GS393A-SR
GS393A-SR
    GAINSIL(聚洵)
    SOP-8
    低功耗低偏置电压双比较器 SOP8
GS393A-SR 数据手册
GS393/393A LOW POWER LOW OFFSET VOLTAGE DUAL COMPARATORS Features Wide Supply Voltage Range Differential Input Voltage Range Equals to the Single Supply: 2.0V to 36V Power Supply Voltage Dual Supplies: ±1.0V to ±18V Low Output Saturation Voltage: 200mV at 4mA Low Supply Current Drain: 0.6mA Open Collector Output Low Input Bias Current: 25nA (Typical) Small Package: Low Input Offset Current: ±5.0nA (Typical) GS393/393A Available in SOP-8 and DIP-8 Packages Low Input Offset Voltage: 1.0mV (Typical) Input Common Mode Voltage Range Includes Ground General Description The GS393/393A consist of two independent precision voltage comparators with a typical offset voltage of 1.0mV and high gain. They are specifically designed to operate from a single power supply over wide range of voltages. Operation from split power supply is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.The GS393/393A series are compatible with industry standard 393. GS393A has more stringent input offset voltage than GS393. Applications Battery Charger DC-DC Module Cordless Telephone PC Motherboard Switching Power Supply Communication Equipment Pin Configuration Figure 1. Pin Assignment Diagram Functional Block Diagram Figure 2. Functional Block Diagram of GS393/393A (Each comparator) V0 1/8 GS393/393A Absolute Maximum Ratings Condition Symbol Max Vcc ±20V or 40V VI(DIFF) 40V VI -0.3V~40V Operating Temperature Range Topr -25°C ~+125°C Storage Temperature Range Tstg -65°C ~+150°C Power Supply Voltage Differential input voltage Input Voltage Note 1: Stresses greater than those listed under "Absolute Maximum Ratings" may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under "Recommended Operating Conditions" is not implied. Exposure to "Absolute Max-imum Ratings" for extended periods may affect device reliability. Note 2: This input current will only exist when the voltage at any of the input leads is driven negative. It is due to the collector-base junction of the input PNP transistors becoming forward biased and thereby acting as input diode clamps. In addition to this diode action, there is also lateral NPN parasitic transistor action on the IC chip. This transistor action can cause the output voltages of the comparators to go to the V+ voltage level (or to ground for a large overdrive) for the time duration that an input is driven negative. This is not destructive and normal output states will re-establish when the input voltage, which was negative, again returns to a value greater than -0.3 VDC at 25°C). Package/Ordering Information MODEL CHANNEL GS393 Dual GS393A Dual V0 PACKAGE PACKAGE MARKING DESCRIPTION OPTION INFORMATION GS393-SR SOP-8 Tape and Reel,4000 GS393 GS393-DR DIP-8 20Tube(1000pcs) GS393 GS393A-SR SOP-8 Tape and Reel,4000 GS393 GS393A-DR DIP-8 20Tube(1000pcs) GS393 ORDER NUMBER 2/8 GS393/393A Recommended Operating Conditions Electrical Characteristics o o o Limits in standard typeface are for TA=25 C, bold typeface applies over TA=-40 C to 85 C (Note 3), VCC=5V, GND=0V, unless otherwise specified. o ≤ TA ≤85 Note 3: These specifications are limited to -40 C o C. Limits over temperature are guaranteed by design, but not tested in production. Note 4: The input common-mode voltage of either input signal voltage should not be allowed to go negatively by o o more than 0.3V (at 25 C). The upper end of the common-mode voltage range is VCC-1.5V (at 25 C), but either or both inputs can go to +36V without damages, V0 independent of the magnitude of the VCC. 3/8 GS393/393A Typical Performance characteristics V0 4/8 GS393/393A Typical Performance characteristics V0 5/8 GS393/393A Typical Applications V0 6/8 GS393/393A Package Information SOP-8 V0 7/8 GS393/393A DIP-8 V0 8/8
GS393A-SR 价格&库存
很抱歉,暂时无法提供与“GS393A-SR”相匹配的价格&库存,您可以联系我们找货
