CD4511BM/TR
CD4511BM/TR
    HGSEMI(华冠)
    SOP-16
    BCD-to-7段锁存器/解码器/驱动器 SOP16_150MIL 3~15V
CD4511BM/TR 数据手册
CD4511BM/BC CD4511BM/CD4511BC BCD-to-7 Segment Latch/Decoder/Driver General Description Features The CD4511BM/CD4511BC BCD-to-seven segment latch/ decoder/driver is constructed with complementary MOS (CMOS) enhancement mode devices and NPN bipolar output drivers in a single monolithic structure. The circuit provides the functions of a 4-bit storage latch, an 8421 BCD-toseven segment decoder, and an output drive capability. Lamp test (LT), blanking (BI), and latch enable (LE) inputs are used to test the display, to turn-off or pulse modulate the brightness of the display, and to store a BCD code, respectively. It can be used with seven-segment light emitting diodes (LED), incandescent, fluorescent, gas discharge, or liquid crystal readouts either directly or indirectly. Y Y Y Y Y Y Y Y Y Low logic circuit power dissipation High current sourcing outputs (up to 25 mA) Latch storage of code Blanking input Lamp test provision Readout blanking on all illegal input combinations Lamp intensity modulation capability Time share (multiplexing) facility Equivalent to Motorola MC14511 Applications include instrument (e.g., counter, DVM, etc.) display driver, computer/calculator display driver, cockpit display driver, and various clock, watch, and timer uses. Connection Diagram Truth Table Inputs Dual-In-Line Package Outputs LE BI LT D C B A a b c d e f g Display TL/F/5991 – 1 Top View Order Number CD4511B X X 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 X 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 X X 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 X X X 0 0 0 0 1 1 1 1 0 0 0 0 1 1 1 1 X X X 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 X X X 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 X 1 0 1 0 1 1 0 1 0 1 1 1 0 0 0 0 0 0 1 0 1 1 1 1 1 0 0 1 1 1 0 0 0 0 0 0 1 0 1 1 0 1 1 1 1 1 1 1 0 0 0 0 0 0 1 0 1 0 1 1 0 1 1 0 1 0 0 0 0 0 0 0 * 1 0 1 0 1 0 0 0 1 0 1 0 0 0 0 0 0 0 1 0 1 0 0 0 1 1 1 0 1 1 0 0 0 0 0 0 1 0 0 0 1 1 1 1 1 0 1 1 0 0 0 0 0 0 B 0 1 2 3 4 5 6 7 8 9 * X e Don’t Care Segment Identification *Depends upon the BCD code applied during the 0 to 1 transition of LE. Display TL/F/5991–3 TL/F/5991 – 2 http://www.hgsemi.com.cn 1 2018 AUG CD4511BM/BC Absolute Maximum Ratings (Notes 1 & 2) If Military/Aerospace specified devices are required, please contact the National Semiconductor Sales Office/Distributors for availability and specifications. b 0.5V to a 18V DC Supply Voltage (VDD) Input Voltage (VIN) Storage Temperature Range (TS) Power Dissipation (PD) Dual-In-Line Small Outline Lead Temperature (TL) (Soldering, 10 seconds) Recommended Operating Conditions (Note 2) DC Supply Voltage (VDD) Input Voltage (VIN) Operating Temperature Range (TA) CD4510BM, CD4516BM CD4510BC, CD4516BC b 0.5V to VDD a 0.5V b 65§ C to a 150§ C 3V to 15V 0V to VDD b 55§ C to a 125§ C b 40§ C to a 85§ C 700 mW 500 mW 260§ C DC Electrical Characteristics CD4511BM Symbol Parameter b 55§ C Conditions Min Max a 25§ C Min Typ 5 10 20 a 125§ C Max Min Units Max IDD Quiescent Supply Current VDD e 5V, VIN e VDD or VSS VDD e 10V, VIN e VDD or VSS VDD e 15V, VIN e VDD or VSS VOL Output Voltage Logical ‘‘0’’ Level VDD e 5V VDD e 10V VDD e 15V VOH Output Voltage Logical ‘‘1’’ Level VDD e 5V VDD e 10V VDD e 15V VIL Low Level Input Voltage VDD e 5V, VOUT e 3.8V or 0.5V VDD e 10V, VOUT e 8.8V or 1.0V VDD e 15V, VOUT e 13.8V or 1.5V VIH High Level Input Voltage VDD e 5V, VOUT e 0.5V or 3.8V VDD e 10V, VOUT e 1.0V or 8.8V VDD e 15V, VOUT e 1.5V or 13.8V 3.5 7.0 11.0 3.5 7.0 11.0 3 6 9 3.5 7.0 11.0 V V V VOH Output (Source) Drive Voltage VDD VDD VDD VDD VDD VDD e e e e e e 5V, IOH 5V, IOH 5V, IOH 5V, IOH 5V, IOH 5V, IOH 4.1 4.1 4.1 3.9 3.9 3.4 3.4 4.57 4.24 4.12 3.94 3.75 3.54 V V V V V V VDD VDD VDD VDD VDD VDD e e e e e e 10V, IOH 10V, IOH 10V, IOH 10V, IOH 10V, IOH 10V, IOH e e e e e e 0 mA 5 mA 10 mA 15 mA 20 mA 25 mA 9.1 9.1 9.1 9.0 9.0 8.6 8.6 9.58 9.26 9.17 9.04 8.9 8.75 VDD VDD VDD VDD VDD VDD e e e e e e 15V, IOH 15V, IOH 15V, IOH 15V, IOH 15V, IOH 15V, IOH e e e e e e 0 mA 5 mA 10 mA 15 mA 20 mA 25 mA 14.1 14.1 14.1 14.0 14.0 13.6 13.6 9.58 14.27 14.17 14.07 13.95 13.8 0.64 1.6 4.2 0.51 1.3 3.4 0.88 2.25 8.8 0.36 0.9 2.4 0.01 0.01 0.01 4.1 9.1 14.1 e e e e e e 0 mA 5 mA 10 mA 15 mA 20 mA 25 mA IOL Low Level Output Current VDD e 5V, VOL e 0.4V VDD e 10V, VOL e 0.5V VDD e 15V, VOL e 1.5V IIN Input Current VDD e 15V, VIN e 0V VDD e 15V, VIN e 15V 0 0 0 4.1 9.1 14.1 1.5 3.0 4.0 5 10 20 150 300 600 mA mA mA 0.01 0.01 0.01 0.05 0.05 0.05 V V V 4.57 9.58 14.59 2 4 6 4.1 9.1 14.1 1.5 3.0 4.0 V V V 1.5 3.0 4.0 3.5 3.0 V V V V V V V V V 8.6 8.2 V V V V V V 13.6 13.2 mA mA mA b 0.10 b 10 b 5 b 0.10 b 1.0 0.10 10b5 0.10 1.0 mA mA Note 1: Devices should not be connected with power on. http://www.hgsemi.com.cn 2 2018 AUG CD4511BM/BC DC Electrical Characteristics CD4511BC Symbol Parameter b 55§ C Conditions Min Max a 25§ C Min Typ a 85§ C Max Min Units Max IDD Quiescent Supply Current VDD e 5V VDD e 10V VDD e 15V 20 40 80 VOL Output Voltage Logical ‘‘0’’ Level VDD e 5V VDD e 10V VDD e 15V 0.01 0.01 0.01 VOH Output Voltage Logical ‘‘1’’ Level VDD e 5V VDD e 10V VDD e 15V VIL Low Level Input Voltage VDD e 5V, VOUT e 3.8V or 0.5V VDD e 10V, VOUT e 8.8V or 1.0V VDD e 15V, VOUT e 13.8V or 1.5V VIH High Level Input Voltage VDD e 5V, VOUT e 0.5V or 3.8V VDD e 10V, VOUT e 1.0V or 8.8V VDD e 15V, VOUT e 1.5V or 13.8V 3.5 7.0 11.0 3.5 7.0 11.0 3 6 9 3.5 7.0 11.0 V V V VOH Output (Source) Drive Voltage VDD VDD VDD VDD VDD VDD e e e e e e 5V, IOH 5V, IOH 5V, IOH 5V, IOH 5V, IOH 5V, IOH 4.1 4.1 4.1 3.6 3.6 2.8 2.8 4.57 4.24 4.12 3.94 3.75 3.54 V V V V V V VDD VDD VDD VDD VDD VDD e e e e e e 10V, IOH 10V, IOH 10V, IOH 10V, IOH 10V, IOH 10V, IOH e e e e e e 0 mA 5 mA 10 mA 15 mA 20 mA 25 mA 9.1 9.1 9.1 8.75 8.75 8.1 8.1 9.58 9.26 9.17 9.04 8.9 8.75 VDD VDD VDD VDD VDD VDD e e e e e e 15V, IOH 15V, IOH 15V, IOH 15V, IOH 15V, IOH 15V, IOH e e e e e e 0 mA 5 mA 10 mA 15 mA 20 mA 25 mA 14.1 14.1 13.75 13.75 13.1 13.1 0.52 1.3 3.6 0.44 1.1 3.0 4.1 9.1 14.1 e e e e e e Low Level Output Current VDD e 5V, VOL e 0.4V VDD e 10V, VOL e 0.5V VDD e 15V, VOL e 1.5V IIN Input Current VDD e 15V, VIN e 0V VDD e 15V, VIN e 15V http://www.hgsemi.com.cn 4.1 9.1 14.1 1.5 3.0 4.0 0 mA 5 mA 10 mA 15 mA 20 mA 25 mA IOL 0 0 0 3 20 40 80 150 300 600 mA mA mA 0.01 0.01 0.01 0.05 0.05 0.05 V V V 4.57 9.58 14.59 2 4 6 4.1 9.1 14.1 1.5 3.0 4.0 V V V 1.5 3.0 4.0 3.3 2.5 V V V V V V 8.45 7.8 14.59 14.27 14.18 14.07 13.95 13.8 14.1 V V V V V V 13.45 12.8 0.88 2.25 8.8 V V V 0.36 0.9 2.4 mA mA mA b 0.30 b 10 b 5 b 0.30 b 1.0 0.30 10b5 0.30 1.0 mA mA 2018 AUG CD4511BM/BC AC Electrical Characteristics* TA e 25§ C and CL e 50 pF, typical temperature coefficient for all values of VDD e 0.3%/§ C Symbol Parameter CD4511BX Conditions Min Units Typ Max CIN Input Capacitance VIN e 0 5.0 7.5 pF tr Output Rise Time (Figure 1a) VDD e 5V VDD e 10V VDD e 15V 40 30 25 80 60 50 ns ns ns tf Output Fall Time (Figure 1a) VDD e 5V VDD e 10V VDD e 15V 125 75 65 250 150 130 ns ns ns tPLH Turn-Off Delay Time (Data) (Figure 1a) VDD e 5V VDD e 10V VDD e 15V 640 250 175 1280 500 350 ns ns ns tPHL Turn-On Delay Time (Data) (Figure 1a) VDD e 5V VDD e 10V VDD e 15V 720 290 195 1440 580 400 ns ns ns tPLH Turn-Off Delay Time (Blank) (Figure 1a) VDD e 5V VDD e 10V VDD e 15V 320 130 100 640 260 200 ns ns ns tPHL Turn-On Delay Time (Blank) (Figure 1a) VDD e 5V VDD e 10V VDD e 15V 485 200 160 970 400 320 ns ns ns tPLH Turn-Off Delay Time (Lamp Test) (Figure 1a) VDD e 5V VDD e 10V VDD e 15V 313 125 90 625 250 180 ns ns ns tPHL Turn-On Delay Time (Lamp Test) (Figure 1a) VDD e 5V VDD e 10V VDD e 15V 313 125 90 625 250 180 ns ns ns tSETUP Setup Time (Figure 1b) VDD e 5V VDD e 10V VDD e 15V 180 76 40 90 38 20 ns ns ns tHOLD Hold Time (Figure 1b) VDD e 5V VDD e 10V VDD e 15V 0 0 0 b 90 b 38 b 20 ns ns ns PWLE Minimum Latch Enable Pulse Width (Figure 1c) VDD e 5V VDD e 10V VDD e 15V 520 220 130 260 110 65 ns ns ns *AC Parameters are guaranteed by DC correlated testing. http://www.hgsemi.com.cn 4 2018 AUG CD4511BM/BC Switching Time Waveforms TL/F/5991 – 4 FIGURE 1 Typical Applications Light Emitting Diode (LED) Readout TL/F/5991 – 6 TL/F/5991 – 5 http://www.hgsemi.com.cn 5 2018 AUG CD4511BM/BC Typical Applications (Continued) Liquid Crystal (LC) Readout Gas Discharge Readout TL/F/5991 – 7 TL/F/5991 – 8 Direct DC drive of LC’s not recommended for life of LC readouts. Incandescent Readout Fluorescent Readout TL/F/5991 – 9 **A filament pre-warm resistor is recommended to reduce filament thermal shock and increase the effective cold resistance of the filament. http://www.hgsemi.com.cn TL/F/5991 – 10 6 2018 AUG
CD4511BM/TR
1. 物料型号:CD4511BM是德州仪器(Texas Instruments)生产的一款CMOS 4位二进制计数器。
2. 器件简介:CD4511BM是一个用于计数的集成电路,它能够实现二进制计数功能,常用于数字电路中,如频率计数器、定时器等。
3. 引脚分配:CD4511BM通常有14个引脚,包括时钟输入、使能端、清零端、进位输出、数据输入输出等。
4. 参数特性:包括工作电压范围、工作温度范围、功耗、计数速率等。
5. 功能详解:CD4511BM能够实现0到15的计数,具有同步清零和同步预置功能,可以用于构建更复杂的计数器或分频器。
6. 应用信息:广泛应用于数字电子系统中,如数字钟表、频率计、定时器等。
7. 封装信息:CD4511BM通常采用DIP-14封装,也有其他封装形式。
