SS54L
SS54L
    LGE(鲁光)
    SMB(DO-214AA)
    肖特基二极管 40V 5A SMB(DO-214AA)
SS54L 数据手册
SS52-SS520 5.0AMP. Schottky Barrier Rectifiers VOLTAGE RANGE:20-200V CURRENT:5.0A Fetures ◇ Plastic package has Underwriters Laboratory SMB Flammability Classification 94V-0 utilizing Flame Retardant Epoxy Molding Compound. ◇ Guard ring for overvoltage protection ◇ High current capability, low forward voltage drop ◇ Low power loss, high efficiency ◇ High surge capability Mechanicla Data ◇ Case: Molded plastic SMB ◇ Terminals: Plated leads solderable per MIL-STD-202,Method 208 guaranteed ◇ Polarity: Color band dentes cathode end ◇ Mounting Position: Any ◇ Weight: 0.093 gram Dimensions in inches and (millimeters) ◇ Lead Free: For RoHS/Lead Free Version ◇ Marking: LGE SS5XX MAXIMUM RATINGS AND ELECTRICAL CHARACTERS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase,half wave,60HZ,resistive or inductive load.For capacitive load,derate by 20%. Type Numger Symbol SS SS SS SS SS SS5 SS5 SS5 52 54 55 56 58 10 15 20 UNITS Maximum Recurrent Peak Reverse Voltage VRRM 20 40 50 60 80 100 150 200 V Maxium RMS Voltage VRMS 14 28 35 42 56 70 105 140 V Maxium DC Blocking Voltage VDC 20 40 50 60 80 100 150 200 V Average Rectified Output Current (Note 1) @TL=100℃ IF(AV) 5.0 A IFSM 175 A I2t 127 A2S Peak forward surge current:8.3ms single half-sine-wave superimposed on rated load (JEDEC Method) I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF= 5.0A VFM Peak Reverse Current @TA=25℃ At Rated DC Blocking Voltage @TA=100℃ Typical Junction Capacitance (Note 2) Typical Thermal Resistance Junction toAmbient(Note 1) Operating Temperature Range Storage Temperature Range 0.45 0.55 IR IR 0.5 20 CJ 500 0.7 0.85 0.85 0.5 V Ma 10 350 pF ℃/W RθJA 55 TJ -55 to +150 ℃ TSTG -55 to +150 ℃ Note: 1.Pulse test:300¦ÌS pulse width,1%duty cycle. 2.P.C.B.mounted with 0.55"X0.55"(14.0X14.0mm2)copper pad areas. Revision:20170701-P1 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com SS52-SS520 5.0 AMP. Schottky Barrier Rectifiers VOLTAGE RANGE:20-200V CURRENT:5.0A F i g . 2 Ty p i c a l R e v e r s e C h a r a c t e r i s t i c s 6.0 100LFM 5.0 4.0 3.0 2.0 Single phase half wave resistive or inductive P.C.B mounted on 0.55×0.55"(14mm×14mm pad) areas 1.0 0.0 25 75 50 100 125 Instaneous Reverse Current ( μA) Average Forward Current (A) Fig.1 Forward Current Derating Curve 10 4 T J =100°C 10 3 SS54B/SS520B 10 1 0 40 60 100 80 F i g . 4 Ty p i c a l J u n c t i o n C a p a c i t a n c e T J =25°C Junction Capacitance ( pF) 20 10 1 SS52B SS54B SS56B/SS58B SS510B/SS520B 0.1 0 0.5 1.0 1.5 500 100 SS52B/SS54B SS54F/SS520F SS56B-SS520B 20 10 0.1 10 1 100 Instaneous Forward Voltage (V) Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current F i g . 6 - Ty p i c a l Tr a n s i e n t T h e r m a l I m p e d a n c e 250 8.3 ms Single Half Sine Wave (JEDEC Method) 200 150 SS54B~SS520B 100 50 00 1 1000 2.0 10 100 Number of Cycles at 60Hz ht t p : // Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) 20 Percent of Rated Peak Reverse Voltage(%) F i g . 3 Ty p i c a l F o r w a r d C h a r a c t e r i s t i c Peak Forward Surage Current (A) T J =25°C 10 0 Lead Temperature (°C) Revision:20170701-P1 T J =75°C 10 2 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.lgesem i .c o m mail:lge@lgesemi.com
SS54L
物料型号:SS52-SS520
器件简介: - 符合RoHS标准 - 采用塑料封装,具有UL94V-0的阻燃等级 - 有保护环以防止过电压 - 高电流承载能力,低正向电压降 - 低功耗,高效率 - 高浪涌能力
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 工作温度范围:-55°C至+150°C - 存储温度范围:-55°C至+150°C - 正向电压、反向电流、结电容等参数随型号不同而有所变化
功能详解: - 正向电流降额曲线 - 典型反向特性 - 典型正向特性 - 最大非重复峰值正向浪涌电流 - 典型瞬态热阻
应用信息:文档中未明确提供应用信息
封装信息: - 封装类型:塑封SMB - 端子:可按照MIL-STD-202, Method 208标准焊接的镀铅引线 - 极性:通过色环标识阴极端 - 安装位置:任意 - 重量:0.093克 - 尺寸:以英寸和毫米提供 - 无铅:适用于RoHS/无铅版本 - 标记:LGE SS5XX
