74HC02M/TR
74HC02M/TR
    HGSEMI(华冠)
    SOP-14
    四路2输入或非门高性能硅栅CMOS
74HC02M/TR 数据手册
74HC02 Quad 2−Input NOR Gate High−Performance Silicon−Gate CMOS The 74HC02 is identical in pinout to the LS02. The device inputs are compatible with standard CMOS outputs; with pullup resistors, they are compatible with LSTTL outputs. Features • • • • • • • • • Output Drive Capability: 10 LSTTL Loads Outputs Directly Interface to CMOS, NMOS, and TTL Operating Voltage Range: 2.0 to 6.0 V Low Input Current: 1.0 mA High Noise Immunity Characteristic of CMOS Devices In Compliance with the Requirements Defined by JEDEC Standard No. 7A ESD Performance: HBM > 2000 V; Machine Model > 200 V Chip Complexity: 40 FETs or 10 Equivalent Gates These are Pb−Free Devices B1 A2 B2 A3 B3 A4 B4 14 1 1 14 TSSOP−14 DT SUFFIX CASE 948G 14 1 LOGIC DIAGRAM A1 14 SOIC−14 D SUFFIX CASE 751A 1 2 1 3 5 4 6 Y1 Y2 Y=A+B 8 10 9 11 13 12 HC02 = Device Code A = Assembly Location WL or L = Wafer Lot Y = Year WW or W = Work Week G or G = Pb−Free Package Y3 (Note: Microdot may be in either location) Y4 FUNCTION TABLE Inputs PIN 14 = VCC PIN 7 = GND PIN ASSIGNMENT Output A B Y L L H H L H L H H L L L Y1 1 14 VCC A1 2 13 Y4 B1 3 12 B4 Y2 4 11 A4 ORDERING INFORMATION See detailed ordering and shipping information in the package dimensions section on page 4 of this data sheet. A2 5 10 Y3 B2 6 9 B3 GND 7 8 A3 HTTP://WWW.HGSEMI.NET 1 2014 APR ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ 74HC02 MAXIMUM RATINGS Symbol Parameter Value Unit – 0.5 to + 7.0 V DC Input Voltage (Referenced to GND) – 0.5 to VCC + 0.5 V DC Output Voltage (Referenced to GND) – 0.5 to VCC + 0.5 V VCC DC Supply Voltage (Referenced to GND) Vin Vout Iin DC Input Current, per Pin ±20 mA Iout DC Output Current, per Pin ±25 mA ICC DC Supply Current, VCC and GND Pins ±50 mA PD Power Dissipation in Still Air, 500 450 mW Tstg Storage Temperature – 65 to + 150 _C TL Lead Temperature, 1 mm from Case for 10 Seconds SOIC or TSSOP Package SOIC Package† TSSOP Package† This device contains protection circuitry to guard against damage due to high static voltages or electric fields. However, precautions must be taken to avoid applications of any voltage higher than maximum rated voltages to this high−impedance circuit. For proper operation, Vin and Vout should be constrained to the range GND v (Vin or Vout) v VCC. Unused inputs must always be tied to an appropriate logic voltage level (e.g., either GND or VCC). Unused outputs must be left open. _C 260 Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the Recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may affect device reliability. †Derating — SOIC Package: – 7 mW/_C from 65_ to 125_C TSSOP Package: − 6.1 mW/_C from 65_ to 125_C For high frequency or heavy load considerations, see Chapter 2 of the ON Semiconductor High−Speed CMOS Data Book (DL129/D). RECOMMENDED OPERATING CONDITIONS Symbol VCC Vin, Vout Parameter DC Supply Voltage (Referenced to GND) DC Input Voltage, Output Voltage (Referenced to GND) TA Operating Temperature, All Package Types tr, tf Input Rise and Fall Time (Figure 1) HTTP://WWW.HGSEMI.NET VCC = 2.0 V VCC = 4.5 V VCC = 6.0 V 2 Min Max Unit 2.0 6.0 V 0 VCC V – 55 + 125 _C 0 0 0 1000 500 400 ns 2014 APR 74HC02 ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ DC ELECTRICAL CHARACTERISTICS (Voltages Referenced to GND) Guaranteed Limit Symbol Parameter Test Conditions VCC (V) – 55 to 25_C v 85_C v 125°C Unit VIH Minimum High−Level Input Voltage Vout = 0.1 V or VCC – 0.1 V |Iout| v 20 mA 2.0 3.0 4.5 6.0 1.5 2.1 3.15 4.2 1.5 2.1 3.15 4.2 1.5 2.1 3.15 4.2 V VIL Maximum Low−Level Input Voltage Vout = 0.1 V or VCC – 0.1 V |Iout| v 20 mA 2.0 3.0 4.5 6.0 0.5 0.9 1.35 1.8 0.5 0.9 1.35 1.8 0.5 0.9 1.35 1.8 V VOH Minimum High−Level Output Voltage Vin = VIH or VIL |Iout| v 20 mA 2.0 4.5 6.0 1.9 4.4 5.9 1.9 4.4 5.9 1.9 4.4 5.9 V 3.0 4.5 6.0 2.48 3.98 5.48 2.34 3.84 5.34 2.20 3.7 5.2 2.0 4.5 6.0 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 3.0 4.5 6.0 0.26 0.26 0.26 0.33 0.33 0.33 0.4 0.4 0.4 Vin = VIH or VIL VOL Maximum Low−Level Output Voltage |Iout| v 2.4 mA |Iout| v 4.0 mA |Iout| v 5.2 mA Vin = VIH or VIL |Iout| v 20 mA Vin = VIH or VIL |Iout| v 2.4 mA |Iout| v 4.0 mA |Iout| v 5.2 mA V Iin Maximum Input Leakage Current Vin = VCC or GND 6.0 ±0.1 ±1.0 ±1.0 mA ICC Maximum Quiescent Supply Current (per Package) Vin = VCC or GND |Iout| = 0 mA 6.0 2.0 20 40 mA NOTE: Information on typical parametric values can be found in Chapter 2 of the ON Semiconductor High−Speed CMOS Data Book (DL129/D). AC ELECTRICAL CHARACTERISTICS (CL = 50 pF, Input tr = tf = 6.0 ns) Guaranteed Limit Symbol Parameter VCC (V) – 55 to 25_C v 85_C v 125_C Unit tPLH, tPHL Maximum Propagation Delay, Input A or B to Output Y (Figures 1 and 2) 2.0 3.0 4.5 6.0 75 30 15 13 95 40 19 16 110 55 22 19 ns tTLH, tTHL Maximum Output Transition Time, Any Output (Figures 1 and 2) 2.0 3.0 4.5 6.0 75 30 15 13 95 40 19 16 110 55 22 19 ns Maximum Input Capacitance — 10 10 10 pF Cin NOTE: For propagation delays with loads other than 50 pF, and information on typical parametric values, see Chapter 2 of the ON Semiconductor High−Speed CMOS Data Book (DL129/D). Typical @ 25°C, VCC = 5.0 V CPD 22 Power Dissipation Capacitance (Per Gate)* pF * Used to determine the no−load dynamic power consumption: PD = CPD VCC2f + ICC VCC. For load considerations, see Chapter 2 of the ON Semiconductor High−Speed CMOS Data Book (DL129/D). HTTP://WWW.HGSEMI.NET 3 2014 APR 74HC02 tf INPUT A OR B tr VCC 90% 50% 10% GND tPLH tPHL 90% 50% 10% OUTPUT Y tTLH tTHL Figure 1. Switching Waveforms TEST POINT OUTPUT DEVICE UNDER TEST C L* *Includes all probe and jig capacitance Figure 2. Test Circuit A Y B Figure 3. Expanded Logic Diagram (1/4 of the Device) HTTP://WWW.HGSEMI.NET 4 2014 APR
74HC02M/TR
物料型号:74HC02 器件简介:74HC02 是一个由四个独立的 2 输入正逻辑与非门(NAND)组成的集成电路。
引脚分配:1-Vcc,2-A1,3-B1,4-Y1,5-GND,6-B2,7-A2,8-Y2,9-GND,10-A3,11-B3,12-Y3,13-GND,14-B4,15-A4,16-Y4。
参数特性:工作电压范围 2V 到 6V,工作电流低,逻辑电平 NO 和 NC 分别代表逻辑 1 和 0。
功能详解:每个与非门有两个输入端和一个输出端,输出低电平表示两个输入端至少有一个是高电平。
应用信息:广泛应用于数字逻辑电路设计中,如构成触发器、寄存器、计数器等。
封装信息:通常采用双列直插式封装(DIP)或表面贴装封装(SMD)。
74HC02M/TR 价格&库存
很抱歉,暂时无法提供与“74HC02M/TR”相匹配的价格&库存,您可以联系我们找货
74HC02M/TR
  • 5+0.42493
  • 20+0.38743
  • 100+0.34994
  • 500+0.31245
  • 1000+0.29495
  • 2000+0.28245
74HC02M/TR
    • 5+0.65114
    • 50+0.52078
    • 150+0.45555
    • 500+0.40662
    • 2500+0.36742
    • 5000+0.34787
    库存:1552
