TS6112-33
TS6112-33
    TRUSIGNAL(坤元微电子)
    SOP-8
    3.3V固定输出,低压差400mV(Max)@Iout=250mA,Vin=12V(Max)
TS6112-33 数据手册
Trusignal Microelectronics TS6112-xx April 2018 ULTRA LOW QUIESCENT CURRENT 250mA LOW-DROPOUT VOLTAGE REGULATORS Features Product Description  250-mA Low-Dropout Voltage Regulator  Available in 1.5V,1.8V,2.5V,2.7V, 2.8V,3.0V,3.3V,5.0V, Fixed Output and Adjustable Versions  Dropout Voltage to 140 mv (typ) at 250 mA (TS6112-33)   Ultra-Low 40-μA Typical Quiescent Current Open Drain Power Good Output  Compatible with Low ESR Capacitor   Thermal Shutdown Protection 8-Pin SOIC Package Applications  Battery-Powered Applications  Power Converter/Inverter  Portable Devices POWER SUPPLY RIPPLE REJECTION vs FREQUENCY PSRR - Power Supply Rijection -dB 90 VI = 4.3V CO = 10μF IO = 250mA 80 70 The TS6112-xx series regulators are designed to have ultra-low quiescent currents and be stable with low ESR ceramic output capacitors and a wide range of capacitance (0.1μF or greater). The combination of the above characteristics provides high performance at lower cost. The TS6112-xx series is designed with very low dropout voltages (e.g. typically 200 mV for the TS6112-33 at an output current of 250 mA). The quiescent current is very low at light load (typically 40 μA at 10uA load), however, it is designed to be dependent of output loading (approximately 1/250 of the output current at heavy load), in order to provide much improved control loop stability and fast transient response. The low quiescent feature yields a significant improvement in operating life for battery-powered systems. This LDO family also features a sleep mode; applying a TTL high signal to EN (enable) shuts down the regulator, reducing the quiescent current to less than 1μA (typ). Power good (PG) is an active high output, which can be used to implement a power-on reset or a low-battery Indicator. The TS6112-xx is offered in 1.5V, 1.8V, 2.5V, 2.7V, 2.8V, 3.0V, 3.3V and 5.0V fixed-voltage versions and in an adjustable version (programmable over the range of 1.25 V to 5.5 V). Output voltage tolerance is specified as a maximum of 3% over line, load, and temperature ranges. The TS6112-xx family is available in 8 pin SOIC package. 60 50 40 30 20 10 100 1K 10K 100K 1M 10M f - Frequency - HZ REV KY.1.0.1B www.trusignal.com Trusignal Microelectronics TS6112-xx PIN CONFIGURATION AND FUNCTIONS SO-8 PACKAGE (TOP VIEW) NC/FB 1 8 OUT PG 2 7 OUT GND 3 6 IN EN 4 5 IN NAME EN FB/NC GND IN IN OUT OUT PG TERMINAL NO 4 1 3 5 6 7 8 2 I/O I I I I O O O DESCROPTION Enable input Feedback input voltage for adjustable device (no connect for fixed option) Regulator ground Input voltage Input voltage Regulated output voltage Regulated output voltage PG output TYPICAL APPLICATION VI 5 6 IN PG IN NC/FB OUT 4 0.1μF 2 PG 1 7 VO 8 OUT EN GND 4.7μF Figure 1. Typical Application Configuration for Fixed Output Options REV KY.1.0.3 2 Trusignal Microelectronics TS6112-xx RECOMMENDED OPERATING CONDITIONS Input voltage, VIN [1] MIN 2.7 Output voltage range, VOUT 1.2 5 V 0 250 mA -40 125 ℃ Output current, IOUT [2] Operating virtual junction temperature, TA [2] MAX 12 UNIT V [1] To calculate the minimum input voltage for your maximum output current, use the following equation: VIN(min) = VOUT(max) + VDO (max load). [2] Continuous current and operating junction temperature are limited by internal protection circuitry, but it is not recommended that the device operate under conditions beyond those specified in this table for extended periods of time. ESD CAUTION ABSOLUTE MAXIMUM RATINGS Parameter Input voltage range Voltage range at EN PG voltage Peak output current Output voltage, VOUT (OUT, FB) Junction Temperature Storage Temperature Range Min -0.3 -0.3 Max 14 16.5 16.5 Internally limited Unit V V V 7 V -40 125 C -65 150 C ±2000 V ESD HBM ESD (electrostatic discharge) sensitive device Charged devices and circuit boards can discharge without detection. Although this product features patented or proprietary protection circuitry, damage may occur on devices subjects to high energy ESD. Therefore, proper ESD precautions should be taken to avoid performance degradation or loss of functionality. ORDERING INFORMATION Model Part Number Eco Plan Package OUTPUT VOLTAGE (V) Container, Pack Qty TS6112-50 TS6112-50SO8R Rohs SO-8 5.0 Reel,2500 TS6112-33 TS6112-33SO8R Rohs SO-8 3.3 Reel,2500 TS6112-30 TS6112-30SO8R Rohs SO-8 3.0 Reel,2500 TS6112-28 TS6112-28SO8R Rohs SO-8 2.8 Reel,2500 TS6112-27 TS6112-27SO8R Rohs SO-8 2.7 Reel,2500 TS6112-25 TS6112-25SO8R Rohs SO-8 2.5 Reel,2500 TS6112-18 TS6112-18SO8R Rohs SO-8 1.8 Reel,2500 TS6112-15 TS6112-15SO8R Rohs SO-8 1.5 Reel,2500 TS6112-01 TS6112-01SO8R Rohs SO-8 Adjustable(1.25V to 5.5V) Reel,2500 The TS6112-01 is programmable using an external resistor divider. REV KY.1.0.3 3 Trusignal Microelectronics TS6112-xx ELECTRICAL CHARACTERISTICS: At TA = +25C, Vi = Vo (type) + 1 V, Io = 10μA, EN= 0V, CO=4.7μF, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40C to +125C. Symbol Parameter Operating Conditions Min Typ Max TS6112-01 TS6112-15 TS6112-18 TS6112-25 VOUT Output voltage [3] (10uA to 250mA load) TS6112-27 TS6112-28 TS6112-30 TS6112-33 TS6112-50 IGND 5.5V≥VOUT≥1.25V TA = −40C to +125C 0.97VOUT 2.7V≤VIN≤12V TA = −40C to +125C 1.455 1.8 2.5 2.7 2.716 (GND current) 3.090 3.3 3.250 3.350 5.0 4.850 EN = 0V Quiescent current [3] 2.884 2.910 5.0 ≤ VIN ≤ 12V TA = −40C to +125C 5.150 40 60 TA = −40C to +125C Output voltage line regulation [3][4] VOUT + 1V ≤ VIN ≤ 12 V, 0.005 Load regulation IOUT = 10μA to 250mA TA = −40C to +125C 0.5% Output noise voltage BW = 300Hz to 50kHZ, COUT =4.7μF 150 Output current Limit VOUT = 0V (ΔVO/VO) V 3.0 4.3 ≤ VIN ≤ 12V TA = −40C to +125C 2.781 2.8 4.0 ≤ VIN ≤ 12V TA = −40C to +125C 2.575 2.619 3.8 ≤ VIN ≤ 12V TA = −40C to +125C 1.854 2.425 3.7 ≤ VIN ≤ 12V TA = −40C to +125C 1.545 1.746 3.5 ≤ VIN ≤ 12V TA = −40C to +125C 1.03VOUT 1.5 2.8 ≤ VIN ≤ 12V TA = −40C to +125C Unit VOUT μA %/V μVrms 0.87 A Thermal shutdown junction temperature 150 ℃ Thermal shutdown hysteresis temperature 20 ℃ ISTB IFB EN = VIN , 2.7V≤VIN≤12V Standby current FB input current TS6112-01 FB = 1.5V High level enable input voltage TA = −40C to +125C VILEN Low level enable input voltage TA = −40C to +125C PSRR [3] IEN REV KY.1.0.3 10 TA = −40C to +125C VIHEN PG 1 μA nA 2 V 2 0.8 V f = 1kHz, IOUT = 10μA, COUT = 4.7μF 67 dB Minimum input voltage for valid PG IO (PG) = 300μA 1.25 V Trip threshold voltage VOUT decreasing TA = −40C to +125C Hysteresis voltage Measured at VOUT 0.5 %/VOUT Output low voltage VIN = 2.7V, IO(PG) = 1mA 0.16 V Leakage current V(PG) = 5 V TA = −40C to +125C Power supply ripple rejection 92 EN = 0V -1 EN = VIN -1 98 0 1 μA 1 μA 1 μA Input current (EN) 4 %/VOUT Trusignal Microelectronics TS6112-xx ELECTRICAL CHARACTERISTICS: At TA = +25C, Vi = Vo (type) + 1 V, Io = 10μA, EN= 0V, CO=4.7μF, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40C to +125C. Symbol Parameter Operating Conditions IOUT = 250mA TA = −40C to +125C IOUT = 250mA TA = −40C to +125C IOUT = 250mA TA = −40C to +125C IOUT = 250mA TA = −40C to +125C TS6112-28 VDO Dropout voltage Min. TS6112-30 [5] TS6112-33 TS6112-50 Typ. Max. Unit 310 540 270 470 200 mV 400 140 250 [3] Minimum IN operating voltage is 2.7 V or VOUT (typ.) + 1V, whichever is greater. Maximum IN voltage 12V [4] If VOUT≤ 1.8V then VINmin =2.7 V, VINmax = 12 V: Line Reg.(mV) = VOUT (V - 2.7V) 100 × 1000 × (%/V) If VOUT ≥ 2.5V then VINmin = VOUT + 1V, VINmax = 12 V: Line Reg.(mV) = VOUT (V - (VOUT+1V)) × 1000 × (%/V) 100 [5] In voltage equals VOUT(typ.) – 100mV; TS6112-01 out voltage set to 3.3V nominal with external resistor divider. TS6112-15, TS6112-18, TS6112-25, and TS6112-27 dropout voltage limited by input voltage range limitations (i.e., TS6112-30 input voltage needs to drop to 2.9 V for purpose of this test). Table of Graphs FIGURE vs Load current vs Free-air temperature vs Load current vs Free-air temperature vs Free-air temperature vs Frequency Output voltage Ground current Dropout voltage Power supply ripple rejection Line transient response Load transient response Output voltage Output spectral noise density REV KY.1.0.3 vs Time vs Frequency 5 2 3 4 7 5 6 8 9 10 11 Trusignal Microelectronics TS6112-xx TYPICAL CHARACTERISTICS TS6112-33 TS6112-33 OUTPUT VOLTAGE VS LOAD CURRENT OUTPUT VOLTAGE VS FREE-AIR TEMPERATURE 3.301 3.31 VIN= 4.3V TA = 25℃ 3.3 VIN= 4.3V 3.3 VO-Output volatge -V VO-Outout Voltage -V 3.299 3.298 3.297 3.296 3.295 3.294 3.29 3.28 IOUT = 10uA 3.27 3.26 IOUT = 250mA 3.293 3.25 3.292 3.24 3.291 0 50 100 150 200 -50 250 -25 0 50 75 100 125 150 TA - Free-Air Temperature - ℃ IL - Load Current - mA Figure2 Figure 3 TS6112-33 TS6112-33 GROUND CURRENT VS LOADCURRENT DROPOUT VOLTAGE VS FREE-AIR TEMPRATURE 1200 1 VIN = 4.3V TA = 25℃ VIN = 3.2V IOUT = 250mA VDO-Output Voltage -V 1000 IQ - Ground Current - μA 25 800 600 400 0.1 IOUT=150mA IOUT = 50mA 0.01 IOUT = 10mA 200 0.001 0 0 25 50 75 100 125 150 175 200 225 -50 250 0 25 50 75 100 TA - Free-Air Temperature - ℃ IL - load Current - mA Figure4 REV KY.1.0.3 -25 Figure5 6 125 150 Trusignal Microelectronics TS6112-xx TYPICAL CHARACTERISTICS POWER SUPPLY RIPPLE REJECTION VS FREQUENCY TS6112-33 GROUND CURRENT VS FREE-AIR TEMPEARTURE 90 50 IGND - Grond Current - μA 80 PSRR - Power Supply Rijection -dB VI = 4.3V IO = 0uA TA =25℃ VIN = 4.3V COUT = 10μF IOUT = 250mA TA = 25℃ 70 60 50 40 45 40 35 30 30 20 10 100 1K 10K 100K 1M -50 10M 0 50 Figure6 Figure7 TS6112-33 LOAD TRANSIENT RESPONSE △VOUT - Change in Output Voltage - mV △VOUT - Change in Output Voltage - mV TS6112-33 LINE TRANSIENT RESPONSE 30 COUT = 4.7μF 20 TA= 25℃ 10 IOUT - Output Current - mA VIN - Input Voltage - V 0 5.3 4.3 REV KY.1.0.3 100 200 300 400 500 150 TA - Free -Air Temperature - ℃ f - Frequency - HZ 0 100 600 700 800 900 100 50 0 CL = 4.7 μF T = 25℃ -50 250 0 0 100 10000 10000 200 300 400 500 t –Time - μs t –Time - μs Figure8 Figure9 7 600 700 800 900 Trusignal Microelectronics TS6112-xx TYPICAL CHARACTERISTICS TS6112-33 TS6833 OUTPUT SPECTRAL NOISE DENSITY VS FREQUENCY OUTPUT VOLTAGE VS TIME (AT STATUP) 10 3 Output Spectral Noise Densitv - μV/√Hz Enable Pulse –V VOUT - Output Voltage - V 4 2 1 0 4.3 0 0 100 200 300 400 500 600 700 800 900 10000 IOUT = 150mA 1 0.1 VIN= 4.3V COUT = 10μF TA= 25℃ O 0.01 100 t –Time - μs 1000 10000 f - Frequency - Hz Figure10 REV KY.1.0.3 IOUTI ==1mA 1mA Figure11 8 100000 Trusignal Microelectronics TS6112-xx APPLICATION INFORMATION The TS6112-XX family includes eight fixed-output voltage regulators (1.5 V, 1.8 V, 2.5 V, 2.7 V, 2.8 V, 3.0 V, 3.3 V, and 5.0 V), and an adjustable regulator, the TS6112-XX (adjustable from 1.25 V to 5.5 V). Device operation The TS6112-xx features very low quiescent current, which remains virtually constant even with varying loads. Conventional LDO regulators use a pnp pass element, the base current of which is directly proportional to the load current through the regulator (IB = IC/). The TS6112-xx uses a PMOS transistor to pass current; because the gate of the PMOS is voltage driven, operating current is low and invariable over the full load range. Another pitfall associated with the pnp-pass element is its tendency to saturate when the device goes into dropout. The resulting drop in forces an increase in IB to maintain the load. During power up, this translates to large startup currents. Systems with limited supply current may fail to start up. In battery-powered systems, it means rapid battery discharge when the voltage decays below the minimum required for regulation. The TS6112-xx quiescent current remains low even when the regulator drops out, eliminating both problems. The TS6112-xx family also features a shutdown mode that places the output in the high-impedance state (essentially equal to the feedback-divider resistance) and reduces quiescent current to 1 A (typ). If the shutdown feature is not used, EN should be tied to ground. Response to an enable transition is quick; regulated output voltage is reestablished in typically 160 s. Minimum load requirements The TS6112-xx family is stable even at zero load; no minimum load is required for operation. FB - pin connection (adjustable version only) The FB pin is an input pin to sense the output voltage and close the loop for the adjustable option. The output voltage is sensed through a resistor divider network to close the loop as it is shown in Figure 29. Normally, this connection should be as short as possible; however, the connection can be made near a critical circuit to improve performance at that point. Internally, FB connects to a high-impedance wide-bandwidth amplifier and noise pickup feeds through to the regulator output. Routing the FB connection to minimize/avoid noise pickup is essential. External capacitor requirements The input capacitor is not required usually, however, a ceramic bypass capacitor (0.1μF or greater) improves load transient performance. A higher capacitance capacitor may be necessary if large load transients with fast rise times are anticipated. The TS6112-XX series regulators require output capacitors to stabilize the internal feedback loop, however, the ESR (the equivalent series resistance) of the output capacitor is not necessary. Instead, the ESR should be limited to under 1Ω for the benefit of higher phase margin under large load current. The capacitance of the output capacitor should be greater than 0.1μF, though the recommended capacitance for this capacitor is 4.7μF or larger. REV KY.1.0.3 9 Trusignal Microelectronics TS6112-xx APPLICATION INFORMATION External capacitor requirements (continued) VI 5 6 IN PG IN NC/FB 1 4 250K 7 OUT 0.1μF PG 2 VO 8 OUT EN GND 4.7μF Figure12. Typical Application Circuit (Fixed Version) Programming the TS6112-01 adjustable LDO regulator The output voltage of the TS6112-01 adjustable regulator is programmed using an external resistor divider as shown in Figure 29. The output voltage is calculated using: Vo =Vref × (1+ Where Vref = 1.224 V typ. (the internal reference voltage) VO ) Vref Resistors R1 and R2 should be chosen from approximately 7-μA divider current . Lower value resistors can be used but offer no inherent advantage and waste more power. Higher values should be avoided as leakage currents at FB increase the output voltage error. The recommended design procedure is to choose R2 = 169 KΩ to set the divider current at 7μA and then calculate R1 using: R1 = ( VI VO − 1) × R2 Vref IN PG PG 250K > 2.0V EN VO OUT R1 < 0.8V FB CO GND R2 Figure13. TS6112-01 Adjustable LDO Regulator Programming REV KY.1.0.3 10 Trusignal Microelectronics TS6112-xx APPLICATION INFORMATION Power-good indicator The TS6112-xx features a power-good (PG) output that can be used to monitor the status of the regulator. Internal comparator monitors the output voltage: when the output drops to between 92% and 98% of its nominal regulated value, the PG output transistor turns on, taking the signal low. The open-drain output requires a pullup resistor. If not used, it can be left floating. PG can be used to drive power-on reset circuitry or used as a lowbattery indicator. Regulator protection The TS6112-xx PMOS-pass transistor has a built-in back diode that conducts reverse currents when the input Voltage drops below the output voltage (e.g., during power down). Current is conducted from the output to the Input and is not internally limited. When extended reverse voltage is anticipated, external limiting may be appropriate. The TS6112-xx also features internal current limiting and thermal protection. During normal operation, the TPS768xx limits output current to approximately 0.8 A (typ). When current limiting engages, the output voltage scales back linearly until the overcurrent condition ends. While current limiting is designed to prevent gross device failure, care should be taken not to exceed the power dissipation ratings of the package. If the temperature of the device exceeds 150℃(typ), thermal-protection circuitry shuts it down. Once the device has cooled below 130℃(typ), regulator operation resumes. power dissipation and junction temperature Specified regulator operation is assured to a junction temperature of 125C; the maximum junction temperature should be restricted to 125C under normal operating conditions. This restriction limits the power dissipation the regulator can handle in any given application. To ensure the junction temperature is within acceptable limits, calculate the maximum allowable dissipation, PD(max), and the actual dissipation, PD, which must be less than or equal to PD(max). The maximum-power-dissipation limit is determined using the following equation: PD(max) = TJ max - TA RθJA Where TJmax is the maximum allowable junction temperature RθJA is the thermal resistance junction-to-ambient for the package, ie., 176℃/W for the 8-terminal soic. TA is the ambient temperature. The regulator dissipation is calculated using: PD(max) = (VI - VO) ×IO Power dissipation resulting from quiescent current is negligible. Excessive power dissipation will trigger the thermal protection circuit. REV KY.1.0.3 11 Trusignal Microelectronics TS6112-xx MECHANICAL DIMENSIONS SO-8 PACKAGE MECHANICAL DRAWING θ SO-8 PACKAGE MECHANICAL DATA dimensions symbol millimeters inches min max min max A 5.8 6.2 0.2283 0.2441 A1 3.8 4 0.1496 0.1575 B 4.8 5 0.1890 0.1969 B1 B2 1.27 0.31 C C1 0.0500 0.51 1.75MAX 0.1 0.25 0.0201 0.0689MAX 0.0039 0.0098 L 0.4 1.27 0.0157 0.0500 D 0.13 0.25 0.0051 0.0098 θ 0o 8o 0o 8o CONTACT INFORMATION Trusignal Microelectronics Phone: +86 512-65923982 Fax: +86 512-65923995 Email: support@kunyuanic.com; sales@kunyuanic.com REV KY.1.0.3 0.0122 12
TS6112-33 价格&库存
很抱歉,暂时无法提供与“TS6112-33”相匹配的价格&库存,您可以联系我们找货
