SIT9121AI-2D2-25E135.000000Y
    SITIME(赛特时脉)
    SMD7050_6P
    有源晶振 ±25ppm 2.5V 135MHz SMD7050_6P
SIT9121AI-2D2-25E135.000000Y 数据手册
SiT9121 1-220 MHz High Performance Differential Oscillator The Smart Timing Choice Features Applications  Any frequency between 1 MHz and 220 MHz accurate to 6 decimal places  10GB Ethernet, SONET, SATA, SAS, Fibre Channel, PCI-Express  LVPECL and LVDS output signaling types  Telecom, networking, instrumentation, storage, servers  0.6ps RMS phase jitter (random) over 12 kHz to 20 MHz bandwidth  Frequency stability as low as ±10 ppm  Industrial and extended commercial temperature ranges  Industry-standard packages: 3.2x2.5, 5.0x3.2 and 7.0x5.0 mmxmm  For frequencies higher than 220 MHz, refer to SiT9122 datasheet Electrical Characteristics Parameter and Conditions Symbol Min. Typ. Max. Unit Condition LVPECL and LVDS, Common Electrical Characteristics Supply Voltage Output Frequency Range Frequency Stability Vdd f F_stab 2.97 3.3 3.63 V 2.25 2.5 2.75 V 2.25 – 3.63 V 1 – 220 MHz -10 – +10 ppm -20 – +20 ppm -25 – +25 ppm Termination schemes in Figures 1 and 2 - XX ordering code Inclusive of initial tolerance, operating temperature, rated power supply voltage, and load variations -50 – +50 ppm First Year Aging F_aging1 -2 – +2 ppm 25°C 10-year Aging F_aging10 -5 – +5 ppm 25°C T_use -40 – +85 °C -20 – +70 °C – – Vdd Operating Temperature Range Industrial Extended Commercial Input Voltage High VIH 70% Input Voltage Low VIL – – 30% Vdd Pin 1, OE or ST Input Pull-up Impedance Z_in – 100 250 kΩ Pin 1, OE logic high or logic low, or ST logic high 2 – – MΩ Pin 1, ST logic low – 6 10 ms Measured from the time Vdd reaches its rated minimum value. – 6 10 ms – 55 % Start-up Time T_start Resume Time T_resume Duty Cycle DC 45 Pin 1, OE or ST In Standby mode, measured from the time ST pin crosses 50% threshold. Contact SiTime for tighter duty cycle LVPECL, DC and AC Characteristics Current Consumption Idd – 61 69 mA Excluding Load Termination Current, Vdd = 3.3V or 2.5V OE Disable Supply Current I_OE – – 35 mA OE = Low Output Disable Leakage Current I_leak – – 1 µA OE = Low Standby Current I_std – – 100 µA ST = Low, for all Vdds I_driver – – 30 mA Maximum average current drawn from OUT+ or OUT- Output High Voltage VOH Vdd-1.1 – Vdd-0.7 V Output Low Voltage VOL Vdd-1.9 – Vdd-1.5 V See Figure 1(a) V_Swing 1.2 1.6 2.0 V See Figure 1(b) Rise/Fall Time Tr, Tf – 300 700 ps 20% to 80%, see Figure 1(a) OE Enable/Disable Time RMS Period Jitter T_oe T_jitt – – – – – 1.2 1.2 1.2 115 1.7 1.7 1.7 ns ps ps ps RMS Phase Jitter (random) T_phj – 0.6 0.85 ps f = 212.5 MHz - For other frequencies, T_oe = 100ns + 3 period f = 100 MHz, VDD = 3.3V or 2.5V f = 156.25 MHz, VDD = 3.3V or 2.5V f = 212.5 MHz, VDD = 3.3V or 2.5V f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdds Maximum Output Current Output Differential Voltage Swing See Figure 1(a) LVDS, DC and AC Characteristics Current Consumption Idd – 47 55 mA Excluding Load Termination Current, Vdd = 3.3V or 2.5V OE Disable Supply Current I_OE – – 35 mA OE = Low Differential Output Voltage VOD 250 350 450 mV See Figure 2 SiTime Corporation Rev. 1.07 990 Almanor Avenue, Sunnyvale, CA 94085 (408) 328-4400 www.sitime.com Revised January 4, 2016 SiT9121 1-220 MHz High Performance Differential Oscillator The Smart Timing Choice Electrical Characteristics (continued) Parameter and Conditions Symbol Min. Typ. Max. Unit Condition LVDS, DC and AC Characteristics (continued) Output Disable Leakage Current I_leak – – 1 µA Standby Current I_std – – 100 µA ST = Low, for all Vdds ∆VOD – – 50 mV See Figure 2 VOD Magnitude Change Offset Voltage OE = Low VOS 1.125 1.2 1.375 V See Figure 2 VOS Magnitude Change ∆VOS – – 50 mV See Figure 2 Rise/Fall Time Tr, Tf – 495 700 ps 20% to 80%, see Figure 2 OE Enable/Disable Time RMS Period Jitter T_oe T_jitt – – – – – 1.2 1.2 1.2 115 1.7 1.7 1.7 ns ps ps ps RMS Phase Jitter (random) T_phj – 0.6 0.85 ps f = 212.5 MHz - For other frequencies, T_oe = 100ns + 3 period f = 100 MHz, VDD = 3.3V or 2.5V f = 156.25 MHz, VDD = 3.3V or 2.5V f = 212.5 MHz, VDD = 3.3V or 2.5V f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdds Pin Description Pin Map Functionality OE Input H or Open: specified frequency output L: output is high impedance ST Input H or Open: specified frequency output L: Device goes to sleep mode. Supply current reduces to I_std. OE/ST 1 6 VDD NC NA No Connect; Leave it floating or connect to GND for better heat dissipation NC 2 5 OUT- GND 3 4 OUT+ 1 2 3 GND Power VDD Power Supply Ground 4 OUT+ Output Oscillator output 5 OUT- Output Complementary oscillator output 6 VDD Power Power supply voltage Top View Absolute Maximum Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Min. Max. Unit Storage Temperature Parameter -65 150 °C VDD -0.5 4 V Electrostatic Discharge (HBM) – 2000 V Soldering Temperature (follow standard Pb free soldering guidelines) – 260 °C Thermal Consideration θJA, 4 Layer Board θJC, Bottom Package (°C/W) (°C/W) 7050, 6-pin 142 27 5032, 6-pin 97 20 3225, 6-pin 109 20 Environmental Compliance Parameter Condition/Test Method Mechanical Shock MIL-STD-883F, Method 2002 Mechanical Vibration MIL-STD-883F, Method 2007 Temperature Cycle JESD22, Method A104 Solderability MIL-STD-883F, Method 2003 Moisture Sensitivity Level MSL1 @ 260°C Rev. 1.07 Page 2 of 8 www.sitime.com SiT9121 1-220 MHz High Performance Differential Oscillator The Smart Timing Choice Waveform Diagrams OUT80% 80% 20% 20% VOH OUT+ Tr VOL Tf GND Figure 1(a). LVPECL Voltage Levels per Differential Pin (OUT+/OUT-) V _ S w in g 0 V t Figure 1(b). LVPECL Voltage Levels Across Differential Pair OUT80% 80% VOD 20% 20% OUT+ VOS Tr Tf GND Figure 2. LVDS Voltage Levels per Differential Pin (OUT+/OUT-) Rev. 1.07 Page 3 of 8 www.sitime.com SiT9121 1-220 MHz High Performance Differential Oscillator The Smart Timing Choice Termination Diagrams LVPECL: VDD Z0 = 50 Ω OUT+ D+ Receiver Device L V P E C L D riv e r Z0 = 50 Ω OUT- D50 Ω 50 Ω VTT = VDD – 2.0 V Figure 3. LVPECL Typical Termination VDD= 3.3V => R1 = 100 to 150 Ω VDD= 2.5V => R1 = 75 Ω VDD 100 nF Z0 = 50 Ω OUT+ D+ Receiver Device LVPECL Driver 100 nF Z0 = 50 Ω OUTR1 R1 D50 Ω 50 Ω VTT Figure 4. LVPECL AC Coupled Termination VDD = 3.3V => R1 = R3 = 133 Ω and R2 = R4 = 82 Ω VDD = 2.5V => R1 = R3 = 250 Ω and R2 = R4 = 62.5 Ω VDD R1 VDD OUT+ R3 Z0 = 50 Ω D+ Receiver Device LVPECL Driver OUT- Z0 = 50 Ω DR2 R4 Figure 5. LVPECL with Thevenin Typical Termination Rev. 1.07 Page 4 of 8 www.sitime.com SiT9121 1-220 MHz High Performance Differential Oscillator The Smart Timing Choice LVDS: VDD OUT+ Z0 = 50 Ω D+ 100 Ω LVDS Driver OUT- Z0 = 50 Ω Receiver Device D- Figure 6. LVDS Single Termination (Load Terminated) Rev. 1.07 Page 5 of 8 www.sitime.com SiT9121 1-220 MHz High Performance Differential Oscillator The Smart Timing Choice Dimensions and Patterns Package Size – Dimensions (Unit: mm)[1] Recommended Land Pattern (Unit: mm)[2] 3.2 x 2.5x 0.75 mm 3.2±0.05 2.25 2.20 #4 #2 #3 #6 #1 #3 #2 1.00 0.7 0.9 YXXXX #5 #4 1.6 #5 2.5±0.05 #6 #1 0.6 0.65 1.05 0.75±0.05 5.0 x 3.2 x 0.75 mm #5 #4 #2 #3 #5 #4 #6 1.20 #6 YXXXX #1 #3 #2 #1 0.75±0.05 7.0 x 5.0x 0.90 mm 7.0±0.10 5.08 #6 #3 #3 #2 1.60 #2 5.08 #5 1.10 YXXXX #1 #4 3.80 #4 2.60 #5 5.0±0.10 #6 #1 0.90 ±0.10 1.40 1.60 Notes: 1. Top Marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the assembly location of the device. 2. A capacitor of value 0.1 µF between Vdd and GND is recommended. Rev. 1.07 Page 6 of 8 www.sitime.com SiT9121 1-220 MHz High Performance Differential Oscillator The Smart Timing Choice Ordering Information SiT9121AC-1C2-33E125.000000T Packaging: “T”, “Y”, “X”, “D”, “E” or “G” Refer to table below for packing method Leave Blank for Bulk Part Family “SiT9121” Revision Letter Frequency “A” is the revision of Silicon 1.000000 MHz to 220.000000 MHz Feature Pin “E” for Output Enable “S” for Standby Temperature Range “I” Industrial, -40 to 85°C “C” Extended Commercial, -20 to 70°C Voltage Supply “25” for 2.5V ±10% “33” for 3.3V ±10% “XX” for 2.25V to 3.63V Signalling Type “1” = LVPECL “2” = LVDS Package Size “B” 3.2 x 2.5 mm x mm “C” 5.0 x 3.2 mm x mm “D” 7.0 x 5.0 mm x mm Frequency Stability “F” for ±10 ppm “1” for ±20 ppm “2” for ±25 ppm “3” for ±50 ppm Ordering Codes for Supported Tape & Reel Packing Method Device Size 8 mm T&R (3ku) 8 mm T&R (1ku) 8 mm T&R (250u) 12 mm T&R (3ku) 12 mm T&R (1ku) 12 mm T&R (250u) 16 mm T&R (3ku) 16 mm T&R (1ku) 16 mm T&R (250u) 7.0 x 5.0 mm – – – – 5.0 x 3.2 mm – – – T – – T Y X Y X – – 3.2 x 2.5 mm D E G T Y – X – – – Frequencies Not Supported Range 1: From 209.000001 MHz to 210.999999 MHz Rev. 1.07 Page 7 of 8 www.sitime.com SiT9121 1-220 MHz High Performance Differential Oscillator The Smart Timing Choice Revision History s Version Release Date 1.01 2/20/13 Change Summary Original 1.02 12/3/13 Added input specifications, LVPECL/LVDS waveforms, packaging T&R options 1.03 2/6/14 Added 8mm T&R option and ±10 ppm 1.04 4/8/14 Included 1.8V option for LVDS output only 1.05 7/30/14 Included Thermal Consideration table 1.06 10/20/14 Modified Thermal Consideration values. Preliminary removed from the title 1.07 1/4/16 Removed 1.8V option Disclaimer: This document is not an official SiTime datasheet. It is exported from a Master FrameMaker document for your convenience, to simplify the generation of your datasheet. The information in the official SiTime datasheet on SiTime’s website will be the final reference in case of conflicting information. Rev. 1.07 Page 8 of 8 www.sitime.com
物料型号:SiT9121
器件简介: - SiT9121是一款高性能差分振荡器,提供1-220 MHz的频率范围,具有LVPECL和LVDS输出信号类型。 - 它具有0.6ps RMS相位抖动(随机),在12 kHz至20 MHz的带宽范围内。 - 频率稳定性低至±10 ppm,适用于工业和扩展商业温度范围。
引脚分配: - OE/ST(1):输出使能/待机输入,高电平或悬空输出指定频率,低电平使设备进入睡眠模式。 - NC(2):无连接,建议悬空或接地以改善散热。 - GND(3):电源地。 - OUT+(4):振荡器输出。 - OUT-(5):互补振荡器输出。 - VDD(6):电源电压。
参数特性: - 供电电压:2.97V至3.63V,或2.25V至2.75V,或2.25V至3.63V(取决于封装和订单代码)。 - 输出频率范围:1 MHz至220 MHz。 - 频率稳定性:首年老化±10 ppm至±50 ppm,10年老化±5 ppm。 - 工作温度范围:工业级-40°C至+85°C,扩展商业级-20°C至+70°C。
功能详解: - SiT9121适用于10GB Ethernet、SONET、SATA、SAS、Fibre Channel、PCI-Express等应用。 - 具有即时绿色终身保修服务。
应用信息: - 适用于电信、网络、仪器、存储和服务器等领域。
封装信息: - 标准工业封装尺寸为3.2x2.5 mm、5.0x3.2 mm和7.0x5.0 mm。
绝对最大值: - 存储温度:-65°C至+150°C。 - VDD:-0.5V至+4V。 - 静电放电(HBM):2000V。 - 焊接温度:最高260°C。
热考虑: - 不同封装的热阻值不同,例如7050、6-pin封装的OJA、4层板热阻为142°C/W。
环境合规性: - 包括机械冲击、机械振动、温度循环、焊接性和湿度敏感度等级等测试。
订购信息: - 提供详细的订购代码,包括频率、温度范围、特征引脚、电压供应、信号类型、封装尺寸和频率稳定性等选项。
SIT9121AI-2D2-25E135.000000Y 价格&库存
很抱歉,暂时无法提供与“SIT9121AI-2D2-25E135.000000Y”相匹配的价格&库存,您可以联系我们找货
    • 5+22.60000
    • 35+21.69600
    • 100+20.24000
    • 500+19.36000
    • 1000+18.48000
    库存:1000
