SR520LH-SR5100LH
Low VF Schottky Barrier Rectifiers
VOLTAGE RANGE: 20 --- 100 V
CURRENT: 5.0A
DO-201AD/DO - 27
Features
Metal-semiconductor junction with guard ring
Epitaxial construction
Low forward voltage drop,low switching losses
High surge capability
For use in low voltage,high frequency inverters free
wheeling,and polarity protection applications
The plastic material carries U/L recognition 94V-0
Mechanical Data
Case:JEDEC DO-201AD/DO--27,molded plastic
Polarity: Color band denotes cathode
Weight: 0.041ounces,1.15 grams
Mounting position: Any
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25
ambient temperature unless otherwise specified.
Single phase,half wave,60 Hz,resistive or inductive load. For capacitive load,derate by 20%.
SR520LH SR530LH SR540LH SR550LH R560LH SR580LH SR5100LH
UNITS
Maximum recurrent peak reverse voltage
VRRM
40
50
60
80
100
V
Maximum RMS voltage
VRMS
14
21
28
35
42
56
70
V
Maximum DC blocking voltage
VDC
40
50
60
80
100
V
Maximum average forw ard rectified current
9.5mm lead length,
(see fig.1)
IF(AV)
5.0
A
IFSM
150.0
A
Peak forw ard surge current
8.3ms single half-sine-w ave
superimposed on rated load
@TJ=125
Maximum instantaneous forw ard voltage
@ 5.0A (Note 1)
Maximum reverse current
@TA=25
VF( 25
0.45
0.60
0.65
VF(125
0.36
0.50
0.60
2.5
IR
at rated DC blocking voltage @TA=100
Typical junction capacitance
(Note2)
CJ
Typical thermal resistance
(Note3)
RθJA
TSTG
Storage temperature range
25.0
500
400
25
- 55 ---- + 125
TJ
Operating junction temperature range
50.0
V
mA
pF
/W
- 55 ---- + 150
- 55 ---- +150
NOTE: 1. Pulse test:300us pulse width,1% duty cy cle.
2. Measured at 1.0MHz and applied rev erse v oltage of 4.0V DC.
3.Thermal resistance junction to ambient
Revision:20170701-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
SR520LH-SR5100LH
Ratings AND Charactieristic Curves
SR550LH - SR5100LH
4.0
3.0
Resistive or
Inductive Load
0.375"(9.5mm)
Lead Length
2.0
1.0
50
75
100
125
150
175
125
TJ =TJ MAX
8.3ms Single Half
Sine-Wave
100
75
50
25
LEAD TEMPERATURE,
10
100
NUMBER OF CYCLES AT 60Hz
FIG.3 -- TYPICAL INSTANTANEOUS FORWARD
XXXXXXX----CHARACTERISTICS
FIG.4 -- TYPICAL JUNCTION CAPACITANCE
50
SR520LH - SR540LH
10
CAPACITANCE,pF
4000
SR550LH - SR560LH
AMPERES
INSTANTANEOUS FORWARD CURRENT
150
AMPERES
SR520LH- SR540LH
FIG.2 -- PEAK FORWARD SURGE CURRENT
5.0
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT
FIG.1 -- FORWARD CURRENT DERATING CURVE
1
SR580LH-SR5100LH
0.1
TJ=25
Pulse Width=300 µ s
1% DUTY CYCLE
1000
SR520LH - SR540LH
SR550LH - SR5100LH
100
0.1
0.01
0.4
0.6
0.8 1.0 1.2 1.4
ht t p : //
1
10
100
1.6
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
REVERSE VOLTAGE,VOLTS
www.lgesem i .c o m
很抱歉,暂时无法提供与“SR5100LH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.88884
- 50+0.70740
- 150+0.61668
- 1250+0.52586
- 2500+0.47142
- 5000+0.44421
