ZV101M050F105ETR
ZV101M050F105ETR
    CAPXON(台湾丰宾)
    SMD,D8xL10.5mm
    贴片铝电解电容 SMD,D8xL10.5mm 100µF ±20% 50V 2000Hrs@105℃
ZV101M050F105ETR 数据手册
  Aluminum Electrolytic Capacitor    ZV series  Part number  Capacitance  Voltage  Surge Voltage  Capacitance  Tolerance (@120Hz, +20°C) Ripple current (max, @100KHz,+105°C)  Dissipation factor (tanδ @120Hz, +20°C)  Leakage Current (max, @ +20°C)*  Impedance (max. @ 100KHz,+20°C)  Size  Operating temperature  Endurance  ZV101M050F105ETR 100 50 58 ±20 310 12 50 0.55 8x10.5 ‐55 to 105 2000 µF VDC VDC % mA % µA Ω mm °C h                              *L.C.  I≦ 0.01CV or 3µA  (C = CAP., V = W.V.)  After 2 minutes, whichever is greater measured with rated working voltage applied.  Test conditions  Duration time  Applied voltage  After test requirements (+20°C):  Capacitance  change  Dissipation factor change  Leakage current  comment  Endurance  Shelf Life  2000h @ 105°C  1000h @ 105°C  Rated DC working voltage,IR  None      ≤ ±25% of initial measured value  ≤ 200% of the initial specified value  ≤ the initial specified value    Pre‐treatment for measurements shall  be conducted after application of DC  working voltage for 30 min.      L max  D  L  A  B  C  W  P±0.2  8  10.5  8.3  8.3  9  0.7~1.1  3.1  Series  1_2  Cap  3_4_5  Tol.  6  Voltage  7_8_9  ZV  101  M  050        =100µF    …  =±20%      =50V      Case D  10  Case L  11_12_13 Type  14_15_16  Cust.  17_18_19_20  F  105  ETR    =8mm      =10.5mm      =tape and reel      no request      Specification and description for the component(s) are subject to change without notice. For packaging, handling, precautions and warning information, please visit our website: www.capxongroup.com CapXon       V.ED‐20171110
ZV101M050F105ETR 价格&库存
很抱歉,暂时无法提供与“ZV101M050F105ETR”相匹配的价格&库存,您可以联系我们找货
ZV101M050F105ETR
  • 5+1.09870
  • 50+0.86060
  • 150+0.70720
  • 500+0.64460
  • 1000+0.60020
  • 3000+0.56160
库存:21095
ZV101M050F105ETR
  • 5+0.99695
  • 50+0.78086
  • 100+0.76915
  • 200+0.64170
  • 500+0.58486
库存:711
ZV101M050F105ETR
  • 5+1.92750
  • 100+1.14980
  • 200+0.80490
  • 500+0.57490
  • 1000+0.54610
  • 5000+0.50590
库存:1
