Mount RC_L SERIES 3 10 0075 to 2512 MARKING RC0075 / RC0100 / RC0201 / RC0402 No Marking Fig. 1 RC0603 03 Fig. 2 Value = 10 KΩ E24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros RC0805 / RC1206 / RC1210 / RC2010 / RC2512 00 Fig. 3 E24/E96 series: 4 digits First three digits for significant figure and 4th digit for number of zeros Value = 10 KΩ RC1218 Fig. 4 Value = 10 KΩ 00 Fig. 5 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Value = 10 KΩ For further marking information, please see special data sheet "Chip resistors marking". CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Ni-barrier) are added, as shown in Fig.6. Outlines For dimensions, please refer to Table 1 Fig. 6 Chip resistor outlines www.yageo.com Jun. 22, 2017 V.7 Product specification Chip Resistor Surface Mount RC_L SERIES 4 10 0075 to 2512 DIMENSION Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RC0075 0.30±0.01 0.15±0.01 0.10±0.01 0.08±0.03 0.08±0.03 RC0100 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 RC0201 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 RC0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 RC0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 RC1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC1210 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC1218 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS POWER OPERATING TEMPERATURE RANGE -55℃ to 125℃ RC0075 1/50 outlines W Fig. 4 Chip resistor MAXIMUM WORKING VOLTAGE 10V MAXIMUM DIELECTRIC OVERLOAD WITHSTANDING VOLTAGE VOLTAGE 25V 25V RESISTANCE RANGE TEMPERATURE COEFFICIENT JUMPER CRITERIA 5% (E24) 10Ω≦R
RC0805JR-0715ML
物料型号:YAGEO RC_L系列,包括多种尺寸,如0075、0100、0201、0402、0603、0805、1206、1210、1218、2010、2512等。
器件简介:这是一系列通用的表面贴装厚膜芯片电阻,采用无铅端子,符合RoHS标准,无卤素。
引脚分配:文档中没有明确指出引脚分配,但通常这类电阻为两个端子的简单结构。
参数特性: - 公差:±0.1%、±0.5%、±1%、±5% - 温度系数:根据规格书有不同的温度系数,如100ppm/°C、±200ppm/°C等。 - 工作温度范围:不同型号有不同的工作温度范围,如-55°C至125°C或-55°C至155°C。 - 最大工作电压:根据型号不同,最大工作电压从10V至500V不等。 - 额定功率:不同型号的电阻有不同的额定功率,如1/50W、1/32W、1/16W等。
功能详解:这些电阻具有节省PCB空间、高组件和设备可靠性、无有害物质使用等特点。
应用信息:适用于所有通用目的的应用。
封装信息:提供了不同尺寸的封装信息,包括长度、宽度、高度、内径和外径。
订购信息:全球零件编号由系列、尺寸、公差、包装类型、温度系数、卷轴和电阻值等组成。
标记:提供了不同型号的电阻的标记方法,包括E24系列、E96系列等。
结构:电阻由高等级陶瓷基板、内部金属电极、厚膜电阻元件、覆盖玻璃和保护性环氧涂层构成。
尺寸:提供了详细的尺寸表,包括每种型号的长度、宽度、高度、内径和外径。
电气特性:包括功率、工作温度范围、最大工作电压、最大电压、介电过载耐压、电阻范围和温度系数等。
包装风格和包装数量:提供了不同包装风格和数量的信息。
测试和要求:包括电阻的温度系数、寿命/耐久性、高温暴露、耐湿性、湿热、热冲击、板弯曲、润湿性、浸出和耐焊热等测试条件、程序和要求。
修订历史:记录了从首次发布到当前版本的所有修订。
RC0805JR-0715ML 价格&库存
很抱歉,暂时无法提供与“RC0805JR-0715ML”相匹配的价格&库存,您可以联系我们找货
RC0805JR-0715ML
  • 50+0.03416
  • 1000+0.02703
  • 2000+0.02662
  • 5000+0.02307
库存:14260
RC0805JR-0715ML
    • 5000+0.08080
    库存:10000
    RC0805JR-0715ML
    • 1+1.591911+0.20606
    • 10+0.7681810+0.09944
    • 25+0.6042925+0.07822
    • 50+0.5107050+0.06611
    • 100+0.43741100+0.05662
    • 250+0.36262250+0.04694
    • 500+0.31984500+0.04140
    • 1000+0.285831000+0.03700
    库存:19725
    RC0805JR-0715ML
    • 5000+0.231795000+0.03001
    • 10000+0.2160510000+0.02797
    • 15000+0.2083815000+0.02698
    • 25000+0.2000825000+0.02590
    • 35000+0.1953435000+0.02529
    • 50000+0.1908450000+0.02471
    库存:19725
    RC0805JR-0715ML
      • 1+0.47210
      • 100+0.25890
      • 1000+0.15850
      • 2500+0.10680
      • 5000+0.07610
      库存:2080
