LM321/358/324
1MHZ High Voltage Bipolar Opamp
Features
Small Package:
Single-Supply Operation from +3V ~ +32V
Dual-Supply Operation from
LM321 Available in SOT23-5 Packages
Gain-Bandwidth Product: 1MHz (Typ.)
LM358 Available in SOP-8 and MSOP-8 Packages
Low Input Bias Current: 45nA (Typ.)
LM324 Available in SOP-14 Package
Low Offset Voltage: 5mV (Max.)
Quiescent Current: 250µA per Amplifier (Typ.)
Operating Temperature: -25°C ~ +80°C
±1.5V ~ ±16V
General Description
The LM358 family have a high gain-bandwidth product of 1MHz, a slew rate of 0.4V/
250
μs, and a quiescent current of
μA/amplifier at 5V. The LM358 family is designed to provide optimal performance in low voltage and low noise systems.
The maximum input offset voltage is 5mV for LM358 family. The operating range is from 3V to 32V. The LM321 single is
available in Green SOT-23-5 packages. The LM358 Dual is available in Green SOP-8 and MSOP-8 packages. The LM324
Quad is available in Green SOP-14 package.
Applications
Walkie-Talkie
Multivibrators
Battery Management Solution
Oscillators
Transducer Amplifiers
Portable Systems
Summing Amplifiers
Pin Configuration
Figure 1. Pin Assignment Diagram
V1
1/13
LM321/358/324
Absolute Maximum Ratings
Condition
Symbol
Max
Vcc
±16V or 32V
VI(DIFF)
32V
VI
-0.3V~32V
Operating Temperature Range
Topr
-25°C ~+80°C
Storage Temperature Range
Tstg
-65°C ~+150°C
Power Supply Voltage
Differential input voltage
Input Voltage
Note: Stress greater than those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a
stress rating only and functional operation of the device at these or any other conditions outside those indicated in the operational
sections of this specification are not implied. Exposure to absolute maximum rating conditions for extended periods may affect
reliability.
Package/Ordering Information
PACKAGE
PACKAGE
MARKING
DESCRIPTION
OPTION
INFORMATION
LM321-TR
SOT23-5
Tape and Reel,3000
LM321
LM358-SR
SOP-8
Tape and Reel,4000
LM358
LM358-MR
MSOP-8
Tape and Reel,3000
LM358
LM324-SR
SOP-14
Tape and Reel,2500
LM324
MODEL
CHANNEL
ORDER NUMBER
LM321
Single
LM358
Dual
LM324
Quad
V1
2/13
LM321/358/324
Electrical Characteristics
o
(At VS = +15V, TA=25 C, unless otherwise noted.)
LM321/358/324
PARAMETER
SYMBOL
CONDITIONS
TYP
+25
MIN/MAX OVER TEMPERATURE
+25
UNITS
MIN/MAX
mV
MAX
INPUT CHARACTERISTICS
Input Offset Voltage
VOS
VCM = VS/2
0.4
5
Input Bias Current
IB
44
nA
TYP
Input Offset Current
IOS
3
nA
TYP
Common-Mode Voltage Range
VCM
-0.1 to +4
V
TYP
Common-Mode Rejection Ratio
CMRR
Open-Loop Voltage Gain
AOL
Input Offset Voltage Drift
∆VOS/∆T
VS = 5.5V
VCM = 0V to Vs-1.5V
90
70
dB
MIN
RL = 5kΩ, VO = 1V to 11V
100
90
dB
MIN
7
µV/
TYP
V
MIN
OUTPUT CHARACTERISTICS
VOH
RL = 2kΩ
11
VOL
RL = 2kΩ
5
mV
MAX
VOH
RL = 10kΩ
12
13
V
MIN
VOL
RL = 10kΩ
5
mV
MAX
40
60
mA
MAX
40
60
3
V
MIN
32
V
MAX
100
75
dB
MIN
400
µA
MAX
Output Voltage Swing from Rail
ISOURCE
Output Current
RL = 10Ω to VS/2
ISINK
POWER SUPPLY
Operating Voltage Range
Power Supply Rejection Ratio
PSRR
VS = +5V to +30V, VCM = +0.5V
Quiescent Current / Amplifier
IQ
250
GBP
1
MHz
TYP
0.4
V/µs
TYP
DYNAMIC PERFORMANCE
Slew Rate
V1
SR
G = +1, 2V Output Step
3/13
LM321/358/324
Typical Performance characteristics
V1
4/13
LM321/358/324
V1
5/13
LM321/358/324
Application Note
Size
LM358 family series op amps are unity-gain stable and suitable for a wide range of general-purpose applications. The small
footprints of the LM358 family packages save space on printed circuit boards and enable the design of smaller electronic
products.
Power Supply Bypassing and Board Layout
LM358 family series operates from a single 3V to 32V supply or dual ±1.5V to ±16V supplies. For best performance, a 0.1µF
ceramic capacitor should be placed close to the VDD pin in single supply operation. For dual supply operation, both VDD and VSS
supplies should be bypassed to ground with separate 0.1µF ceramic capacitors.
Low Supply Current
The low supply current (typical 250uA per channel) of LM358 family will help to maximize battery life.
Operating Voltage
LM358 family operates under wide input supply voltage (3V to 32V). In addition, all temperature specifications apply from
o
o
-25 C to +80 C. Most behavior remains unchanged throughout the full operating voltage range. These guarantees ensure
operation throughout the single Li-Ion battery lifetime
Capacitive Load Tolerance
The LM358 family is optimized for bandwidth and speed, not for driving capacitive loads. Output capacitance will create a
pole in the amplifier’s feedback path, leading to excessive peaking and potential oscillation. If dealing with load capacitance is
a requirement of the application, the two strategies to consider are (1) using a small resistor in series with the amplifier’s output
and the load capacitance and (2) reducing the bandwidth of the amplifier’s feedback loop by increasing the overall noise gain.
Figure 2. shows a unity gain follower using the series resistor strategy. The resistor isolates the output from the capacitance
and, more importantly, creates a zero in the feedback path that compensates for the pole created by the output capacitance.
Figure 2. Indirectly Driving a Capacitive Load Using Isolation Resistor
The bigger the RISO resistor value, the more stable VOUT will be. However, if there is a resistive load RL in parallel with the
capacitive load, a voltage divider (proportional to RISO/RL) is formed, this will result in a gain error.
The circuit in Figure 3 is an improvement to the one in Figure 2. RF provides the DC accuracy by feed-forward the VIN to RL. CF
and RISO serve to counteract the loss of phase margin by feeding the high frequency component of the output signal back to the
amplifier’s inverting input, thereby preserving the phase margin in the overall feedback loop. Capacitive drive can be increased
by increasing the value of CF. This in turn will slow down the pulse response.
V1
6/13
LM321/358/324
Figure 3. Indirectly Driving a Capacitive Load with DC Accuracy
V1
7/13
LM321/358/324
Typical Application Circuits
Differential amplifier
The differential amplifier allows the subtraction of two input voltages or cancellation of a signal common the two inputs. It is useful
as a computational amplifier in making a differential to single-end conversion or in rejecting a common mode signal. Figure 4.
shown the differential amplifier using LM358 family.
Figure 4. Differential Amplifier
VOUT= ( RR13++RR24 ) RR14 VIN − RR12 VIP +( RR13++RR24 ) RR13 VREF
If the resistor ratios are equal (i.e. R1=R3 and R2=R4), then
VOUT =
R2
R1
(VIP − VIN ) + VREF
Low Pass Active Filter
The low pass active filter is shown in Figure 5. The DC gain is defined by –R2/R1. The filter has a -20dB/decade roll-off after its
corner frequency ƒC=1/(2πR3C1).
Figure 5. Low Pass Active Filter
V1
8/13
LM321/358/324
Instrumentation Amplifier
The triple LM358 family can be used to build a three-op-amp instrumentation amplifier as shown in Figure 6. The amplifier in
Figure 6 is a high input impedance differential amplifier with gain of R2/R1. The two differential voltage followers assure the high
input impedance of the amplifier.
Figure 6. Instrument Amplifier
V1
9/13
LM321/358/324
Package Information
SOP-8
V1
10/13
LM321/358/324
MSOP-8
V1
11/13
LM321/358/324
SOP-14
V1
12/13
LM321/358/324
SOT23-5
V1
13/13
很抱歉,暂时无法提供与“LM324-SR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.80050
- 50+0.63461
- 150+0.55167
- 国内价格
- 5+0.63000
- 20+0.57750
- 100+0.52500
- 500+0.47250
- 1000+0.44800
- 2000+0.43050
