SS12-SS120
1.0AMP. Surface Mount Schottky Barrier Rectifiers
SMA/DO-214AC
Features
0. 181( 4. 60)
0. 161( 4. 10)
For surface mounted application
Easy pick and place
Metal to silicon rectifier, majority carrier conduction
Low power loss, high efficiency
High current capability, low VF
High surge current capability
Plastic material used carriers Underwriters
Laboratory Classification 94V-0
Epitaxial construction
High temperature soldering:
260oC / 10 seconds at terminals
0. 209( 5. 30)
0. 193( 4. 90)
0. 012(0.30)
0. 006(0.15)
0.096(2.45)
0.078(2.00)
0. 059( 1. 50)
0. 035( 0. 90)
Mechanical Data
0. 108( 2. 75)
0. 096( 2. 45)
0. 063(1.60)
0. 051(1.30)
Case: JEDEC SMA/DO-214AC Molded plastic
Terminals: Pure tin plated, lead free
Polarity: Indicated by cathode band
Packaging: 12mm tape
Weight: 0.064 gram
0.008(0.20)
0. 002(0.05)
Dimensions in inches and(millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Symbol SS SS SS SS
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
at TL(See Fig. 1)
Peak Forward Surge Current, 8.3 ms Single
Half Sine-wave Superimposed on Rated
Load (JEDEC method )
Maximum Instantaneous Forward Voltage
o
IF= 1.0A @ 25 C
(Note 1)
o
@ 100 C
o
Maximum DC Reverse Current
@ TA =25 C at
Rated DC Blocking Voltage @ TA=125 oC
Maximum DC Reverse Current at VR=33V
o
& TA=50 C
Typical Junction Capacitance (Note 3)
Typical Thermal Resistance ( Note 2 )
VRRM
VRMS
VDC
12
30
21
30
14
40
28
40
SS
16
60
42
60
15
50
35
50
SS
19
90
63
90
SS SS SS Units
110 115 120
100 150 200
V
V
70 105 150
100 150 200
V
I(AV)
1.0
A
IFSM
30
A
0.5
0.4
VF
0.75
0.65
0.4
IR
10
5.0
HTIR
Cj
0.80
0.70
0.1
2.0
0.90
0.85
V
mA
mA
5.0
uA
50
R ΘJL
28
88
R θJA
TJ
Operating Temperature Range
-65 to +125
-65 to +150
Storage Temperature Range
TSTG
-65 to +150
Notes:
1. Pulse Test with PW=300 usec, 1% Duty Cycle
2. Measured on P.C.Board with 0.2” x 0.2” (5.0mm x 5.0mm) Copper Pad Areas.
3. Measured at 1 MHz and Applied Reverse Voltage of 4.0V D.C.
pF
o
C/W
o
o
C
C
- 32 ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
SS12-SS120
RATINGS AND CHARACTERISTIC CURVES (SS12 THRU SS120)
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
50
RESISTIVE OR
INDUCTIVE LOAD
SS12- SS14
SS15-SS120
0.5
PCB MOUNTED ON 0.2X0.2"
(5.0X5.0mm) COPPER PAD AREAS
PEAK FORWARD SURGE CURRENT. (A)
AVERAGE FORWARD CURRENT. (A)
1.0
FIG.2- MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
AT RATED TL
8.3ms Single Half Sine Wave
JEDEC Method
40
30
60
70
80
90
100
110
120
130
140
150
160
1
170
10
NUMBER OF CYCLES AT 60Hz
o
LEAD TEMPERATURE. ( C)
100
FIG.4- TYPICAL REVERSE CHARACTERISTICS
FIG.3- TYPICAL FORWARD CHARACTERISTICS
100
50
SS12-SS14
SS15-SS120
SS15-SS16
10
INSTANTANEOUS FORWARD CURRENT. (A)
INSTANTANEOUS REVERSE CURRENT. (mA)
SS19-SS110
SS12-SS14
1
SS120
0.1
10
Tj=125 0C
1
Tj=75 0C
0.1
0.01
Tj=25OC
PULSE WIDTH=300 S
1% DUTY CYCLE
0.001
0.01
.4
.6
.8
1.0
1.2
1.4
1.6
FORWARD VOLTAGE. (V)
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
FIG.6- TYPICAL TRANSIENT THERMAL
CHARACTERISTICS
FIG.5- TYPICAL JUNCTION CAPACITANCE
Tj=25 C
f=1.0MHz
Vsig=50mVp-p
SS12-SS14
SS15-SS16
SS19-SS120
100
10
0.1
1.0
10
TRANSIENT THERMAL IMPEDANCE. (OC/W)
100
400
JUNCTION CAPACITANCE.(pF)
10
1
0.1
0.01
0.1
REVERSE VOLTAGE. (V)
100
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMA
5000/REEL
80000
36X30.6X31
12.00
11.00
ht t p : //
1
10
T, PULSE DURATION. (sec)
www.lgesemi .c o m
很抱歉,暂时无法提供与“SS16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.11036
- 10+0.10146
- 30+0.09968
- 国内价格
- 10+0.20866
- 100+0.16665
- 300+0.14332
- 1000+0.12939
- 5000+0.10757
- 10000+0.10109
