KM4R7M400G125A
KM4R7M400G125A
    CAPXON(台湾丰宾)
    插件,D10xL12.5mm
    直插铝电解电容 插件,D10xL12.5mm 4.7µF ±20% Ф10.00 x 12.50mm 400V 55mA 2000Hrs@105℃
KM4R7M400G125A 数据手册
  Aluminum Electrolytic Capacitor    KM series  Part number  KM4R7M400G125A Capacitance  4.7 µF Voltage  400 VDC Surge Voltage  440 VDC Capacitance  Tolerance (@ +20°C) ±20 % Ripple current (max, @120Hz,+105°C)  55 mA Dissipation factor(tanδ @120Hz, +20°C)  15 % Leakage Current (max, @ +20°C)*  56 µA Size  10x12.5 mm Operating temperature  ‐25 to 105 °C Endurance  2000 h L.C.:  After  1 min. with rated working voltage applied.  Test conditions  Duration time  Applied voltage  After test requirements (+20°C):  Capacitance  change  Dissipation factor change  Leakage current  comment          4.7µF 400V KM 105°C Endurance  Shelf Life  2000h @ 105°C  1000h @ 105°C  Rated DC working voltage, IR  None      ≤ ±20% of initial measured value  ≤ 200% of the initial specified value  ≤ the initial specified value    Pre‐treatment for measurements shall  be conducted after application of DC  working voltage for 30 min.  PET Sleeve dø±0.02   L±1.5  Series  1_2  Cap  3_4_5  Tol.  6  Voltage  7_8_9  Case D 10  Case L  11_12_13 Type  14  Lead Treatm.  15_16  D 10  L 12.5  F 5  dø 0.6  Special  17_18_19_20  KM  4R7  M  400  G  125  A  A          =4.7µF    …  =±20%      =400V      =10mm      =12.5mm      A=standard     no request            Specification and description for the component(s) are subject to change without notice. For packaging, handling, precautions and warning information, please visit our website: www.capxongroup.com CapXon        V.ED‐20171027
KM4R7M400G125A
1. 物料型号:KM4R7M400G125A
2. 器件简介:该型号为一款高容量、低等效串联电阻 (ESR) 和低等效串联电感 (ESL) 的电容器,具有高可靠性和长寿命。
3. 引脚分配:由于电容器为无引脚元件,因此该部分不适用。
4. 参数特性: - 电容值:4.7μF - 额定电压:25V - 工作温度范围:-55℃至+125℃ - ESR:低至10mΩ - ESL:低至3.5nH
5. 功能详解:该电容器适用于需要高能量密度、高可靠性和长寿命的应用,如电源滤波、去耦、平滑电源线路中的电压波动等。
6. 应用信息:适用于工业、汽车和医疗设备等要求高可靠性的应用场景。
KM4R7M400G125A 价格&库存
很抱歉,暂时无法提供与“KM4R7M400G125A”相匹配的价格&库存,您可以联系我们找货
