KM331M035G125A
KM331M035G125A
    CAPXON(台湾丰宾)
    插件,D10xL12.5mm
    直插铝电解电容 插件,D10xL12.5mm 330µF ±20% Ф10.00 x 12.50mm 35V 400mA 2000Hrs@105℃
KM331M035G125A 数据手册
  Aluminum Electrolytic Capacitor    KM series  Part number  KM331M035G125A Capacitance  330 µF Voltage  35 VDC Surge Voltage  40 VDC Capacitance  Tolerance (@ +20°C) ±20 % Ripple current (max, @120Hz,+105°C)  400 mA Dissipation factor(tanδ @120Hz, +20°C)  12 % Leakage Current (max, @ +20°C)*  116 µA Size  10x12.5 mm Operating temperature  ‐40 to 105 °C Endurance  2000 h L.C.:  After  1 min. with rated working voltage applied.  Test conditions  Duration time  Applied voltage  After test requirements (+20°C):  Capacitance  change  Dissipation factor change  Leakage current  comment          330µF 35V KM 105°C Endurance  Shelf Life  2000h @ 105°C  1000h @ 105°C  Rated DC working voltage, IR  None      ≤ ±20% of initial measured value  ≤ 200% of the initial specified value  ≤ the initial specified value    Pre‐treatment for measurements shall  be conducted after application of DC  working voltage for 30 min.  PET Sleeve dø±0.02   L±1.5  Series  1_2  Cap  3_4_5  Tol.  6  Voltage  7_8_9  KM  331  M  035        =330µF    …  =±20%      =35V      Case D 10  Case L  11_12_13 Type  14  Lead Treatm.  15_16  G  125  A  A    =10mm      =12.5mm      A=standard     no request            D 10  L 12.5  F 5  dø 0.6  Special  17_18_19_20  Specification and description for the component(s) are subject to change without notice. For packaging, handling, precautions and warning information, please visit our website: www.capxongroup.com CapXon        V.ED‐20171027
KM331M035G125A
物料型号:KM331M035G125A 器件简介:CapXon KM系列铝电解电容器 引脚分配:未提供 参数特性: - 容量:330µF - 额定电压:35V DC - 浪涌电压:40V DC - 容量公差(+20°C):+20% - 纹波电流(最大值,@120Hz, +105°C):400mA - 损耗角正切(@120Hz, +20°C):12% - 漏电流(最大值,@ +20°C):116µA 功能详解:未提供 应用信息:未提供 封装信息:尺寸为10x12.5mm,PET套管,橡胶端封,安全装置,尺寸公差为直径±0.02mm,长度±1.5mm。
CapXon KM系列电容器在105°C环境下的额定寿命为2000小时,存储寿命为1000小时。
测试后要求包括容量变化不超过初始测量值的±20%,损耗因子变化不超过初始标称值的200%,漏电流不超过初始标称值。
规格和描述如有变更,厂家不另行通知。
有关包装、处理、预防措施和警告信息,请访问CapXon集团网站。
KM331M035G125A 价格&库存
很抱歉,暂时无法提供与“KM331M035G125A”相匹配的价格&库存,您可以联系我们找货
KM331M035G125A
  • 5+0.40646
  • 20+0.36836
  • 100+0.33025
  • 500+0.29215
  • 1000+0.27436
  • 2000+0.26166
