SM3521-101MT
SM3521-101MT
    SXN(顺翔诺)
    SMD,3.5x3mm
    功率电感 100µH ±20% IND_D3.5X3MM_SM 2.10mm Φ3.50 x 3.00mm 2.8Ω 200mA 6.8MHz
SM3521-101MT 数据手册
MINIATURE SMD CHIP CHOKE COILS 非 屏 蔽 贴 片 功 率 电 感 Unshielded SMD Power Inductors O p e r a t i n g Te m p : - 2 0 ℃ ~ 8 5 ℃ 特征: FEATURES:  镀银型,低成本的设计。 ● Silver plated type, Low cost design.  具有高功率,强力高饱和电流。 ● High power, high saturation inductors.  交易电感器的直流-直流转换。 ●  适用于编带和自动电器表面安装。 ● Available on tape and reelfor auto surface mounting. Ideal inductorsfor DC-DC conversion. 用途: APPLICATIONS:  录影机。 ● Power supply for VTRs.  液晶电视。 ● LCD televisions.  笔记本电脑。 ● Notebook PCs.  小型通信机器。 ● Portable communication equipment.  DC/DC 变压器之电源供应器等。 ● DC/DC converters, etc. PRODUCT 产品型号: IDENTIFICATION: SM 1054 100 K T ① ② ③ ④ ⑤ ① ② ③ 类型 Type 非屏蔽贴片功率电感 SM 外形尺寸(L×H) (mm) Inductance External Dimensions (L×H) (mm) 10 uH Unshielded SMT Power Inductors ④ 1054 10×5.4 ⑤ Tolerance 包装 Packing J:±5%,K: ±10%, L: ±15% B 散装 Bulk Package M: ±20%,P: ±25%, N: ±30% T 编带Tape & Reel Shape and Size(Dimension are in mm): ※48.0 MINIATURE SMD CHIP CHOKE COILS Part No A B C H I J SM3511 3.5±0.3 3.0±0.3 1.1±0.2 3.5 1.6 0.8 SM3516 3.5±0.3 3.0±0.3 1.6±0.2 3.5 1.6 0.8 SM3521 3.5±0.3 3.0±0.3 2.1±0.3 3.5 1.6 0.8 SM4532 4.5±0.3 4.0±0.3 3.2±0.3 4.5 1.75 1.5 SM5825 5.8±0.3 5.2±0.3 2.5±0.3 5.5 2.15 1.7 SM5835 5.8±0.3 5.2±0.3 3.5±0.3 5.5 2.15 1.7 SM5845 5.8±0.3 5.2±0.3 4.5±0.35 5.5 2.15 1.7 SM7835 7.8±0.3 7.0±0.3 3.5±0.5 7.5 3.0 2.0 SM7850 7.8±0.3 7.0±0.3 5.0±0.5 7.5 3.0 2.0 SM1040 10.0±0.3 9.0±0.3 4.0±0.5 9.5 3.75 2.5 SM1054 10.0±0.3 9.0±0.3 5.4±0.5 9.5 3.75 2.5 SM3511 Series Inductance(uH) Part No. Nominal Value Tole. Quality Factor DCR SRF Rated DC (OHM) (MHz) Current Test Spec. Test Freq. Min Freq. Max Min (Amp)Max SM3511-2R2M 2.2 M 100KHz 20 1MHz 0.24 62 1.0 SM3511-3R3M 3.3 M 100KHz 20 1MHz 0.27 47 0.90 SM3511-4R7M 4.7 M 100KHz 30 1MHz 0.30 38 0.80 SM3511-6R8M 6.8 M 100KHz 30 1MHz 0.47 31 0.76 SM3511-8R2M 8.2 M 100KHz 30 1MHz 0.52 27 0.72 SM3511-100M 10.0 M 100KHz 30 1MHz 0.55 23 0.66 SM3511-120M 12.0 M 100KHz 30 1MHz 0.75 21 0.54 SM3511-150M 15.0 M 100KHz 30 1MHz 0.91 19 0.45 SM3511-220M 22.0 M 100KHz 30 1MHz 1.20 15 0.36 SM3511-270M 27.0 M 100KHz 30 1MHz 1.50 14 0.30 Quality Factor DCR SRF Rated DC (OHM) (MHz) Current SM3516 Series Inductance(uH) Part No. Nominal Value Tole. Test Spec. Test Freq. Min Freq. Max Min (Amp)Max SM3516-2R2M 2.2 M 100KHz 20 1MHz 0.24 62 1.20 SM3516-3R3M 3.3 M 100KHz 20 1MHz 0.27 47 1.08 SM3516-4R7M 4.7 M 100KHz 30 1MHz 0.30 38 1.00 SM3516-6R8M 6.8 M 100KHz 30 1MHz 0.47 31 0.80 SM3516-8R2M 8.2 M 100KHz 30 1MHz 0.52 27 0.76 SM3516-100M 10.0 M 100KHz 30 1MHz 0.55 23 0.70 SM3516-120M 12.0 M 100KHz 30 1MHz 0.75 21 0.60 SM3516-150M 15.0 M 100KHz 30 1MHz 0.91 19 0.50 SM3516-220M 22.0 M 100KHz 30 1MHz 1.20 15 0.40 SM3516-270M 27.0 M 100KHz 30 1MHz 1.50 14 0.36 ※49.0 MINIATURE SMD CHIP CHOKE COILS SM3521 Series Inductance(uH) Part No. Nominal Value Tole. Quality Factor DCR SRF Rated DC (OHM) (MHz) Current Test Spec. Test Freq Min Freq. Max Min (Amp)Max SM3521-1R0M 1.0 M 100KHz 20 1MHz 0.045 120 2.20 SM3521-1R2M 1.2 M 100KHz 20 1MHz 0.050 100 2.10 SM3521-1R5M 1.5 M 100KHz 20 1MHz 0.055 85 1.70 SM3521-1R8M 1.8 M 100KHz 20 1MHz 0.070 75 1.65 SM3521-2R2M 2.2 M 100KHz 20 1MHz 0.085 62 1.60 SM3521-2R7M 2.7 M 100KHz 20 1MHz 0.100 53 1.40 SM3521-3R3M 3.3 M 100KHz 20 1MHz 0.120 47 1.04 SM3521-3R9M 3.9 M 100KHz 20 1MHz 0.125 41 1.00 SM3521-4R7M 4.7 M 100KHz 30 1MHz 0.135 38 1.00 SM3521-5R6M 5.6 M 100KHz 30 1MHz 0.145 33 0.95 SM3521-6R8M 6.8 M 100KHz 30 1MHz 0.20 31 0.95 SM3521-8R2M 8.2 M 100KHz 30 1MHz 0.25 27 0.92 SM3521-100M 10 M 100KHz 35 1MHz 0.32 23 0.90 SM3521-120M 12 M 100KHz 35 1MHz 0.35 21 0.85 SM3521-150M 15 M 100KHz 35 1MHz 0.46 19 0.75 SM3521-180M 18 M 100KHz 35 1MHz 0.52 17 0.70 SM3521-220M 22 M 100KHz 35 1MHz 0.65 15 0.60 SM3521-270M 27 M 100KHz 35 1MHz 0.75 14 0.55 SM3521-330M 33 M 100KHz 35 1MHz 0.92 12 0.50 SM3521-390M 39 M 100KHz 35 1MHz 1.12 11 0.48 SM3521-470M 47 M 100KHz 35 1MHz 1.27 10 0.45 SM3521-560M 56 M 100KHz 35 1MHz 1.50 9.3 0.30 SM3521-680M 68 M 100KHz 35 1MHz 2.00 8.4 0.26 SM3521-820M 82 M 100KHz 35 1MHz 2.15 7.5 0.23 SM3521-101M 100 M 100KHz 40 796MHz 2.80 6.8 0.20 SM3521-121K 120 K 100KHz 40 796MHz 3.40 6.2 0.18 SM3521-151K 150 K 100KHz 40 796MHz 4.20 5.5 0.16 SM3521-181K 180 K 100KHz 40 796MHz 4.50 5.0 0.15 SM3521-221K 220 K 100KHz 40 796MHz 5.70 4.5 0.14 SM3521-271K 270 K 100KHz 40 796MHz 8.50 4.0 0.10 SM3521-331K 330 K 100KHz 40 796MHz 9.50 3.6 0.09 ※50.0 MINIATURE SMD CHIP CHOKE COILS SM4532 Series Inductance(uH) Part No. Nominal Value Tole. Quality Factor DCR SRF (OHM) (MHz) Current Min (Amp)Max Test Spec. Test Freq Min Freq. Max Rated DC SM4532-1R0M 1.0 M 100KHz 20 1MHz 0.0487 120 2.56 SM4532-1R4M 1.4 M 100KHz 20 1MHz 0.0562 95 2.52 SM4532-1R8M 1.8 M 100KHz 20 1MHz 0.0637 75 1.95 SM4532-2R2M 2.2 M 100KHz 20 1MHz 0.0712 62 1.75 SM4532-2R7M 2.7 M 100KHz 20 1MHz 0.0787 53 1.58 SM4532-3R3M 3.3 M 100KHz 20 1MHz 0.0862 47 1.44 SM4532-3R9M 3.9 M 100KHz 20 1MHz 0.0937 41 1.33 SM4532-4R7M 4.7 M 100KHz 30 1MHz 0.1087 38 1.15 SM4532-5R6M 5.6 M 100KHz 30 1MHz 0.1257 33 0.99 SM4532-6R8M 6.8 M 100KHz 30 1MHz 0.1312 31 0.95 SM4532-8R2M 8.2 M 100KHz 30 1MHz 0.1462 27 0.84 SM4532-100M 10 M 100KHz 35 1MHz 0.182 23 1.04 SM4532-120M 12 M 100KHz 35 1MHz 0.210 21 0.97 SM4532-150M 15 M 100KHz 35 1MHz 0.235 19 0.85 SM4532-180M 18 M 100KHz 35 1MHz 0.338 17 0.74 SM4532-220M 22 M 100KHz 35 1MHz 0.378 15 0.68 SM4532-270M 27 M 100KHz 35 1MHz 0.522 14 0.62 SM4532-330M 33 M 100KHz 35 1MHz 0.540 12 0.56 SM4532-390M 39 M 100KHz 35 1MHz 0.587 11 0.52 SM4532-470K 47 K 100KHz 35 1MHz 0.844 10 0.44 SM4532-560K 56 K 100KHz 35 1MHz 0.937 9.3 0.42 SM4532-680K 68 K 100KHz 35 1MHz 1.117 8.4 0.37 ※51.0 MINIATURE SMD CHIP CHOKE COILS SM5825 Series Inductance(uH) Part No. Nominal Value Tole. Quality Factor DCR SRF (OHM) (MHz) Current Min (Amp)Max Test Spec. Test Freq Min Freq. Max Rated DC SM5825-1R2M 1.2 M 100KHz 20 1MHz 0.050 100 4.20 SM5825-1R5M 1.5 M 100KHz 20 1MHz 0.060 85 4.00 SM5825-1R8M 1.8 M 100KHz 20 1MHz 0.065 75 3.70 SM5825-2R2M 2.2 M 100KHz 20 1MHz 0.07 62 3.50 SM5825-2R7M 2.7 M 100KHz 20 1MHz 0.08 53 3.20 SM5825-3R3M 3.3 M 100KHz 20 1MHz 0.10 47 2.70 SM5825-3R9M 3.9 M 100KHz 20 1MHz 0.12 41 2.40 SM5825-4R7M 4.7 M 100KHz 30 1MHz 0.14 38 2.00 SM5825-5R6M 5.6 M 100KHz 30 1MHz 0.15 33 1.80 SM5825-6R8M 6.8 M, 100KHz 30 1MHz 0.16 31 1.50 SM5825-8R2M 8.2 M 100KHz 30 1MHz 0.18 27 1.40 SM5825-100M 10 M 100KHz 35 1MHz 0.20 23 1.30 SM5825-120M 12 M 100KHz 35 1MHz 0.23 21 1.10 SM5825-150M 15 M 100KHz 35 1MHz 0.25 19 1.05 SM5825-180M 18 M 100KHz 35 1MHz 0.30 17 1.00 SM5825-220M 22 M 100KHz 35 1MHz 0.35 15 0.90 SM5825-270M 27 M 100KHz 35 1MHz 0.40 14 0.85 SM5825-330M 33 M 100KHz 35 1MHz 0.50 12 0.75 SM5825-390M 39 M 100KHz 35 1MHz 0.55 11 0.70 SM5825-470K 47 K 100KHz 35 1MHz 0.65 10 0.60 SM5825-560K 56 K 100KHz 35 1MHz 0.75 9.3 0.55 SM5825-680K 68 K 100KHz 35 1MHz 0.95 8.4 0.50 SM5825-820K 82 K 100KHz 35 1MHz 1.20 7.5 0.45 SM5825-101K 100 K 100KHz 40 796MHz 1.40 6.8 0.40 SM5825-121K 120 K 100KHz 40 796MHz 1.75 6.2 0.35 SM5825-151K 150 K 100KHz 40 796MHz 2.00 5.5 0.25 SM5825-181K 180 K 100KHz 40 796MHz 2.60 5.0 0.22 SM5825-221K 220 K 100KHz 40 796MHz 3.00 4.5 0.20 SM5825-271K 270 K 100KHz 40 796MHz 3.70 4.0 0.18 SM5825-331K 330 K 100KHz 40 796MHz 4.30 3.6 0.17 SM5825-391K 390 K 100KHz 40 796MHz 6.00 3.0 0.16 SM5825-471 470 K 100KHz 40 796MHz 6.70 2.7 0.15 ※52.0 MINIATURE SMD CHIP CHOKE COILS SM5830 Series Inductance(uH) Part No. Nominal Value Tole. Quality Factor DCR SRF Rated DC (OHM) (MHz) Current Test Spec. Test Freq. Min Freq. Max Min (Amp)Max SM5830-1R0M 1.0 M 100KHz 20 1MHz 0.03 120 4.50 SM5830-1R2M 1.2 M 100KHz 20 1MHz 0.03 100 4.20 SM5830-1R5M 1.5 M 100KHz 20 1MHz 0.03 85 4.10 SM5830-1R8M 1.8 M 100KHz 20 1MHz 0.03 75 3.70 SM5830-2R2M 2.2 M 100KHz 20 1MHz 0.03 62 3.50 SM5830-2R7M 2.7 M 100KHz 20 1MHz 0.04 53 3.20 SM5830-3R3M 3.3 M 100KHz 20 1MHz 0.05 47 2.80 SM5830-3R9M 3.9 M 100KHz 20 1MHz 0.06 41 2.60 SM5830-4R7M 4.7 M 100KHz 30 1MHz 0.07 38 2.50 SM5830-5R6M 5.6 M 100KHz 30 1MHz 0.08 33 2.40 SM5830-6R8M 6.8 M 100KHz 30 1MHz 0.09 31 2.20 SM5830-8R2M 8.2 M 100KHz 30 1MHz 0.10 27 2.00 SM5830-100M 10 M 100KHz 35 1MHz 0.13 23 1.80 SM5830-120M 12 M 100KHz 35 1MHz 0.16 21 1.75 SM5830-150M 15 M 100KHz 35 1MHz 0.19 19 1.70 SM5830-180M 18 M 100KHz 35 1MHz 0.21 17 1.60 SM5830-220M 22 M 100KHz 35 1MHz 0.28 15 1.50 SM5830-270M 27 M 100KHz 35 1MHz 0.32 14 1.40 SM5830-330M 33 M 100KHz 35 1MHz 0.38 12 1.10 SM5830-390M 39 M 100KHz 35 1MHz 0.42 11 1.00 SM5830-470K 47 K 100KHz 35 1MHz 0.52 10 0.90 SM5830-560K 56 K 100KHz 35 1MHz 0.56 9.3 0.85 SM5830-680K 68 K 100KHz 35 1MHz 0.68 8.4 0.80 SM5830-820K 82 K 100KHz 35 1MHz 0.82 7.5 0.65 SM5830-101K 100 K 100KHz 40 796MHz 1.10 6.8 0.60 SM5830-121K 120 K 100KHz 40 796MHz 1.20 6.2 0.58 SM5830-151K 150 K 100KHz 40 796MHz 1.50 5.5 0.43 SM5830-181K 180 K 100KHz 40 796MHz 1.80 5.0 0.41 SM5830-221K 220 K 100KHz 40 796MHz 2.00 4.5 0.37 SM5830-271K 270 K 100KHz 40 796MHz 2.90 4.0 0.35 SM5830-331K 330 K 100KHz 40 796MHz 3.30 3.6 0.28 SM5830-391K 390 K 100KHz 40 796MHz 3.70 3.0 0.260 SM5830-471K 470 K 100KHz 40 796MHz 4.90 2.7 0.200 ※53.0 MINIATURE SMD CHIP CHOKE COILS SM5845 Series Inductance(uH) Part No. Nominal Value Tole. Quality Factor DCR SRF (OHM) (MHz) Current Min (Amp)Max Test Spec. Test Freq. Min Freq. Max Rated DC SM5845-100M 10 M 100KHz 35 1MHz 0.10 23 1.44 SM5845-120M 12 M 100KHz 35 1MHz 0.12 21 1.40 SM5845-150M 15 M 100KHz 35 1MHz 0.14 19 1.30 SM5845-180M 18 M 100KHz 35 1MHz 0.15 17 1.23 SM5845-220M 22 M 100KHz 35 1MHz 0.18 15 1.11 SM5845-270M 27 M 100KHz 35 1MHz 0.20 14 0.97 SM5845-330M 33 M 100KHz 35 1MHz 0.23 12 0.88 SM5845-390M 39 M 100KHz 35 1MHz 0.32 11 0.80 SM5845-470K 47 K 100KHz 35 1MHz 0.37 10 0.72 SM5845-560K 56 K 100KHz 35 1MHz 0.42 9.3 0.68 SM5845-680K 68 K 100KHz 35 1MHz 0.46 8.4 0.61 SM5845-820K 82 K 100KHz 35 1MHz 0.60 7.5 0.58 SM5845-101K 100 K 100KHz 40 796MHz 0.70 6.8 0.52 SM5845-121K 120 K 100KHz 40 796MHz 0.93 6.2 0.48 SM5845-151K 150 K 100KHz 40 796MHz 1.10 5.5 0.40 SM5845-181K 180 K 100KHz 40 796MHz 1.83 5.0 0.38 SM5845-221K 220 K 100KHz 40 796MHz 1.57 4.5 0.35 DCR SRF Rated DC (OHM) (MHz) Current SM7835 Series Inductance(uH) Part No. Nominal Value Tole. Quality Factor Test Spec. Test Freq. Min Freq. Max Min (Amp)Max SM7835-100M 10 M 100KHz 20 1MHz 0.0803 120 1.44 SM7835-120M 12 M 100KHz 20 1MHz .0897 100 1.39 SM7835-150M 15 M 100KHz 20 1MHz 0.104 95 1.24 SM7835-180M 18 M 100KHz 20 1MHz 0.111 85 1.12 SM7835-220M 22 M 100KHz 20 1MHz 0.129 75 1.07 SM7835-270M 27 M 100KHz 20 1MHz 0.153 62 0.94 SM7835-330M 33 M 100KHz 20 1MHz 0.170 53 0.85 SM7835-390M 39 M 100KHz 20 1MHz 0.217 47 0.74 SM7835-470K 47 K 100KHz 20 1MHz 0.252 41 0.68 SM7835-560K 56 K 100KHz 30 1MHz 0.282 38 0.64 SM7835-680K 68 K 100KHz 30 1MHz 33 0.59 SM7835-820K 82 K 100KHz 30 1MHz 0.406 31 0.54 SM7835-101K 100 K 100KHz 30 1MHz 0.481 27 0.51 SM7835-121K 120 K 100KHz 35 1MHz 0.536 23 0.49 0.332 ※54.0 MINIATURE SMD CHIP CHOKE COILS SM7835 Series Inductance(uH) Part No. Nominal Value Tole. Quality Factor DCR SRF Rated DC (OHM) (MHz) Current Test Spec. Test Freq. Min Freq. Max Min (Amp)Max SM7835-121K 120 K 100KHz 35 1MHz 0.536 23 0.49 SM7835-151K 150 K 100KHz 35 1MHz 0.755 21 0.40 SM7835-181K 180 K 100KHz 35 1MHz 1.022 19 0.36 SM7835-221K 220 K 100KHz 35 1MHz 1.200 17 0.31 SM7835-271K 270 K 100KHz 35 1MHz 1.306 15 0.29 SM7835-331K 330 K 100KHz 35 1MHz 1.495 14 0.28 Quality Factor DCR SRF Rated DC (OHM) (MHz) Current SM7850 Series Inductance(uH) Part No. Nominal Value Tole. Test Spec. Test Freq. Min Freq. Max Min (Amp)Max SM7850-100M 10 M 100KHz 20 1MHz 0.07 120 2.30 SM7850-120M 12 M 100KHz 20 1MHz 0.08 100 2.00 SM7850-150M 15 M 100KHz 20 1MHz 0.09 95 1.80 SM7850-180M 18 M 100KHz 20 1MHz 0.10 85 1.60 SM7850-220M 22 M 100KHz 20 1MHz 0.11 75 1.50 SM7850-270M 27 M 100KHz 20 1MHz 0.12 62 1.30 SM7850-330M 33 M 100KHz 20 1MHz 0.13 53 1.20 SM7850-390M 39 M 100KHz 20 1MHz 0.16 47 1.10 SM7850-470K 47 K 100KHz 20 1MHz 0.18 41 1.10 SM7850-560K 56 K 100KHz 30 1MHz 0.24 38 0.94 SM7850-680K 68 K 100KHz 30 1MHz 0.28 33 0.85 SM7850-820K 82 K 100KHz 30 1MHz 0.37 31 0.78 SM7850-101K 100 K 100KHz 30 1MHz 0.43 27 0.72 SM7850-121K 120 K 100KHz 35 1MHz 0.47 23 0.66 SM7850-151K 150 K 100KHz 35 1MHz 0.64 21 0.58 SM7850-181K 180 K 100KHz 35 1MHz 0.71 19 0.51 SM7850-221K 220 K 100KHz 35 1MHz 0.96 17 0.49 SM7850-271K 270 K 100KHz 35 1MHz 1.11 15 0.42 SM7850-331K 330 K 100KHz 35 1MHz 1.26 14 0.40 SM7850-391K 390 K 100KHz 35 1MHz 1.77 12 0.36 SM7850-471K 470 K 100KHz 35 1MHz 1.96 11 0.34 ※55.0 MINIATURE SMD CHIP CHOKE COILS SM1040Series Inductance(uH) Part No. Nominal Value Tole. Quality Factor DCR SRF Rated DC (OHM) (MHz) Current Test Spec. Test Freq. Min Freq. Max Min (Amp)Max SM1040-100M 10 M 100KHz 20 1MHz 0.053 120 2.38 SM1040-120M 12 M 100KHz 20 1MHz 0.061 100 2.13 SM1040-150M 15 M 100KHz 20 1MHz 0.070 95 1.87 SM1040-180M 18 M 100KHz 20 1MHz 0.071 85 1.73 SM1040-220M 22 M 100KHz 20 1MHz 0.088 75 1.60 SM1040-270M 27 M 100KHz 20 1MHz 0.100 62 1.44 SM1040-330M 33 M 100KHz 20 1MHz 0.120 53 1.26 SM1040-390M 39 M 100KHz 20 1MHz 0.151 47 1.20 SM1040-470K 47 K 100KHz 20 1MHz 0.170 41 1.10 SM1040-560K 56 K 100KHz 30 1MHz 0.199 38 1.01 SM1040-680K 68 K 100KHz 30 1MHz 0.223 33 0.91 SM1040-820K 82 K 100KHz 30 1MHz 0.252 31 0.85 SM1040-101K 100 K 100KHz 30 1MHz 0.344 27 0.74 SM1040-121K 120 K 100KHz 35 1MHz 0.396 23 0.69 SM1040-151K 150 K 100KHz 35 1MHz 0.544 21 0.61 SM1040-181K 180 K 100KHz 35 1MHz 0.621 19 0.56 SM1040-221K 220 K 100KHz 35 1MHz 0.721 17 0.53 SM1040-271K 270 K 100KHz 35 1MHz 0.949 15 0.45 SM1040-331K 330 K 100KHz 35 1MHz 1.100 14 0.42 SM1040-391K 390 K 100KHz 35 1MHz 1.245 12 0.38 SM1040-471K 470 K 100KHz 35 1MHz 1.526 11 0.35 SM1040-561K 560 K 100KHz 35 1MHz 1.904 10 0.32 Quality Factor DCR SRF Rated DC (OHM) (MHz) Current SM1054 Series Inductance(uH) Part No. Nominal Value Tole. Test Spec. Test Freq. Min Freq. Max Min (Amp)Max SM1054-100M 10 M 100KHz 20 1MHz 0.06 120 2.60 SM1054-120M 12 M 100KHz 20 1MHz 0.07 100 2.45 SM1054-150M 15 M 100KHz 20 1MHz 0.08 95 2.27 SM1054-180M 18 M 100KHz 20 1MHz 0.09 85 2.15 SM1054-220M 22 M 100KHz 20 1MHz 0.10 75 1.95 SM1054-270M 27 M 100KHz 20 1MHz 0.11 62 1.76 SM1054-330M 33 M 100KHz 20 1MHz 0.12 53 1.50 SM1054-390M 39 M 100KHz 20 1MHz 0.14 47 1.37 ※56.0 MINIATURE SMD CHIP CHOKE COILS SM105 Series Inductance(uH) Part No. Nominal Value Tole. Quality Factor DCR SRF Rated DC (OHM) (MHz) Current Test Spec. Test Freq. Min Freq. Max Min (Amp)Max SM1054-470K 47 K 100KHz 20 1MHz 0.17 41 1.28 SM1054-560K 56 K 100KHz 30 1MHz 0.19 38 1.17 SM1054-680K 68 K 100KHz 30 1MHz 0.22 33 1.11 SM1054-820K 82 K 100KHz 30 1MHz 0.25 31 1.00 SM1054-101K 100 K 100KHz 30 1MHz 0.35 27 0.97 SM1054-121K 120 K 100KHz 35 1MHz 0.40 23 0.89 SM1054-151K 150 K 100KHz 35 1MHz 0.47 21 0.78 SM1054-181K 180 K 100KHz 35 1MHz 0.63 19 0.72 SM1054-221K 220 K 100KHz 35 1MHz 0.73 17 0.66 SM1054-271K 270 K 100KHz 35 1MHz 0.97 15 0.57 SM1054-331K 330 K 100KHz 35 1MHz 1.15 14 0.52 SM1054-391K 390 K 100KHz 35 1MHz 1.30 12 0.48 SM1054-471K 470 K 100KHz 35 1MHz 1.48 11 0.42 SM1054-561K 560 K 100KHz 35 1MHz 1.90 10 0.33 SM1054-681K 680 K 100KHz 35 1MHz 2.25 9.3 0.28 SM1054-821K 820 K 100KHz 35 1MHz 2.55 8.4 0.24 ※57.0
SM3521-101MT 价格&库存
很抱歉,暂时无法提供与“SM3521-101MT”相匹配的价格&库存,您可以联系我们找货
SM3521-101MT
  • 10+0.25451
  • 100+0.20279
  • 600+0.17689
  • 1200+0.17424
库存:931
