RTS5411-GR
RTS5411-GR
    REALTEK(瑞昱)
    QFN-76-EP(9x9)
    USB3.0超高速轮毂控制器 QFN76_9X9MM_EP
RTS5411-GR 数据手册
RTS5411 USB 3.0 Super-Speed HUB Controller DATASHEET Doc Rev. 1.2 30. Nov. 2015 i Rev 1.2 TRADEMARKS Realtek is a trademark of Realtek Semiconductor Corporation. All other names mentioned in this document are trademarks/registered trademarks of their respective owners. Realtek provides this document “as is”, without warranty of any kind, neither expressed nor implied, including, but not limited to the particular purpose. Realtek may make improvements and/or changes in this manual or in the product(s) and/or the program(s) described in this manual at any time. This document could include technical inaccuracies or typographical errors. Revision History Revision Description Page Date 0.90 First release 2014/01/10 0.91 Added SMBus Section 2014/03/16 0.92 Added the maximum ratings of HBM in section 5.1 10 Modified the system clock frequency in section 5.4.1 11 Updated the power consumption in section 5.5 12 Modified the power off sequence in section 5.6. 15 Modified the buffer type of OCP and DSP_PWR pins in section 4.3 9 Added comments in the Package Dimensions in section 8 27 Fixed the default slave address of SMBUS 19,20 Added SMBus Patch Setting Transfer 20 Added SMBus Customer Charge Configuration Transfer 21 2014/07/01 0.93 Modify the pin description of the OCP input pins. 2014/07/22 0.94 Add the maximum junction temperature in section 5.2 10 2014/08/20 0.95 Update power consumption in section 5.5 12,13,14 2014/11/12 0.96 Correct the clerical mistake of ‘command code’ value in section 6.3.6 21 2015/01/22 1.0 Formal Release 1.1 Add ‘Tc’ parameter in section 5.2 10 2015/03/23 1.2 Add “RTS5411” mark 5 2015/11/30 Add VAV12,VDV12 condition : Active and Disconnect / Suspend 10 2015/01/30 ii Rev 1.2 Table of Contents 1. General Description .............................................................................................................................................................. 1 2. Features ................................................................................................................................................................................. 2 3. Block Diagram ...................................................................................................................................................................... 4 4. Pin Information ..................................................................................................................................................................... 5 4.1 Pin Assignment ............................................................................................................................................................... 5 4.2 Pin Descriptions .............................................................................................................................................................. 6 4.3 Buffer list ........................................................................................................................................................................ 9 5. Electrical Characteristics ..................................................................................................................................................... 10 5.1 Absolute Maximum Ratings .......................................................................................................................................... 10 5.2 Recommended Operating Ranges ................................................................................................................................. 10 5.3 DC Characteristics .........................................................................................................................................................11 5.3.1 DC Characteristics except USB differential signals ................................................................................................11 5.3.2 USB 2.0 Interface DC Characteristics .....................................................................................................................11 5.3.3 USB 3.0 Interface DC Characteristics .....................................................................................................................11 5.4 AC Characteristics ..........................................................................................................................................................11 5.4.1 System Clock ..........................................................................................................................................................11 5.5 Power Consumption ...................................................................................................................................................... 12 5.6 Power On/Off Sequence ................................................................................................................................................ 15 6. SMBus Slave Interface ........................................................................................................................................................ 17 6.1 Pull-Up Resistor for SMBus ......................................................................................................................................... 17 6.2 SMBus Bus Protocol ..................................................................................................................................................... 17 6.2.1 Receive Byte .......................................................................................................................................................... 18 6.2.2 Block Write/Block Read......................................................................................................................................... 19 6.3 SMBus Transfer Protocol .............................................................................................................................................. 19 6.3.1 Slave Address ......................................................................................................................................................... 19 6.3.2 Get Device Status ................................................................................................................................................... 19 6.3.3 Block-out Transfer ................................................................................................................................................. 20 6.3.4 Block-in Transfer ................................................................................................................................................... 20 6.3.5 SMBus Patch Setting Tranfer ................................................................................................................................. 20 6.3.6 Customer Charging Configuration Transfer ........................................................................................................... 21 6.3.7 Invalid Protocol Response Behavior ...................................................................................................................... 22 6.4 Bus Reset Sequence ...................................................................................................................................................... 22 6.5 SMBus Timing .............................................................................................................................................................. 22 7. I2C Master and slave interface ............................................................................................................................................ 24 7.1 I2C Slave interface ........................................................................................................................................................ 24 7.2 I2C Master interface ...................................................................................................................................................... 24 7.2.1 Supported Mode and Speed .................................................................................................................................... 24 7.2.2 Transfer Protocol Implementation .......................................................................................................................... 24 7.2.3 Stretching the SCK ................................................................................................................................................. 25 7.2.4 Slave Response Timeout ........................................................................................................................................ 25 7.3 I2C Timing .................................................................................................................................................................... 25 8. QFN-76 Package Dimensions ............................................................................................................................................. 28 9. Ordering Information .......................................................................................................................................................... 30 iii Rev 1.2 RTS5411 1. General Description RTS5411 is an advanced USB3.0 4-port HUB controller, which integrates USB3.0 and USB2.0 Transceivers, MCU, SIE, regulator and charger circuits into a single chip. That could dramatically reduce the system BOM cost. With high compatibility, RTS5411 is fully backward compatible to USB2.0 and USB1.1 specification which can be operated in Super-Speed, High-Speed, Full-Speed and Low-Speed. RTS5411 provides the battery charging function for each downstream port. Besides complies with USB Battery Charging specification rev1.2, RTS5411 also provides charging function for various portable devices. Not only downstream ports can be used as charger, RTS5411’s upstream port also supports two special functions regarding the BC1.2 specification. The first one charger function of RTS5411’s upstream port is called “ACA-dock” mode. When a device which complies with ACA-dock of the BC1.2 specification is put into an ACA-Dock, it would act as a host to various USB peripherals, such as a hub, keyboard, mouse, printer, etc. However, while in ACA-dock, the device should also be able to charge at the same time. The second charger function of the RTS5411’s upstream port is called “charger detection” function. RTS5411 can recognize the BC1.2 charger mode which attached to the upstream port, including CDP, DCP and SDP. RTS5411 supports an auto detection-switch mechanism to charge portable device in suitable mode. RTS5411 can update its firmware with an external SPI flash through flexible ISP channel. With the ISP function, it can configure lots of features and settings by the external SPI flash or EEPROM as well. The ISP function is easy to complete with just one USB cable and RTS5411’s download tool. The features and settings of RTS5411 can also be configured by the SMBUS interface or internal eFuse. RTS5411 has various interfaces to communicate with other components, such as GPIO, I2C, SMBUS. It’s flexible for extending varieties of applications by using these interfaces. Moreover, RTS5411 supports a special power saving function named delink mode. It can save more power for the system when there is no device connected to the hub even though the upstream port of the RTS5411 is attached to the downstream port of the behind host or hub. Realtek Semiconductor Corp. 1 V1.2 RTS5411 2. Features  Compliant with Universal Serial Bus 3.0 Specification Revision 1.0 - 4 downstream ports for super-speed, high-speed, full-speed and low-speed traffic. - Backward compatible with USB specification Revision 2.0, 1.1 and 1.0.  MT T (Mu lt i pl e Tr a ns ac t i on Tr a ns la to r) - O n e T T f or e ac h do w ns tr e am por t. - Better data throughput when multiple downstream ports act on FS concurrently.  Support SMBUS to customize configurations - SMBUS address is configurable by external SPI Flash or internal eFuse.  Support I2C to configure other chips on the same platform.  Compliant with USB Battery Charging Specification Revision 1.2 and other portable devices - DCP Mode of BC 1.2. - CDP Mode of BC 1.2. - ACA-Dock functions of BC 1.2. - Charger detection functions for upstream port’s charger which complies with BC1.2. - D+/D– Divider Modes 2.0V/2.7V, 2.7/2.0V and 2.7/2.7V. - D+/D- 1.2V Mode.  The Up Stream Port of the RTS5411 can detect the DSP it is connected to is a SDP, CDP, or DCP. When the RTS5411 is connected to a charging port, it is allowed to draw more current from the DSP.  Support Gang mode and Individual mode for downstream port.  Support USB2.0 LPM-L1 function  Support USB3.0 U1/U2/U3 power saving mode  Integrated Fast 8051 microprocessor  Support serial flash for ISP function which can upgrade Firmware or configurations via USB directly.  Support EEPROM for ISP function which can upgrade configurations via USB directly.  Support 12MHz Crystal clock  Integrated 3.3V output LDO inside, the input range supports from 4.5V to 5.5V  Integrated 1.2V output switching regulator, the input range supports from 3.0V to 5.5V.  Support LED control function of indicating Downstream Ports transfer activity and over-current condition. Realtek Semiconductor Corp. 2 V1.2 RTS5411  76-pin QFN (9 x9 mm) package  Support Efuse to configure functions or configurations such as non-removable port, gang mode, etc.  Support the “Delink” function for extreme power saving - If there is no any device attached to the RTS5411’s downstream ports, the RTS5411 will disconnect itself from the downstream port of the host or another hub controller for further power saving. The connection of the upstream port will be established automatically once there is any device attached to its downstream ports. Realtek Semiconductor Corp. 3 V1.2 RTS5411 3. Block Diagram DS port DS Port Over-current power flag enable 5V 3.3V 5V/3.3V Power switch Controller LDO Super Speed HUB repeater Super Speed PHY SPI FLASH Upstream Port 1.2V SPI Super Speed PHY SWR Charging Controller Super Speed HUB Controller USB2.0 PHY 1st Downstream Port Super Speed PHY USB2.0 PHY USB2.0 HUB Multiple Transaction Translators Super Speed PHY 2nd Downstream Port MCU (8051) USB 3.0 HUB POWER Controller 4 Cache Controller ROM MCU RAM USB2.0 HUB Repeater USB2.0 PHY 3rd Downstream Port USB 2.0 HUB Realtek Semiconductor Corp. USB2.0 PHY Super Speed PHY USB2.0 HUB Controller USB2.0 PHY 4th Downstream Port V1.2 RTS5411 4. Pin Information USP_DM USP_DP V33_OUT LDO_V5_IN SWR_V5_IN SWR_OUT SWR_GND DV12 DV12 DV33 MOSI MISO SCS SCK DSP4_PWR DSP3_PWR DSP2_PWR DSP1_PWR GPIO7 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 4.1 Pin Assignment AV12 58 38 GPIO6 USP_SSTX- 59 37 GPIO5 USP_SSTX+ 60 36 GPIO4 35 GPIO3/SDA 34 GPIO2/SCL 33 GPIO1/SMBDA 32 GPIO0/SMBCL GND 61 USP_SSRX- 62 USP_SSRX+ 63 AV12 64 DSP1_SSTX+ 65 DSP1_SSTX- 66 REALTEK RTS5411 31 AV12 30 DSP4_SSRXDSP4_SSRX+ OCP1 67 29 DSP1_SSRX+ 68 28 OCP4 DSP1_SSRX- 69 27 DSP4_SSTX- AV12 70 26 DSP4_SSTX+ DSP1_DP 71 DSP1_DM 72 DV33 73 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 DV12 DV33 DSP2_DP DSP2_DM AV12 DSP2_SSTX+ DSP2_SSTX- OCP2 DSP2_SSRX+ DSP2_SSRX- AV12 DSP3_SSTX+ DSP3_SSTX- OCP3 DSP3_SSRX+ DSP3_SSRX- AV12 76 2 SPWR_DET The e-pad shall be connected to reference ground BPWR_DET 75 1 74 RREF XTLI XTLO LLLLLLL GXXXVV 25 AV12 24 DSP4_DM 23 DSP4_DP 22 DV33 21 DSP3_DM 20 DSP3_DP The version number is shown in the location marked ‘VV’ and G means Green Package Realtek Semiconductor Corp. 5 V1.2 RTS5411 4.2 Pin Descriptions Pin Name Pin No. I/O Type Description Power supply DV33 DV12 AV12 LDO_V5_IN 4,22,48,73 3,49,50 7,13,19,25,31, 58,64,70 54 V33_OUT 55 Power Power Power Power Power SWR_V5_IN 53 Power SWR_GND SWR_OUT 51 52 GND Power GND 61 E-PAD - RREF 1 XTLI XTLO 74 75 GPIO0/SMBCL, GPIO2/SCL, GPIO4,GPIO6 32,34,36,38 GND GND 3.3V power supply for digital circuits 1.2V power supply for digital circuits 1.2V power supply for analog circuits 5V to 3.3V LDO input. Short this pin to DV33, when on-chip LDO is not used. 3.3V output (from internal 5V to 3.3V Low Dropout Regulator) Short this pin to DV33, when on-chip LDO is not used. 5V to 1.2V SWR input Connect this pin to LDO_V5_IN if internal switching regulator isn’t used. Reference GND for 1.2V SWR 5V to 1.2V SWR output Left this pin floating if internal switching regulator isn’t used. Reference ground The bottom of the package has a thermal pad. The pad shall be connected to the reference ground Analog Interface Connect an external resistor (6.2K ±1%) to the Reference GND I System Clock I O 12Mhz Crystal input. 12Mhz Crystal output. LED Control Pins I/O GPIO1/SMBDA, GPIO3/SDA, GPIO5,GPIO7 33,35,37,39 I/O Realtek Semiconductor Corp. General Purpose I/O. Now used for LED application to indicate Downstream Ports transmit and receive activity .The LEDs will blink when there is USB transfer under corresponding port. These pins have weak internal pull up resistances. Left these pins floating when unused. The GPIO0 can be configured as a SMBus clock pin The GPIO2 can be configured as a I2C clock pin General Purpose I/O. Now used for LED application to indicate Downstream Ports over-current condition. The LEDs will on when over-current condition is detected. These pins have weak internal pull up resistances. Left these pins floating when unused. The GPIO1 can be configured as a SMBus data pin The GPIO3 can be configured as a I2C data pin 6 V1.2 RTS5411 Pin Descriptions(continued) Pin Name Pin No. I/O Type Description USB Port Control Pins DSP1_PWR, DSP2_PWR, DSP3_PWR, DSP4_PWR 40,41,42,43 OCP1,OCP2, OCP3,OCP4 67,10,16,28 O I BPWR_DET 2 I SPWR_DET 76 I External power switch enable pin for corresponding (1) downstream port. Active low . Left these pins floating when unused. 0: Power supply for VBUS is on. 1: Power supply for VBUS is off. Over Current Protection flag for corresponding (1) downstream port .Active low . These pins have internal pull up resistors. Left these pins as floating if OCP function of these pins are unused and the ‘power switch’ mode is selected. The external pull-up resistors shall be connected to these pins if the ‘non power switch’ mode is selected and the OCP function of these pins are unused. 0: Over-current condition is detected. 1:Non over-current condition is detected. Upstream VBUS power detection pin. Active High. 0: Upstream VBUS power is absent. 1: Upstream VBUS power exists. Self Power Detection pin. Active High. 0: Bus-power setting 1: Self-power setting SPI Interface SCK 44 SCS 45 I/O I/O MISO 46 MOSI 47 I/O I/O This is I/O bi-direction. Now used as clock output for EEPROM or Serial Flash memory This is I/O bi-direction. Now used as output chip select for EEPROM or Serial Flash memory Upon power on reset this pin is also used for pin strap option to perform code execution from internal ROM or external SPI ROM. 0:Execute codes from internal ROM .Optionally load configurable futures from the external EEPROM. 1:Execute codes from Serial Flash. This is I/O bi-direction. Now used as data input from EEPROM or Serial Flash memory This is I/O bi-direction. Now used as data output to EEPROM or Serial Flash memory (1) Active low by default. It can be configured to be active high by firmware through executing external codes. Realtek Semiconductor Corp. 7 V1.2 RTS5411 Pin Descriptions(continued) Pin Name Pin No. I/O Type Description USB3.0 Interface USP_SSTX+ DSP1_SSTX+, DSP2_SSTX+, DSP3_SSTX+, DSP4_SSTX+ 60 65,8,14,26 USP_SSTXDSP1_SSTX-, DSP2_SSTX-, DSP3_SSTX-, DSP4_SSTX- 59 66,9,15,27 USP_SSRX+ DSP1_SSRX+, DSP2_SSRX+, DSP3_SSRX+, DSP4_SSRX+ 63 68,11,17,29 USP_SSRXDSP1_SSRX-, DSP2_SSRX-, DSP3_SSRX-, DSP4_SSRX- 62 69,12,18,30 USP_DP DSP1_DP, DSP2_DP, DSP3_DP, DSP4_DP 56 71,5,20,23 USP_DM DSP1_DM, DSP2_DM, DSP3_DM, DSP4_DM 57 72,6,21,24 O USB3.0 SuperSpeed TX+ of Upstream Port USB3.0 SuperSpeed TX+ of Downstream Ports O O USB3.0 SuperSpeed TX- of Upstream Port USB3.0 SuperSpeed TX- of Downstream Ports O I USB3.0 SuperSpeed RX+ of Upstream Port USB3.0 SuperSpeed RX+ of Downstream Ports I I USB3.0 SuperSpeed RX- of Upstream Port USB3.0 SuperSpeed RX- of Downstream Ports I USB2.0 Interface USB2.0 D+ signal of Upstream Port I/O USB2.0 D+ signal of Downstream Ports I/O Realtek Semiconductor Corp. I/O USB2.0 D- signal of Upstream Port USB2.0 D- signal of Downstream Ports I/O 8 V1.2 RTS5411 4.3 Buffer list 5V input buffer with internal 10K pull-up resistor OCP[4:1] (2) Open drain output buffer DSP_PWR [4:1] (1) 3.3V bi-directional buffer SCK.SCS, MISO, MOSI 3.3V bi-directional buffer with internal 200K pull-up resistor GPIO[7:0] 5V input buffer BPWR_DET, SPWR_DET 3.3V clock interface XTLI, XTLO USB2.0 interface DSP_DP [4:1], USP_DP, DSP_DM [4:1], USP_DM USB3.0 interface DSP_SSTX+[4:1], DSP_SSTX- [4:1], DSP_SSRX+[4:1], DSP_SSRX-[4:1], USP_SSTX+,USP_SSTX-,USP_SSRX+, USP_SSRXLDO interface LDO_V5_IN, V33_OUT Switching Regulator interface SWR_V5_IN, SWR_OUT (1) Use open drain output buffer by default when configured as active low. If configured as active high by F/W, it will use the 3.3V output buffer instead. (2) The pull-up resistors are only valid when the ‘power switch’ mode is selected. Realtek Semiconductor Corp. 9 V1.2 RTS5411 5. Electrical Characteristics 5.1 Absolute Maximum Ratings Parameter Power supply voltage Input voltage (1) Symbol Condition Rating V5IN 5.5 V VAV12,VDV12 -0.2 to 1.4 V VDV33 -0.5 to 4.1 V VI 3V buffer -0.5 to VDV33+0.5 V -0.5 to +6 V -0.5 to VDV33+0.5 V 6 mA 12 mA 5V buffer Open drain buffer Output voltage (2) VO Output current (3) IO Storage temperature 4mA Type (4) 8mA Type (4) Tstg Latch up Current Electrostatic Discharge Voltage (HBM) (1) Units -20 to +80 °C ±400 mA ±5 KV This parameter indicates voltage exceeding which damage or reduced reliability will occur when power is applied to an input pin. (2) This Parameter indicates voltage exceeding which damage or reduced reliability will occur when power is applied to an output pin. (3) This parameter indicates absolute tolerance values for DC current to prevent damage or reduced reliability when current flows out of or into output pin. (4) The output driving strength of all output is 4mA by default, which can be configured as 8mA by firmware through executing external codes. 5.2 Recommended Operating Ranges Parameter Power supply voltage Symbol Condition V5IN Active VAV12,VDV12 Disconnect / Suspend VDV33 Available current of 3.3V power (1) supply for external circuits Operating ambient temperature Absolute maximum junction temperature Surface Temperature of body (1) Min. Typ. Max. Units 4.45 5 5.25 V 1.08 1.2 1.32 V 1.0 1.08 1.32 V 2.97 3.3 3.63 V 150 mA V5IN=5V TA 0 +70 °C TJ 0 +125 °C PCB Layer:4L 0 +87.95 °C PCB Layer:2L 0 +93.47 °C TC Load current of external circuits shouldn’t exceed the max value when using on-chip LDO. It is recommended that the external circuits are limited to SPI Flash and LEDs Realtek Semiconductor Corp. 10 V1.2 RTS5411 5.3 DC Characteristics 5.3.1 DC Characteristics except USB differential signals The following specifications apply when power supply voltages are within the recommended operating ranges in section 6.2. Parameter (1) Input leakage current Input High Voltage Symbol II VIH Input Low Voltage VIL Output High Voltage VOH Output Low Voltage VOL TRI-STATE Output Leakage (2) Current Input pin Capacitance IOZ (1) Conditions 3V buffer, VI=VDV33 or GND 5V buffer, VI=V5IN or GND 3V buffer, Min. Max. Units -0.5 +0.5 µA -30 +30 µA 2 V 5V buffer 3V buffer 5V buffer 3.06 V V V 0.8 0.8 0.9VDV33 3.3V buffer, Vo= VDV33 or GND V 0.1VDV33 V +0.5 µA -0.5 Cin 10 pF This parameter indicates the current that flows through the input pin when power supply voltage is supplied to it. (2) This parameter indicates the current that flows through the output pin in tri-stated when the power supply voltage is applied to it. 5.3.2 USB 2.0 Interface DC Characteristics RTS5411 conforms to DC characteristics of Universal Serial Bus 2.0 Specification. Refer to the specification for more information. 5.3.3 USB 3.0 Interface DC Characteristics RTS5411 conforms to DC characteristics of Universal Serial Bus 3.0 Specification. Refer to the specification for more information. 5.4 AC Characteristics 5.4.1 System Clock The following specifications apply when power supply voltages and operating temperature are within the recommended operating ranges in section 5.2. Parameter Clock frequency Symbol FCLK Condition Crystal (1) Min. Typ. Max. Units -100ppm 12 100ppm MHz (1) Crystal used shall conform to the frequency ratings in the table over the temperature from 0°C to +70°C. Realtek Semiconductor Corp. 11 V1.2 RTS5411 5.5 Power Consumption The following consumption value applies upon the typical condition without on-chip LDO and Switch Regulator operating. The VDD33 and VDD12 are powered externally. TA= 25°C, VDD33(VDV33)= 3.3 V, VDD12(VAV12,VDV12)= 1.2 V. Device Connection Typical Supply Current(mA) VDD12 VDD33 Condition Typical Power(mW) (1) 3.9 9.8 1.5 (4) 3.5 (3) 6.2 12.8 31.0 16.8 92.6 Hub is connected to host controller both with SuperSpeed and High-Speed. Low-Speed data transfer on the four ports. 31.0 4.9 53.4 Hub is connected to host controller both with SuperSpeed and High-Speed. High-Speed data transfer on the four ports. 99.7 4.3 133.8 4 SS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Super-Speed (3) data transfer on the four ports. 118.6 (6) 442.2 2 SS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Super-Speed (3) data transfer on the two ports. 76.5 (6) 266.6 1 SS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Super-Speed (3) data transfer on one port. 4 SS/HS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Four SuperSpeed hubs are connected on all ports under SuperSpeed and High-Speed data (3) transfer. 178.4 (6) 536.6 No Upstream connection Suspend 4 FS devices 4 LS devices 4 HS devices Hub is not connected to host controller. 0.75 0.9 (2) 2.7 Hub is connected to host controller both with SuperSpeed and High-Speed. SuperSpeed hub goes into U3 state and USB2.0 hub goes into L2 state 1.0 Hub is connected to host controller both with SuperSpeed and High-Speed. Full-Speed data transfer on the four ports. (5) 38.8 (6) 47.2 (5) 270.4 686.4 (5) 25.4 (6) 30.4 (5) 175.6 420.2 56.4 (6) 181.8 (5) 18.7 (6) 22.0 (5) 129.4 290.8 (5) 37.5 (6) 45.9 (5) 337.8 795.4 (1) Charging mode is disabled (2) Charging mode is enabled (3) CDP function is disabled. The VDD33 power consumption will also decrease by 1mA in SS devices connection when CDP function is disabled (4) CDP function is enabled. (5) The SS devices under test support U1/U2 function. When the SS devices are Idle with little data transfer. The SuperSpeed hub will keep in U1/U2 power saving status most of the time. (6) The SS devices under test do not support U1/U2 function. So this is the worst case for SS power consumption Realtek Semiconductor Corp. 12 V1.2 RTS5411 The following consumption value applies upon the typical condition with on-chip LDO and Switch Regulator operating. Only VDD5 needs to be provided in this 5V mode. TA= 25°C, VDD5( V5IN) = 5 V. Device Connection No Upstream connection Suspend Typical Supply Current(mA) VDD5 Condition Hub is not connected to host controller. Typical Power(mW) 2.1 (2) 4.1 (1) 10.5 20.5 (3) Hub is connected to host controller both with SuperSpeed and High-Speed. SuperSpeed hub goes into U3 state and USB2.0 hub goes into L2 state 2.5 (4) 4.5 12.5 22.5 Hub is connected to host controller both with SuperSpeed and High-Speed. Full-Speed data transfer on the four ports. 27.8 139.0 Hub is connected to host controller both with SuperSpeed and High-Speed. Low-Speed data transfer on the four ports. 16.9 84.5 Hub is connected to host controller both with SuperSpeed and High-Speed. High-Speed data transfer on the four ports. 35.6 178.0 4 SS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Super-Speed (1) data transfer on the four ports. 76.4 (6) 182.6 2 SS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Super-Speed (1) data transfer on the two ports. 50.8 (6) 110.6 1 SS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Super-Speed (1) data transfer on one port. 37.4 (6) 76.8 4 SS/HS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Four SuperSpeed hubs are connected on all ports under SuperSpeed and High-Speed data (1) transfer. 93.8 (6) 216.6 4 FS devices 4 LS devices 4 HS devices (5) 382.0 913.0 (5) 254.0 553.0 (5) 187.0 384.0 (5) 469.0 1083.0 (1) Charging mode is disabled (2) Charging mode is enabled (3) CDP function is disabled. The VDD33 power consumption will also decrease by 1mA in SS devices connection when CDP function is disabled (4) CDP function is enabled. (5) The SS devices under test support U1/U2 function. When the SS devices are Idle with little data transfer. The SuperSpeed hub will keep in U1/U2 power saving status most of the time. (6) The SS devices under test do not support U1/U2 function. So this is the worst case for SS power consumption Realtek Semiconductor Corp. 13 V1.2 RTS5411 The following consumption value applies upon the typical condition with on-chip Switch Regulator operating. Only VDD33 needs to be provided in this 3.3V mode. TA= 25°C, VDD33(VDV33) = 3.3 V. Device Connection No Upstream connection Suspend Typical Supply Current(mA) VDD33 Condition Hub is not connected to host controller. Typical Power(mW) 2.0 (2) 4.0 (1) 6.6 13.2 (1) Hub is connected to host controller both with SuperSpeed and High-Speed. SuperSpeed hub goes into U3 state and USB2.0 hub goes into L2 state 2.4 (2) 4.4 7.9 14.5 Hub is connected to host controller both with SuperSpeed and High-Speed. Full-Speed data transfer on the four ports. 32.9 108.6 Hub is connected to host controller both with SuperSpeed and High-Speed. Low-Speed data transfer on the four ports. 20.3 67.0 Hub is connected to host controller both with SuperSpeed and High-Speed. High-Speed data transfer on the four ports. 48.6 160.4 4 SS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Super-Speed (1) data transfer on the four ports. 89.4 (6) 244.8 2 SS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Super-Speed (1) data transfer on the two ports. 59.6 (6) 146.6 1 SS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Super-Speed (1) data transfer on one port. 4 SS/HS devices Hub is connected to host controller both with SuperSpeed and High-Speed. Four SuperSpeed hubs are connected on all ports under SuperSpeed and High-Speed data (1) transfer. 114.9 (6) 295.2 4 FS devices 4 LS devices 4 HS devices (5) 295.0 807.8 (5) 196.7 483.8 44.5 (6) 101.2 (5) 146.9 334.0 (5) 379.2 974.2 (1) Charging mode is disabled (2) Charging mode is enabled (3) CDP function is disabled. The VDD33 power consumption will also decrease by 1mA in SS devices connection when CDP function is disabled (4) CDP function is enabled. (5) The SS devices under test support U1/U2 function. When the SS devices are Idle with little data transfer. The SuperSpeed hub will keep in U1/U2 power saving status most of the time. (6) The SS devices under test do not support U1/U2 function. So this is the worst case for SS power consumption Realtek Semiconductor Corp. 14 V1.2 RTS5411 5.6 Power On/Off Sequence When the on-chip LDO and switch regulator are not used, both 1.2V and 3.3V power need to be provided externally. The power on/off sequence between 1.2V and 3.3V need to be noticed as in Figure 5-1. During power on, it is recommended that the point where both power supplies are stabilized should be no later than 50ms after the start of the 3.3V rising. During power off, the end of 1.2V falling should be no later than 350ms after the start of 3.3V falling. Meanwhile, the falling time (0.9VDD to 0.1VDD) of 3.3V power should be no less than 50us. During the whole process, the voltage of 3.3V power should be always above the 1.2V power. When the 5V to 3.3V LDO is used and 1.2V power is provided externally. The power on/off sequence between 1.2V and 5V should be as the same as the sequence between 1.2V and 3.3V mentioned above. 3.3V 0.9VDD 1.2V 0.1VDD 0.9VDD 0.1VDD GND
RTS5411-GR 价格&库存
很抱歉,暂时无法提供与“RTS5411-GR”相匹配的价格&库存,您可以联系我们找货
