CD4094B
8-Bit Shift Register/Latch with 3-STATE Outputs
General Description
the latch to 3-STATE output gates. These gates are
enabled when OUTPUT ENABLE is taken HIGH.
The CD4094B consists of an 8-bit shift register and a 3STATE 8-bit latch. Data is shifted serially through the shift
register on the positive transition of the clock. The output of
the last stage (QS) can be used to cascade several
devices. Data on the QS output is transferred to a second
output, Q′S, on the following negative clock edge.
Features
■ Wide supply voltage range:
■ High noise immunity:
3.0V to 18V
0.45 VDD (typ.)
■ Low power TTL compatibility:
The output of each stage of the shift register feeds a latch,
which latches data on the negative edge of the STROBE
input. When STROBE is HIGH, data propagates through
Fan out of 2 driving 74L or 1 driving 74LS
■ 3-STATE outputs
Devices also available in Tape and Reel. Specify by appending the suffix letter “X” to the ordering code.
Connection Diagram
Pin Assignments for DIP and SOP
Top View
Truth Table
Clock
X = Don't Care
= HIGH-to-LOW
= LOW-to-HIGH
Output
Strobe
Data
Parallel Outputs
Enable
Serial Outputs
Q1
QN
QS
(Note 1)
Q′Σ
Hi-Z
Hi-Z
Q7
No Change
Hi-Z
Hi-Z
No Change
Q7
Q7
No Change
X
X
X
X
1
X
1
1
QN−1
Q7
No Change
1
1
1
1
QN−1
Q7
No Change
1
1
1
No Change No Change
No Change No Change No Change
Q7
Note 1: At the positive clock edge, information in the 7th shift register stage is transferred to Q8 and QS.
http://www.hgsemi.com.cn
1
2018 JUN
CD4094B
Block Diagram
2
2018 JUN
CD4094B
Absolute Maximum Ratings(Note 2)
Recommended Operating
Conditions (Note 3)
(Note 3)
−0.5 to +18 VDC
Supply Voltage (VDD)
Input Voltage (VIN)
Input Voltage (VIN)
−65°C to +150°C
Storage Temperature Range (TS)
Power Dissipation (PD)
Dual-In-Line
700 mW
Small Outline
500 mW
Lead Temperature (TL)
(Soldering, 10 seconds)
260°C
+3.0 to +15 VDC
DC Supply Voltage (VDD)
−0.5 to VDD +0.5 VDC
0 to VDD VDC
−40°C to +85°C
Operating Temperature Range (TA)
Note 2: “Absolute Maximum Ratings” are those values beyond which the
safety of the device cannot be guaranteed; they are not meant to imply that
the devices should be operated at these limits. The tables of “Recommended Operating Conditions” and “Electrical Characteristics” provide conditions for actual device operation.
Note 3: VSS = 0V unless otherwise specified.
DC Electrical Characteristics (Note 3)
Symbol
IDD
VOL
Parameter
−40°C
Conditions
Min
IOL
IOH
IIN
IOZ
+85°C
Max
Min
Max
Units
VDD = 5.0V
µA
VDD = 10V
40
40
300
µA
VDD = 15V
80
80
600
µA
LOW Level
VDD = 5.0V
0.05
0.05
V
Output Voltage
VDD = 10V
0.05
0.05
V
0.05
0.05
V
HIGH Level
VDD = 5.0V
Output Voltage
VDD = 10V
LOW Level
Input Voltage
VIH
Typ
Device Current
|IO| ≤ 1.0 µA
|IO| ≤ 1 µA
VDD = 15V
VIL
Min
Quiescent
VDD = 15V
VOH
+25°C
Max
4.95
4.95
5.0
4.95
V
9.95
9.95
10.0
9.95
V
14.95
14.95
15.0
14.95
VDD = 5.0V, VO = 0.5V or 4.5V
1.5
1.5
V
1.5
V
VDD = 10V, VO = 1.0V or 9.0V
3.0
3.0
3.0
V
VDD = 15V, VO = 1.5V or 13.5V
4.0
4.0
4.0
V
HIGH Level
3.5
3.5
3.5
Input Voltage
7.0
7.0
7.0
V
11.0
11.0
11.0
V
LOW Level
VDD = 5.0V, VO = 0.4V
0.52
0.44
0.88
0.36
mA
Output Current
VDD = 10V, VO = 0.5V
1.3
1.1
2.25
0.9
mA
mA
V
(Note 4)
3.6
3.0
8.8
2.4
HIGH Level
VDD = 5.0V, VO = 4.6V
−0.52
−0.44
0.88
−0.36
mA
Output Current
VDD = 10V, VO = 9.5V
−1.3
−1.1
2.25
−0.9
mA
(Note 4)
VDD = 15V, VO = 13.5V
−3.6
−3.0
8.8
Input Current
VDD = 15V, VIN = 0V
−0.3
−0.3
−1.0
µA
VDD = 15V, VIN = 15V
0.3
0.3
1.0
µA
1
1
10
µA
3-STATE Output
VDD = 15V, VIN = 0V or 15V
−2.4
mA
Leakage Current
Note 4: IOH and IOL are tested one output at a time.
3
2018 JUN
CD4094B
AC Electrical Characteristics
(Note 5)
TA = 25°C, CL = 50 pF
Symbol
tPHL, tPLH
tPHL, tPLH
tPHL, tPLH
tPHL, tPLH
tPHZ
tPLZ
tPZH
tPZL
tTHL, tTLH
tSU
tr , tf
Parameter
tPS
fmax
CIN
Min
Typ
Max
Units
Propagation Delay
VDD = 5.0V
300
600
ns
Clock to QS
VDD = 10V
125
250
ns
ns
VDD = 15V
95
190
Propagation Delay
VDD = 5.0V
230
460
ns
Clock to Q′Σ
VDD = 10V
110
220
ns
VDD = 15V
75
150
ns
Propagation Delay Clock
VDD = 5.0V
420
840
ns
to Parallel Out
VDD = 10V
195
390
ns
VDD = 15V
135
270
ns
Propagation Delay Strobe
VDD = 5.0V
290
580
ns
to Parallel Out
VDD = 10V
145
290
ns
VDD = 15V
100
200
ns
Propagation Delay HIGH
VDD = 5.0V
140
280
ns
Level to HIGH Impedance
VDD = 10V
75
150
ns
VDD = 15V
55
110
ns
Propagation Delay LOW
VDD = 5.0V
140
280
ns
VDD = 10V
75
150
ns
VDD = 15V
55
110
ns
VDD = 5.0V
140
280
ns
Impedance to HIGH Level
VDD = 10V
75
150
ns
VDD = 15V
55
110
ns
VDD = 5.0V
140
280
ns
Impedance to LOW Level
VDD = 10V
75
150
ns
VDD = 15V
55
110
ns
VDD = 5.0V
100
200
ns
VDD = 10V
50
100
ns
VDD = 15V
40
80
ns
Transition Time
Set-Up Time
VDD = 5.0V
80
40
ns
Data to Clock
VDD = 10V
40
ns
VDD = 15V
VDD = 5.0V
1
ms
ms
Maximum Clock Rise
ns
VDD = 10V
1
VDD = 15V
1
Minimum Clock
VDD = 5.0V
200
100
Pulse Width
VDD = 10V
100
50
ns
VDD = 15V
83
40
ns
Minimum Strobe
VDD = 5.0V
200
100
ns
Pulse Width
VDD = 10V
80
40
ns
VDD = 15V
70
35
ns
Maximum Clock Frequency
VDD = 5.0V
1.5
3.0
MHz
VDD = 10V
3.0
6.0
MHz
VDD = 15V
4.0
8.0
and Fall Time
tPC
Conditions
Input Capacitance
Any Input
ms
5.0
ns
MHz
7.5
pF
Note 5: AC Parameters are guaranteed by DC correlated testing.
4
2018 JUN
CD4094B
Timing Diagram
Test Circuits and Timing Diagrams for 3-STATE
5
2018 JUN
很抱歉,暂时无法提供与“CD4094BM/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.84040
- 100+0.56100
- 1250+0.50930
- 2500+0.46750
- 国内价格
- 5+1.11705
- 50+0.88830
- 150+0.79035
- 500+0.66798
- 2500+0.61355
- 5000+0.58094
