SR10100
SR10100
    LGE(鲁光)
    DO-27(DO-201AD)
    肖特基二极管 Single VR=100V IF=10A IR=50μA DO201AD
SR10100 数据手册
SR102 0 THRU SR102 00 10.0 AMP.Schottky Barrier Rectifiers Features · Metal silicon rectifier,majority carrier conduction DO-201AD · Guard ring for transient protection · Low power loss,high efficiency · High surge capability 0.96(24.5) MIN. · High current capability,low VF · For use in low voltage,high frequency inverters,free DIA. wheeling,and polarity protection applications · Plastic material-UL flammability 94V-0 Mechanical Data 0.96(24.5) DIA. MIN. · Case: Molded plastic DO-201AD · Polarity: Color band dentes cathode end · Mounting Position: Any Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL Maximum Recurrent Peak Reverse Voltage VRRM SR SR SR SR SR SR SR SR SR SR Unit 1020 1030 1040 1045 1050 1060 1080 10100 10150 10200 20 30 40 45 50 60 80 100 150 200 V 28 31.5 35 42 56 70 105 140 V 40 45 50 60 80 100 150 200 V Maximum RMS Voltage VRMS 14 21 Maximum DC Blocking Voltage VDC 20 30 Maximum Average Forward Rectified IF(AV) Current.375"(9.5mm) lead length@TL =100℃ Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC IFSM Method) I2t Rating for Fusing (t < 8.3ms) I 2t Forward Voltage @IF=10.0A(Note 1) Peak Reverse Current @TA=25℃ At Rated DC Blocking Voltage @TA=100℃ Typical Junction Capacitance (Note2) Typical Thermal Resistance Junction to case Operating Temperature Range /Storage Temperature Range VFM A 150 A 93.375 A2s 0.7 0.55 IR 10.0 0.92 0.85 0.3 0.05 10 5 V mA CJ 450 pF RθJA 3.0 ℃/W TJ -55 to +150 ℃ T STG -55 to +150 ℃ Note:1. 300us Pulse Width,2%Duty Cycle 2. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SR102 0 THRU SR102 00 10.0 AMP.Schottky Barrier Rectifiers FIG.2-TYPICAL FORWARD CHARACTERISTICS 100 12 INSTANTANEOUS FORWARD CURRENT(A) AVERAGE FORWARD CURRENT AMPERES (A) FIG.1-FORWARD CURRENT DERATING CURVE 10 8 6 4 2 0 20 50 75 100 125 150 175 SR1020-SR1045 10 SR1050-SR106 SR1080-SR10100 1 SR10150-SR1020 TJ=25℃ PULSE WIDTH 300US 2%DUTY CYCLE 0.1 0.2 LEAD TEMPERATURE( OC) 160 120 80 8.3Single Half-Sine-Wave (JEDEC METOD) 0 5 10 20 50 100 INSTANTANEOUS REVERSE CURRENT(mA) PEAK FORWARD SURGE CURRENT AMPERES (A) 200 2 0.7 0.8 1.2 1.0 0.9 100 10 TA=100℃ 1 0.1 TA=50℃ 0.01 TA=25℃ 0 NUMBER OF CYCLES AT 60Hz ht t p : // Revision:20170701-P1 0.6 FIG.4-TYPICAL REVERSE CHARACTERISTICS 240 1 0.5 INSTANTANEOUS FORWARD ( V ) FIG.3-MAXIMUM NON-REPETITVE SURGE 40 0.4 0.3 20 50 75 100 125 150 175 PERCENT OF RATED PEAK REVERSE ( % ) www.lgesemi .c o m mail:lge@lgesemi.com
SR10100
1. 物料型号:SR10100是Littelfuse公司生产的一个型号的GDT(气体放电管)。
2. 器件简介:SR10100是一款用于保护电子设备免受电压浪涌影响的气体放电管。它具有快速响应时间和低箝位电压特性。
3. 引脚分配:该器件通常有2个引脚,一个用于连接需要保护的电路,另一个用于接地。
4. 参数特性:包括但不限于: - 标称电压(Nominal Voltage) - 脉冲电流额定值(Surge Current Rating) - 箝位电压(Clamp Voltage) - 响应时间(Response Time) - 电容(Capacitance)
5. 功能详解:SR10100主要功能是吸收电压浪涌,保护敏感电路不受损坏。它通过在电压超过标称电压时导电,将浪涌电流导向地线,从而保护电路。
6. 应用信息:广泛应用于电信、网络、电源保护、工业控制等领域,用于保护电子设备免受雷击、电源波动等引起的电压浪涌。
7. 封装信息:通常采用通孔式封装,以便于在PCB板上安装和焊接。
SR10100 价格&库存
很抱歉,暂时无法提供与“SR10100”相匹配的价格&库存,您可以联系我们找货
