SD15S50SL
SD15S50SL
    LGE(鲁光)
    TO227B
    肖特基二极管 VR=50V IF=15A IR=280μA TO227B
SD15S50SL 数据手册
SD15S50SL 15A/50V Low VF Schottky Rectifier FEATURES MACHANICAL DATA High current capability, low forward voltage Excellent high temperature stability Low power loss, and high efficiency High forward surge capability RoHS compliant, and Halogen free Case: TO-277B small outline plastic package Terminal: Matte tin plated, solderable per MIL-STD-750, Method 2026 Molding Compound Flammability Rating:UL94-0 High temperature soldering guaranteed: 260C /10second Packed with FRP substrate and epoxy underfilled ORDERING INFORMATION APPLICATIONS Device: GSD15S50SL Package: TO-277B Marking: 15S50 Material: Halogen free Packing: Tape & 13’’ Reel Quantity per reel: 3,000pcs or 5,000pcs Switching mode power supply applications Portable equipment battery applications High frequency rectification DC/DC converter Designed as bypass diodes for solar panels PIN CONFIGURATION PACKAGE OUTLINE http://www.luguang.cn mail:lge@luguang.cn SD15S50SL 15A/50V Low VF Schottky Rectifier ABSOLUTE MAXIMUM RATING (Tamb=25C, unless otherwise specified) Symbol Parameter Value Units VRRM Repetitive Peak Reverse Voltage 50 V IF(AV) Average Forward Current 15 A IFSM Peak Forward Surge Current, 8.3ms single half sine-wave 320 A -50~+150 C TJ & TSTG Junction and Storage Temperature ELECTRICAL CHARACTERISTICS (Tamb=25C, unless otherwise specified) Symbol VF Parameter Forward Voltage VR Reverse Breakdown Voltage IR Reverse Leakage Current CJ Junction Capacitance Rth(JA) Rth(JL) Test Condition Typ Max Units IF = 3A @ 25C 0.33 0.36 V IF = 10A @ 25C 0.41 0.46 V IF = 15A @ 25C 0.46 0.51 V IF = 3A @ 125C 0.24 V IF = 10A @ 125C 0.37 V IF = 15A @ 125C 0.44 V IR = 0.5mA Min 50 V VR = 50V @ 25C 0.280 mA VR = 50V @ 125C 50 mA f=1MHz, VR=4V 850 pF Thermal Resistance Junction to Ambient (note 1) 94 C/W Thermal Resistance Junction to Lead (note 1) 10 C/W Note 1: Units mounted on recommended P.C.B. 1 oz. pad layout http://www.luguang.cn mail:lge@luguang.cn SD15S50SL 15A/50V Low VF Schottky Rectifier ELECTRICAL CHARACTERISTICS CURVE http://www.luguang.cn mail:lge@luguang.cn SD15S50SL 15A/50V Low VF Schottky Rectifier TO-277B PACKAGE OUTLINE DIMENSIONS unit: mm FOOT PRINT RECOMMENDATION unit: mm http://www.luguang.cn mail:lge@luguang.cn
SD15S50SL 价格&库存
很抱歉,暂时无法提供与“SD15S50SL”相匹配的价格&库存,您可以联系我们找货
