ZV470M016C055ETR
ZV470M016C055ETR
    CAPXON(台湾丰宾)
    SMD,D5xL5.5mm
    贴片铝电解电容 SMD,D5xL5.5mm 47µF ±20% 16V 2000Hrs@105℃
ZV470M016C055ETR 数据手册
  Aluminum Electrolytic Capacitor    ZV series  Part number  Capacitance  Voltage  Surge Voltage  Capacitance  Tolerance (@120Hz, +20°C) Ripple current (max, @100KHz,+105°C)  Dissipation factor (tanδ @120Hz, +20°C)  Leakage Current (max, @ +20°C)*  Impedance (max. @ 100KHz,+20°C)  Size  Operating temperature  Endurance  ZV470M016C055ETR 47 16 18 ±20 170 16 7.52 2 5x5.5 ‐55 to 105 2000 µF VDC VDC % mA % µA Ω mm °C h                              *L.C.  I≦ 0.01CV or 3µA  (C = CAP., V = W.V.)  After 2 minutes, whichever is greater measured with rated working voltage applied.  Test conditions  Duration time  Applied voltage  After test requirements (+20°C):  Capacitance  change  Dissipation factor change  Leakage current  comment  Endurance  Shelf Life  2000h @ 105°C  1000h @ 105°C  Rated DC working voltage,IR  None      ≤ ±25% of initial measured value  ≤ 200% of the initial specified value  ≤ the initial specified value    Pre‐treatment for measurements shall  be conducted after application of DC  working voltage for 30 min.      L max  D  L  A  B  C  W  P±0.2  5  5.5  5.3  5.3  5.9  0.5~0.8  1.4  Series  1_2  Cap  3_4_5  Tol.  6  Voltage  7_8_9  ZV  470  M  016        =47µF    …  =±20%      =16V      Case D  10  Case L  11_12_13 Type  14_15_16  Cust.  17_18_19_20  C  055  ETR    =5mm      =5.5mm      =tape and reel      no request      Specification and description for the component(s) are subject to change without notice. For packaging, handling, precautions and warning information, please visit our website: www.capxongroup.com CapXon       V.ED‐20171110
ZV470M016C055ETR 价格&库存
很抱歉,暂时无法提供与“ZV470M016C055ETR”相匹配的价格&库存,您可以联系我们找货
ZV470M016C055ETR
  • 5+0.31810
  • 50+0.24500
  • 150+0.19920
  • 500+0.18080
  • 1000+0.16790
  • 3000+0.15660
库存:18769
ZV470M016C055ETR
  • 10+0.62660
  • 100+0.37370
  • 500+0.26160
  • 1000+0.18690
  • 2000+0.17760
  • 10000+0.16440
库存:410
ZV470M016C055ETR
  • 10+0.20954
  • 100+0.19002
  • 500+0.17050
  • 1000+0.15098
  • 2000+0.13796
  • 4000+0.13406
