PESD24VS1ULD,315
PESD24VS1ULD,315
    NEXPERIA(安世)
    SOD-882D
    ESD VRWM=24 V VBR(Min)=26.5 V VC=70 V IPP=3 A Ppp=150 W SOD882D
PESD24VS1ULD,315 数据手册
PESD24VS1ULD Unidirectional ESD protection diode 22 August 2018 Product data sheet 1. General description Unidirectional ElectroStatic Discharge (ESD) protection diode designed to protect one signal line from the damage caused by ESD and other transients. The device is housed in a SOD882D leadless ultra small Surface-Mounted Device (SMD) plastic package with visible and solderable side pads. 2. Features and benefits • • • • • • • • • • • • ESD protection of one line ESD protection up to 23 kV Ultra small SMD plastic package IEC 61000-4-2; level 4 (ESD) Solderable side pads IEC 61000-4-5 (surge); IPP = 3A Package height typ. 0.37 mm Max. peak pulse power: PPPM = 150 W Low clamping voltage: VCL = 70 V Max. peak pulse power: PPPM = 150 W Ultra low leakage current: IRM < 1 nA AEC-Q101 qualified 3. Application information • • • • Computers and peripherals Communication systems Audio and video equipment Portable electronics 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 24 V Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C - 23 50 pF PESD24VS1ULD Nexperia Unidirectional ESD protection diode 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K cathode[1] 2 A anode Simplified outline 1 2 Graphic symbol A K 006aaa152 Transparent top view DFN1006D-2 (SOD882D) [1] The marking bar indicates the cathode. 6. Ordering information Table 3. Ordering information Type number Package PESD24VS1ULD Name Description Version DFN1006D-2 leadless ultra small plastic package; 2 terminals; 0.65 mm pitch; 1 mm x 0.6 mm x 0.4 mm body SOD882D 7. Marking Table 4. Marking codes Type number Marking code PESD24VS1ULD 0010 0000 CATHODE BAR READING DIRECTION VENDOR CODE READING EXAMPLE: 0111 1011 MARKING CODE (EXAMPLE) READING DIRECTION 006aac477 Fig. 1. SOD882D binary marking code description PESD24VS1ULD Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2018 © Nexperia B.V. 2018. All rights reserved 2 / 11 PESD24VS1ULD Nexperia Unidirectional ESD protection diode 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit PPPM rated peak pulse power tp = 8/20 µs [1] - 150 W IPPM rated peak pulse current [1] - 3 A Tj Tamb junction temperature - 150 °C ambient temperature -55 150 °C Tstg storage temperature -65 150 °C - 23 kV - 10 kV ESD maximum ratings VESD [1] [2] [3] electrostatic discharge voltage IEC 61000-4-2; contact discharge [2] [3] MIL-STD-883 (human body model) Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC61000-4-5. Device stressed with ten non-repetitive ESD pulses. Measured from pin 1 to 2. 001aaa630 120 IPP 100 % 100 % IPP; 8 µs IPP (%) 80 90 % e-t 50 % IPP; 20 µs 40 10 % 0 Fig. 2. 0 10 20 30 t (µs) 8/20 µs pulse waveform according to IEC 61000-4-5 PESD24VS1ULD Product data sheet t tr = 0.6 ns to 1 ns 40 30 ns 60 ns Fig. 3. ESD pulse waveform according to IEC 61000-4-2 All information provided in this document is subject to legal disclaimers. 22 August 2018 001aaa631 © Nexperia B.V. 2018. All rights reserved 3 / 11 PESD24VS1ULD Nexperia Unidirectional ESD protection diode 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 24 V VBR breakdown voltage IR = 5 mA; Tamb = 25 °C 26.5 27 27.5 V IRM reverse leakage current VRWM = 24 V; Tamb = 25 °C - 1 50 nA Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C - 23 50 pF VCL clamping voltage IPP = 1 A; Tamb = 25 °C [1] [2] - - 36 V IPP = 3 A; Tamb = 25 °C [1] [2] - - 70 V IR = 10 A; Tamb = 25 °C [3] [2] - 1.6 - Ω Rdyn [1] [2] [3] dynamic resistance Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC61000-4-5. Measured from pin 1 to pin 2. Non-repetitive current pulse, Transmission Line Pulse (TLP) tp = 100 ns; square pulse; ANSI / ESD STM5.5.1-2008. 006aac488 104 PPP PPP (W) PPP(25°C) 103 0.8 102 0.4 10 1 10 102 tp (µs) 0 103 Tamb = 25 °C Fig. 4. 001aaa633 1.2 Peak pulse power as a function of exponential pulse duration; typical values PESD24VS1ULD Product data sheet Fig. 5. 0 100 150 Tj (°C) 200 Relative variation of peak pulse power as a function of junction temperature; typical values All information provided in this document is subject to legal disclaimers. 22 August 2018 50 © Nexperia B.V. 2018. All rights reserved 4 / 11 PESD24VS1ULD Nexperia Unidirectional ESD protection diode 006aac489 50 006aac490 10 Cd (pF) IRM 40 IRM(25°C) 30 1 20 10 0 0 5 10 15 20 VR (V) 10- 1 - 100 25 f = 1 MHz; Tamb = 25 °C Fig. 6. Fig. 7. Diode capacitance as a function of reverse voltage; typical values - 50 0 50 100 Tj (°C) 150 Relative variation of reverse leakage current as a function of junction temperature; typical values I V -VCL -VBR -VRWM -IRM -IR - + P-N -IPP 006aaa407 Fig. 8. V-I characteristics for unidirectional ESD protection diode PESD24VS1ULD Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2018 © Nexperia B.V. 2018. All rights reserved 5 / 11 PESD24VS1ULD Nexperia Unidirectional ESD protection diode ESD TESTER 4 GHz DIGITAL OSCILLOSCOPE RG 223/U 50 Ω coax RZ 40 dB ATTENUATOR CZ 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 network CZ = 150 pF; RZ = 330 Ω vertical scale = 2 kV/div horizontal scale = 15 ns/div GND vertical scale = 20 V/div horizontal scale = 10 ns/div GND unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) clamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) pin 1 to 2 vertical scale = 2 kV/div horizontal scale = 15 ns/div GND GND vertical scale = 20 V/div horizontal scale = 10 ns/div unclamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) Fig. 9. clamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) pin 1 to 2 006aac491 ESD clamping test setup and waveforms PESD24VS1ULD Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2018 © Nexperia B.V. 2018. All rights reserved 6 / 11 PESD24VS1ULD Nexperia Unidirectional ESD protection diode 10. Application information The device is designed for the protection of one unidirectional data line from surge pulses and ESD damage. The device is suitable on lines where the signal polarities are either positive or negative with respect to ground. The device provides a surge capability of 150 W for an 8/20 µs waveform. line to be protected (positive signal polarity) line to be protected (negative signal polarity) ESD protection diode ESD protection diode GND GND unidirectional protection of one line aaa-002440 Fig. 10. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. 2. 3. 4. 5. 6. 7. 8. Place the device as close to the input terminal or connector as possible. Minimize the path length between the device and the protected line. Keep parallel signal paths to a minimum. Avoid running protected conductors in parallel with unprotected conductors. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. Minimize the length of the transient return path to ground. Avoid using shared transient return paths to a common ground point. Use ground planes whenever possible. For multilayer PCBs, use ground vias. 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PESD24VS1ULD Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2018 © Nexperia B.V. 2018. All rights reserved 7 / 11 PESD24VS1ULD Nexperia Unidirectional ESD protection diode 12. Package outline 0.65 0.55 0.4 max 2 0.30 0.22 1.05 0.95 0.65 1 0.30 0.22 0.55 0.45 cathode marking on top side (if applicable) Dimensions in mm 12-05-01 Fig. 11. Package outline DFN1006D-2 (SOD882D) 13. Soldering 1.4 0.2 solder lands 0.8 (2×) 0.6 (2×) solder resist 0.7 (2×) solder paste Dimensions in mm 0.3 0.4 1 1.3 sod882d_fr Fig. 12. Reflow soldering footprint for DFN1006D-2 (SOD882D) PESD24VS1ULD Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2018 © Nexperia B.V. 2018. All rights reserved 8 / 11 PESD24VS1ULD Nexperia Unidirectional ESD protection diode 14. Revision history Table 7. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PESD24VS1ULD v.2 20180822 Product data sheet - PESD24VS1ULD v.1 Modifications: • • • • PESD24VS1ULD v.1 PESD24VS1ULD Product data sheet Application information: updated. Package drawing: updated. The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 20101019 Product data sheet - All information provided in this document is subject to legal disclaimers. 22 August 2018 - © Nexperia B.V. 2018. All rights reserved 9 / 11 PESD24VS1ULD Nexperia Unidirectional ESD protection diode equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or PESD24VS1ULD Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2018 © Nexperia B.V. 2018. All rights reserved 10 / 11 PESD24VS1ULD Nexperia Unidirectional ESD protection diode Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Application information............................................... 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Characteristics.............................................................. 4 10. Application information............................................. 7 11. Test information.......................................................... 7 12. Package outline.......................................................... 8 13. Soldering..................................................................... 8 14. Revision history..........................................................9 15. Legal information......................................................10 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 22 August 2018 PESD24VS1ULD Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2018 © Nexperia B.V. 2018. All rights reserved 11 / 11 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: PESD24VS1ULD,315
PESD24VS1ULD,315
1. 物料型号:PESD24VS1ULD,315 2. 器件简介:PESD24VS1ULD,315 是由Nexperia生产的ESD保护二极管,用于保护低压信号线路免受静电放电(ESD)的损害。 3. 引脚分配:该器件为SOD-923封装,具有两个引脚,分别是阳极(A)和阴极(C)。 4. 参数特性: - 最大工作电压:24V - 最大箝位电压:5.0V - 最大脉冲电流:3.1A - 电容:35pF - 封装类型:SOD-923 5. 功能详解:该器件主要用于保护低压信号线路,如数据线、I/O端口等,防止静电放电造成的损害。 6. 应用信息:适用于各种低压信号线路的ESD保护,如USB接口、HDMI接口、音频/视频接口等。 7. 封装信息:SOD-923封装,是一种小型表面贴装封装,适用于自动贴装工艺。
PESD24VS1ULD,315 价格&库存
很抱歉,暂时无法提供与“PESD24VS1ULD,315”相匹配的价格&库存,您可以联系我们找货
PESD24VS1ULD,315
  • 1+2.291481+0.29702
  • 10+1.4185810+0.18388
  • 100+0.87961100+0.11402
  • 500+0.64498500+0.08361
  • 1000+0.568841000+0.07374
  • 2000+0.504682000+0.06542
  • 5000+0.434985000+0.05638
库存:7
PESD24VS1ULD,315
    PESD24VS1ULD,315
    • 1+0.46310
    • 100+0.31900
    • 500+0.29040
    • 2500+0.26950
    • 5000+0.25190
    • 10000+0.23100
    库存:6
    PESD24VS1ULD,315
    • 10000+0.3905110000+0.05062
    • 20000+0.3542520000+0.04592
    • 30000+0.3357730000+0.04353
    • 50000+0.3150050000+0.04083
    • 70000+0.3027070000+0.03924
    • 100000+0.29073100000+0.03769
    库存:7
