74HC00M/TR
74HC00M/TR
    HGSEMI(华冠)
    SOP-14
    四输入正与非门
74HC00M/TR 数据手册
74HC00           D Wide Operating Voltage Range of 2 V to 6 V D Outputs Can Drive Up To 10 LSTTL Loads D Low Power Consumption, 20-µA Max ICC D Typical tpd = 8 ns D ±4-mA Output Drive at 5 V D Low Input Current of 1 µA Max SN54HC00 . . . J OR W PACKAGE SN74HC00 . . . D, DB, N, NS, OR PW PACKAGE (TOP VIEW) 1 14 2 13 3 12 4 11 5 10 6 9 7 8 1B 1A NC VCC 4B VCC 4B 4A 4Y 3B 3A 3Y 1Y NC 2A NC 2B 4 3 2 1 20 19 18 5 17 6 16 7 15 8 14 9 10 11 12 13 4A NC 4Y NC 3B 2Y GND NC 3Y 3A 1A 1B 1Y 2A 2B 2Y GND SN54HC00 . . . FK PACKAGE (TOP VIEW) NC − No internal connection description The ’HC00 devices contain four independent 2-input NAND gates. They perform the Boolean function Y = A • B or Y = A + B in positive logic. FUNCTION TABLE (each gate) INPUTS OUTPUT Y A B H H L L X H X L H logic diagram (positive logic) A Y B http://www.hgsemi.com.cn 1 2018 MAR 74HC00 absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† Supply voltage range, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.5 V to 7 V Input clamp current, IIK (VI < 0 or VI > VCC) (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±20 mA Output clamp current, IOK (VO < 0 or VO > VCC) (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±20 mA Continuous output current, IO (VO = 0 to VCC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±25 mA Continuous current through VCC or GND . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±50 mA Package thermal impedance, θJA (see Note 2): D package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86°C/W DB package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 96°C/W N package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80°C/W NS package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 76°C/W PW package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 113°C/W Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −65°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTES: 1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 2. The package thermal impedance is calculated in accordance with JESD 51-7. recommended operating conditions (see Note 3) SN54HC00 VCC Supply voltage VIH High-level input voltage VCC = 2 V VCC = 4.5 V VCC = 6 V VCC = 2 V VIL Low-level input voltage MIN NOM MAX MIN NOM MAX 2 5 6 2 5 6 1.5 1.5 3.15 3.15 4.2 4.2 VCC = 4.5 V VCC = 6 V VI VO Input voltage 0 Output voltage 0 ∆t/∆v Input transition rise/fall time VCC = 2 V VCC = 4.5 V VCC = 6 V SN74HC00 0.5 0.5 1.35 1.8 1.8 0 0 V V 1.35 VCC VCC UNIT VCC VCC 1000 1000 500 500 400 400 V V V ns TA Operating free-air temperature −55 125 −40 85 °C NOTE 3: All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. http://www.hgsemi.com.cn 2 2018 MAR 74HC00 electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS IOH = −20 µA VOH VI = VIH or VIL IOH = −4 mA IOH = −5.2 mA IOL = 20 µA VOL VI = VIH or VIL IOL = 4 mA IOL = 5.2 mA II ICC VI = VCC or 0 VI = VCC or 0, IO = 0 VCC MIN TA = 25°C TYP MAX SN74HC00 MIN MIN MAX 2V 1.9 1.998 1.9 1.9 4.5 V 4.4 4.499 4.4 4.4 6V 5.9 5.999 5.9 5.9 4.5 V 3.98 4.3 3.7 3.84 6V 5.48 5.8 5.2 MAX UNIT V 5.34 2V 0.002 0.1 0.1 0.1 4.5 V 0.001 0.1 0.1 0.1 6V 0.001 0.1 0.1 0.1 4.5 V 0.17 0.26 0.4 0.33 6V 0.15 0.26 0.4 0.33 6V ±0.1 ±100 ±1000 ±1000 nA 2 40 20 µA 3 10 10 10 pF 6V Ci SN54HC00 2 V to 6 V V switching characteristics over recommended operating free-air temperature range, CL = 50 pF (unless otherwise noted) (see Figure 1) TA = 25°C TYP MAX SN54HC00 SN74HC00 MIN MIN PARAMETER FROM (INPUT) TO (OUTPUT) VCC 2V 45 90 135 115 tpd A or B Y 4.5 V 9 18 27 23 6V 8 15 23 20 tt Y MIN MAX MAX 2V 38 75 110 95 4.5 V 8 15 22 19 6V 6 13 19 16 UNIT ns ns operating characteristics, TA = 25°C PARAMETER Cpd TEST CONDITIONS Power dissipation capacitance per gate http://www.hgsemi.com.cn No load 3 TYP 20 UNIT pF 2018 MAR 74HC00 PARAMETER MEASUREMENT INFORMATION From Output Under Test Test Point Input VCC 50% 50% 0V CL = 50 pF (see Note A) tPLH In-Phase Output LOAD CIRCUIT 50% 10% tPHL 90% 90% tr Input 50% 10% 90% 90% tr tPHL VCC 50% 10% 0 V Out-of-Phase Output 90% tf tPLH 50% 10% tf VOLTAGE WAVEFORM INPUT RISE AND FALL TIMES VOH 50% 10% VOL tf 50% 10% 90% VOH VOL tr VOLTAGE WAVEFORMS PROPAGATION DELAY AND OUTPUT TRANSITION TIMES NOTES: A. CL includes probe and test-fixture capacitance. B. Phase relationships between waveforms were chosen arbitrarily. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tr = 6 ns, tf = 6 ns. C. The outputs are measured one at a time with one input transition per measurement. D. tPLH and tPHL are the same as tpd. Figure 1. Load Circuit and Voltage Waveforms http://www.hgsemi.com.cn 4 2018 MAR
74HC00M/TR 价格&库存
很抱歉,暂时无法提供与“74HC00M/TR”相匹配的价格&库存,您可以联系我们找货
