HG2277M/TR
HG2277M/TR
    HGSEMI(华冠)
    SOP-8
    高精度运算放大器 SOP8
HG2277M/TR 数据手册
HG277/HG2277/HG4277 HG277/HG2277/HG4277 High Precision Operational Amplifiers 1 Features • • • • • • • • • 1 HGx277 series operational amplifiers operate from ±2-V to ±18-V supplies with excellent performance. Unlike most operational amplifiers which are specified at only one supply voltage, the HGx277 series is specified for real-world applications; a single limit applies over the ±5-V to ±15-V supply range. High performance is maintained as the amplifiers swing to their specified limits. Because the initial offset voltage (±20 μV maximum) is so low, user adjustment is usually not required. However, the single version (HG277) provides external trim pins for special applications. Ultralow Offset Voltage: 10 μV Ultralow Drift: ±0.1 μV/°C High Open-Loop Gain: 134 dB High Common-Mode Rejection: 140 dB High Power Supply Rejection: 130 dB Low Bias Current: 1-nA maximum Wide Supply Range: ±2 V to ±18 V Low Quiescent Current: 800 μA/amplifier Single, Dual, and Quad Versions HG277 operational amplifiers are easy to use and free from phase inversion and the overload problems found in some other operational amplifiers. They are stable in unity gain and provide excellent dynamic behavior over a wide range of load conditions. Dual and quad versions feature completely independent circuitry for lowest crosstalk and freedom from interaction, even when overdriven or overloaded. 2 Applications • • • • • • • Transducer Amplifiers Bridge Amplifiers Temperature Measurements Strain Gage Amplifiers Precision Integrators Battery-Powered Instruments Test Equipment Device Information(1) PART NUMBER PACKAGE BODY SIZE (NOM) VSON (8) 4.00 mm × 4.00 mm SOIC (8) 3.91 mm × 4.90 mm 3 Description PDIP (8) 6.35 mm × 9.81 mm The HGx277 series precision operational amplifiers replace the industry standard HG-177. They offer improved noise, wider output voltage swing, and are twice as fast with half the quiescent current. Features include ultralow offset voltage and drift, low bias current, high common-mode rejection, and high power supply rejection. Single, dual, and quad versions have identical specifications, for maximum design flexibility. SOIC (14) 3.91 mm × 8.65 mm PDIP (14) 6.35 mm × 19.30 mm HG277 HG2277 HG4277 (1) For all available packages, see the orderable addendum at the end of the data sheet. 0.1 Hz to 10 Hz Noise 50nV/div Noise signal is bandwidth limited to lie between 0.1Hz and 10Hz. 1s/div http://www.hgsemi.com.cn 1 2018 AUG HG277/HG2277/HG4277 4 Pin Configuration and Functions HG277 DRM Package 8-Pin VSON Top View HG277 P and D Packages 8-Pin PDIP and SOIC Top View Offset Trim 1 8 Offset Trim –In 2 7 V+ +In 3 6 Output V– 4 5 NC(1) Offset Trim 1 Pin 1 Indicator 8 Offset Trim 7 V+ −In 2 +In 3 6 Output V− 4 5 NC Thermal Pad on Bottom (Connect to V−) Pin Functions: HG277 PIN NO. I/O NAME DESCRIPTION 1 Offset Trim I Input offset voltage trim (leave floating if not used) 2 –In I Inverting input 3 +In I 4 V– — 5 NC — No internal connection (can be left floating) 6 Output O Output Noninverting input Negative (lowest) power supply 7 V+ — Positive (highest) power supply 8 Offset Trim — Input offset voltage trim (leave floating if not used) HG2277 DRM Package 8-Pin VSON Top View HG2277 P and D Packages 8-Pin PDIP and SOIC Top View Out A –In A 1 2 +In A 3 V– 4 8 A B Out A V+ 7 Out B 6 –In B 5 +In B 1 Pin 1 Indicator 8 Out B 7 V+ −In A 2 +In A 3 6 −In B V− 4 5 +In B Thermal Pad on Bottom (Connect to V−) Pin Functions: HG2277 PIN I/O DESCRIPTION NAME PDIP, SOIC NO. DFN NO. Out A 1 1 O Output channel A –In A 2 2 I Inverting input channel A +In A 3 3 I Noninverting input channel A V– 4 4 — +In B 5 5 I Noninverting input channel B –In B 6 6 I Inverting input channel B Out B 7 8 O Output channel B V+ 8 7 — Positive (highest) power supply http://www.hgsemi.com.cn Negative (lowest) power supply 2 2018 AUG HG277/HG2277/HG4277 HG4277 P and D Packages 14 Pins PDIP and SOIC Top View Out A 1 14 Out D –In A 2 13 –In D A D +In A 3 12 +In D V+ 4 11 V– +In B 5 10 +In C B C –In B 6 9 –In C Out B 7 8 Out C Pin Functions: HG4277 PIN I/O DESCRIPTION NO. NAME 1 Out A O Output channel A 2 –In A I Inverting input channel A 3 +In A I Noninverting input channel A 4 V+ — 5 +In B I Noninverting input channel B 6 –In B I Inverting input channel B Positive (highest) power supply 7 Out B O Output channel B 8 Out C O Output channel C 9 –In C I Inverting input channel C 10 +In C I Noninverting input channel C 11 V– — 12 +In D I Noninverting input channel D 13 –In D I Inverting input channel D 14 Out D O Output channel D http://www.hgsemi.com.cn Negative (lowest) power supply 3 2018 AUG HG277/HG2277/HG4277 5 Specifications 5.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) MIN MAX UNIT 36 V (V+) +0.7 V Supply voltage, Vs = (V+) – (V–) Input voltage (V–) –0.7 Output short-circuit (2) Continuous Operating temperature –55 125 °C Junction temperature 150 °C Lead temperature 300 °C 125 °C Storage temperature, Tstg (1) (2) –55 Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Short-circuit to ground, one amplifier per package. 5.2 ESD Ratings VALUE Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001 V(ESD) (1) (2) Electrostatic discharge (1) UNIT ±2000 Charged-device model (CDM), per JEDEC specification JESD22C101 (2) ±500 V JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. 5.3 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) Supply voltage, Vs = (V+) – (V–) Specified temperature MIN NOM MAX 4 (±2) 30 (±15) 36 (±18) V +85 °C –40 UNIT 5.4 Thermal Information for HG277 HG277 THERMAL METRIC (1) P (PDIP) RθJA Junction-to-ambient thermal resistance 49.2 RθJC(top) Junction-to-case (top) thermal resistance 39.4 RθJB Junction-to-board thermal resistance ψJT Junction-to-top characterization parameter ψJB RθJC(bot) D (SOIC) DRM (VSON) UNIT 110.1 40.7 °C/W 52.2 41.3 °C/W 26.4 52.3 16.7 °C/W 15.4 10.4 0.6 °C/W Junction-to-board characterization parameter 26.3 51.5 16.9 °C/W Junction-to-case (bottom) thermal resistance — — 3.3 °C/W 8 PINS (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report, SPRA953. 5.5 Thermal Information for HG2277 HG2277 THERMAL METRIC (1) P (PDIP) RθJA Junction-to-ambient thermal resistance 47.2 RθJC(top) Junction-to-case (top) thermal resistance 36.0 D (SOIC) DRM (VSON) UNIT 107.4 39.3 °C/W 45.8 36.9 °C/W 8 PINS (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report, SPRA953. http://www.hgsemi.com.cn 4 2018 AUG HG277/HG2277/HG4277 Thermal Information for HG2277 (continued) HG2277 THERMAL METRIC (1) P (PDIP) D (SOIC) DRM (VSON) UNIT 8 PINS RθJB Junction-to-board thermal resistance 24.4 47.9 15.4 °C/W ψJT Junction-to-top characterization parameter 13.4 5.7 0.4 °C/W ψJB Junction-to-board characterization parameter 24.3 47.3 15.6 °C/W RθJC(bot) Junction-to-case (bottom) thermal resistance — — 2.2 °C/W 5.6 Thermal Information for HG4277 HG4277 THERMAL METRIC (1) D (SOIC) P (PDIP) UNIT 14 PINS RθJA Junction-to-ambient thermal resistance 67.0 66.3 °C/W RθJC(top) Junction-to-case (top) thermal resistance 24.1 20.5 °C/W RθJB Junction-to-board thermal resistance 22.5 26.8 °C/W ψJT Junction-to-top characterization parameter 2.2 2.1 °C/W ψJB Junction-to-board characterization parameter 22.1 26.2 °C/W RθJC(bot) Junction-to-case (bottom) thermal resistance — — °C/W (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report, SPRA953. 5.7 Electrical Characteristics for HGx277P, HGx277U, and HGx277xA At TA = 25°C, and RL = 2 kΩ, unless otherwise noted PARAMETER HG277xA HG2277xA HG4277xA HG277P, U HG2277P, U TEST CONDITIONS MIN (1) MAX ±10 ±20 TYP MIN UNIT (1) MAX ±20 ±50 TYP OFFSET VOLTAGE V0S Input Offset Voltage HG277P, U (high-grade, single) Input Offset Voltage Over Temperature HG2277P, U (high-grade, dual) µV ±30 TA = –40°C to 85°C ±50 µV All PA, UA, Versions ±100 AIDRM Versions HG277P, U (high-grade, single) dV0S/dT Input Offset Voltage Drift HG2277P, U (high-grade, dual) TA = –40°C to 85°C ±0.1 ±0.15 ±0.1 ±0.25 All PA, UA, AIDRM Versions ±0.15 vs Time Input Offset Voltage: (all models) vs Power Supply (PSRR) Channel Separation (dual, quad) (1) (2) µV/°C 0.2 VS = ±2 V to ±18 V ±0.3 ±0.5 See (2) See (2) ±1 µV/mo ±1 µV/V TA = –40°C to 85°C ±0.5 DC 0.1 ±1 See (2) µV/V VS = ±15 V Specifications are the same as HG277P, U. http://www.hgsemi.com.cn 5 2018 AUG HG277/HG2277/HG4277 Electrical Characteristics for HGx277P, HGx277U, and HGx277xA (continued) At TA = 25°C, and RL = 2 kΩ, unless otherwise noted PARAMETER HG277xA HG2277xA HG4277xA HG277P, U HG2277P, U TEST CONDITIONS MIN TYP (1) MAX ±1 MIN UNIT TYP (1) MAX See (2) ±2.8 INPUT BIAS CURRENT IB Input Bias Current TA = –40°C to 85°C ±0.5 IOS Input Offset Current TA = –40°C to 85°C ±0.5 ±2 ±4 ±1 See (2) ±2.8 ±2 ±4 nA nA NOISE Input Voltage Noise, f = 0.1 to 10 Hz en in Input Voltage Noise Density 0.22 See (2) (2) f = 10 Hz 12 See f = 100 Hz 8 See (2) (2) f = 1 kHz 8 See f = 10 kHz 8 See (2) See (2) Current Noise Density, f = 1 kHz 0.2 µVPP nV/√Hz pA/√Hz INPUT VOLTAGE RANGE VCM CMRR Common-Mode Voltage Range Common-Mode Rejection (V–)+2 VCM = (V–) +2 V to (V+) –2 V 130 TA = –40°C to 85°C 128 (V+)–2 140 See (2) 115 See See (2) V (2) dB 115 INPUT IMPEDANCE Differential 100 || 3 Common-Mode See (2) MΩ || pF GΩ || pF VCM = (V–) +2 V to (V+) –2 V 250 || 3 See (2) VO = (V–)+0.5 V to (V+)–1.2 V, RL = 10 kΩ 140 See (2) OPEN-LOOP GAIN AOL Open-Loop Voltage Gain dB VO = (V–)+1.5 V to (V+)–1.5 V, RL = 2 kΩ 126 VO = (V–)+1.5 V to (V+)–1.5 V, RL = 2 kΩ 134 126 See (2) See (2) See (2) dB TA = –40°C to 85°C FREQUENCY RESPONSE GBW Gain-Bandwidth Product SR Slew Rate See (2) MHz See (2) V/µs VS = ±15 V, G = 1, 10-V Step 14 See (2) 16 See (2) Overload Recovery Time VIN × G = VS 3 See (2) Total Harmonic Distortion + Noise 1 kHz, G = 1, VO = 3.5 Vrms See (2) 0.1% Settling Time THD+N 1 0.8 0.01% http://www.hgsemi.com.cn 0.002% 6 µs µs 2018 AUG HG277/HG2277/HG4277 Electrical Characteristics for HGx277P, HGx277U, and HGx277xA (continued) At TA = 25°C, and RL = 2 kΩ, unless otherwise noted PARAMETER HG277xA HG2277xA HG4277xA HG277P, U HG2277P, U TEST CONDITIONS MIN TYP (1) MAX MIN TYP UNIT (1) MAX OUTPUT VO Voltage Output ISC RL = 10 kΩ (V–)+0.5 (V+)–1.2 See (2) See (2) TA = –40°C to +85°C (V–)+0.5 (V+)–1.2 See (2) See (2) RL = 2 kΩ (V–)+1.5 (V+)–1.5 See (2) See (2) TA = –40°C to +85°C (V–)+1.5 (V+)–1.5 See (2) See (2) Short-Circuit Current ±35 CLOAD Capacitive Load Drive See ZO Open-loop output impedance f = 1 MHz V See (2) mA See (2) Ω (3) 40 POWER SUPPLY VS Specified Voltage Range ±5 Operating Voltage Range ±2 IO = 0 IQ ±15 Quiescent Current (per amplifier) ±18 ±790 TA = –40°C to 85°C See (2) See (2) ±825 See ±900 (2) See (2) V See (2) V See (2) See (2) µA TEMPERATURE RANGE (3) Specified Range –40 85 See (2) See (2) °C Operating Range –55 125 See (2) See (2) °C See Typical Characteristics 6.8 Electrical Characteristics for HGx277AIDRM At TA = 25°C, and RL = 2 kΩ, unless otherwise noted PARAMETER TEST CONDITIONS HG277AIDRM HG2277AIDRM MIN UNIT TYP (1) MAX ±35 ±100 OFFSET VOLTAGE V0S Input Offset Voltage µV HG277P, U (high-grade, single) Input Offset Voltage Over Temperature HG2277P, U (high-grade, dual) TA = –40°C to 85°C µV All PA, UA, Versions AIDRM Versions ±165 HG277P, U (high-grade, single) dV0S/dT Input Offset Voltage Drift HG2277P, U (high-grade, dual) TA = –40°C to 85°C All PA, UA, AIDRM Versions ±0.15 vs Time Input Offset Voltage: (all models) vs Power Supply (PSRR) Channel Separation (dual, quad) (1) (2) µV/°C VS = ±2 V to ±18 V See (2) See (2) TA = –40°C to 85°C DC ±1 µV/mo ±1 ±1 See (2) µV/V µV/V VS = ±15 V Specifications are the same as HG277P, U. http://www.hgsemi.com.cn 7 2018 AUG HG277/HG2277/HG4277 Electrical Characteristics for HGx277AIDRM (continued) At TA = 25°C, and RL = 2 kΩ, unless otherwise noted PARAMETER HG277AIDRM HG2277AIDRM TEST CONDITIONS MIN TYP (1) UNIT MAX INPUT BIAS CURRENT IB Input Bias Current TA = –40°C to 85°C IOS Input Offset Current TA = –40°C to 85°C ±2.8 ±4 ±2.8 ±4 nA nA NOISE See (2) f = 10 Hz See (2) f = 100 Hz See (2) f = 1 kHz See (2) f = 10 kHz See (2) See (2) Input Voltage Noise, f = 0.1 to 10 Hz en in Input Voltage Noise Density Current Noise Density, f = 1 kHz µVPP nV/√Hz pA/√Hz INPUT VOLTAGE RANGE VCM CMRR Common-Mode Voltage Range Common-Mode Rejection See (2) VCM = (V–) +2 V to (V+) –2 V 115 TA = –40°C to 85°C 115 See (2) V See (2) See (2) MΩ || pF VCM = (V–) +2 V to (V+) –2 V See (2) GΩ || pF VO = (V–)+0.5 V to (V+)–1.2 V, RL = 10 kΩ See (2) See (2) dB INPUT IMPEDANCE Differential Common-Mode OPEN-LOOP GAIN AOL Open-Loop Voltage Gain VO = (V–)+1.5 V to (V+)–1.5 V, RL = 2 kΩ VO = (V–)+1.5 V to (V+)–1.5 V, RL = 2 kΩ dB See (2) See (2) dB TA = –40°C to 85°C FREQUENCY RESPONSE GBW Gain-Bandwidth Product See (2) MHz SR Slew Rate See (2) V/µs VS = ±15 V, G = 1, 10-V Step See (2) See (2) Overload Recovery Time VIN × G = VS See (2) Total Harmonic Distortion + Noise 1 kHz, G = 1, VO = 3.5 Vrms See (2) 0.1% Settling Time THD+N 0.01% µs µs OUTPUT See (2) See (2) See (2) See (2) RL = 2 kΩ See (2) See (2) TA = –40°C to +85°C See (2) See (2) RL = 10 kΩ VO Voltage Output ISC Short-Circuit Current CLOAD Capacitive Load Drive ZO Open-loop output impedance http://www.hgsemi.com.cn TA = –40°C to +85°C f = 1 MHz 8 V See (2) mA See (2) Ω 2018 AUG HG277/HG2277/HG4277 Electrical Characteristics for HGx277AIDRM (continued) At TA = 25°C, and RL = 2 kΩ, unless otherwise noted PARAMETER HG277AIDRM HG2277AIDRM TEST CONDITIONS MIN TYP (1) UNIT MAX POWER SUPPLY VS Specified Voltage Range Operating Voltage Range IQ Quiescent Current (per amplifier) See (2) See (2) V See (2) See (2) V See (2) See (2) IO = 0 See TA = –40°C to 85°C (2) µA TEMPERATURE RANGE Specified Range Operating Range http://www.hgsemi.com.cn 9 See (2) See (2) See (2) °C See (2) °C 2018 AUG HG277/HG2277/HG4277 6.9 Typical Characteristics At TA = 25°C, VS = ±15 V, and RL = 2 kΩ, unless otherwise noted. 140 140 G 120 CL = 0 CL = 1500pF 0 –60 φ 60 –90 40 –120 20 –150 0 –180 PSR, CMR (dB) 80 +PSR –PSR –30 Phase (°) AOL (dB) 100 120 100 80 CMR 60 40 20 –20 0 0.1 1 10 100 1k 10k 100k 1M 10M 0.1 1 10 Frequency (Hz) 100 1k 10k 100k 1M Frequency (Hz) Figure 1. Open-Loop Gain and Phase vs Frequency Figure 2. Power Supply and Common-Mode Rejection vs Frequency INPUT NOISE AND CURRENT NOISE SPECTRAL DENSITY vs FREQUENCY Noise signal is bandwidth limited to lie between 0.1Hz and 10Hz. Current Noise 50nV/div Voltage Noise (nV/√Hz) Current Noise (fA/√Hz) 1000 100 Voltage Noise 10 1 1 0.1 10 100 1k 1s/div Frequency (Hz) Figure 3. Input Noise and Current Noise Spectral Density vs Frequency Figure 4. Input Noise Voltage vs Time 140 1 120 THD+Noise (%) Channel Separation (dB) VOUT = 3.5Vrms 100 Dual and quad devices. G = 1, all channels. Quad measured channel A to D or B to C —other combinations yield similar or improved rejection. 80 60 0.1 G = 10, RL = 2kΩ, 10kΩ 0.01 G = 1, RL = 2kΩ, 10kΩ 0.001 40 10 100 1k 10k 100k 10 1M 1k 10k 100k Frequency (Hz) Frequency (Hz) Figure 6. Total Harmonic Distortion + Noise vs Frequency Figure 5. Channel Separation vs Frequency http://www.hgsemi.com.cn 100 10 2018 AUG HG277/HG2277/HG4277 Typical Characteristics (continued) At TA = 25°C, VS = ±15 V, and RL = 2 kΩ, unless otherwise noted. 35 16 Typical distribution of packaged units. Single, dual, and quad included. 12 10 8 6 4 25 20 15 10 5 2 0 0 0 – 50– 45– 40– 35– 30– 25– 20– 15– 10– 5 0 5 10 15 20 25 30 35 40 45 50 Offset Voltage (µV) 0.1 0.2 0.3 0.5 0.6 0.7 0.8 0.9 1.0 Figure 8. Offset Voltage Drift Production Distribution 3 160 2 150 CMR AOL, CMR, PSR (dB) 1 0 –1 140 AOL 130 PSR 120 110 –2 100 –75 –3 15 30 45 60 75 90 105 120 –50 –25 0 25 50 75 100 125 Temperature ( °C) Time from Power Supply Turn-On (s) Figure 9. Warm-Up Offset Voltage Drift Figure 10. AOL, CMR, PSR vs Temperature 1000 100 4 950 90 3 900 80 Quiescent Current (µA) 5 2 1 0 –1 –2 Curves represent typical production units. –3 –4 –75 –50 –25 0 25 50 75 100 125 60 50 750 –ISC 700 40 +ISC 650 30 600 20 550 10 0 –50 –25 0 25 50 75 100 125 Temperature (°C) Temperature ( °C) Figure 12. Quiescent Current and Short-Circuit Current vs Temperature Figure 11. Input Bias Current vs Temperature http://www.hgsemi.com.cn ±I Q 800 500 –75 –5 70 850 Short-Circuit Current (mA) 0 Input Bias Current (nA) 0.4 Offset Voltage (µV/°C) Figure 7. Offset Voltage Production Distribution Offset Voltage Change (µV) Typical distribution of packaged units. Single, dual, and quad included. 30 Percent of Amplifiers (%) Percent of Amplifiers (%) 14 11 2018 AUG HG277/HG2277/HG4277 Typical Characteristics (continued) At TA = 25°C, VS = ±15 V, and RL = 2 kΩ, unless otherwise noted. 2.0 2.0 Curve shows normalized change in bias current with respect to VS = ±10V (+20V). Typical I B may range from –0.5nA to +0.5nA at V S = ±10V. 1.5 1.0 VS = ±5V 0.5 0.0 ∆IB (nA) ∆IB (nA) 1.0 Curve shows normalized change in bias current with respect to VCM = 0V. Typical I B may range from –05.nA to +0.5nA at V CM = 0V. 1.5 VCM = 0V 0.5 0.0 –0.5 –0.5 –1.0 –1.0 –1.5 –1.5 VS = ±15V –2.0 –2.0 0 5 10 15 20 25 30 35 40 –15 –10 Supply Voltage (V) Figure 13. Change in Input Bias Current vs Power Supply Voltage 5 10 15 100 10V step CL = 1500pF per amplifier Settling Time (µs) 900 800 700 50 0.01% 0.1% 20 600 10 500 0 ±5 ±10 ±15 ±20 ±1 ±10 Supply Voltage (V) ±100 Gain (V/V) Figure 15. Quiescent Current vs Supply Voltage Figure 16. Settling Time vs Closed-Loop Gain 30 (V+) (V+) – 1 Output Voltage Swing (V) VS = ±15V 25 Output Voltage (V PP) 0 Figure 14. Change in Input Bias Current vs Common-Mode Voltage 1000 Quiescent Current (µA) –5 Common-Mode Voltage (V) 20 15 10 VS = ±5V 5 –55°C (V+) – 2 (V+) – 3 125°C (V+) – 4 25°C (V+) – 5 (V–) + 5 25°C 125°C (V–) + 4 (V–) + 3 (V–) + 2 –55°C (V–) + 1 0 (V–) 1k 10k 100k 1M 0 Frequency (Hz) ±10 ±15 ±20 ±25 ±30 Output Current (mA) Figure 17. Maximum Output Voltage vs Frequency http://www.hgsemi.com.cn ±5 Figure 18. Output Voltage Swing vs Output Current 12 2018 AUG HG277/HG2277/HG4277 Typical Characteristics (continued) At TA = 25°C, VS = ±15 V, and RL = 2 kΩ, unless otherwise noted. 60 Gain = –1 50 Overshoot (%) 40 2V/div Gain = +1 30 20 Gain = ±10 10 0 10 100 1k 10k 100k 10µs/div Load Capacitance (pF) Figure 20. Large-Signal Step Response G = 1, CL = 1500 pF, VS = ±15 V 20mV/div 20mV/div Figure 19. Small-Signal Overshoot vs Load Capacitance 1µs/div 1µs/div Figure 21. Small-Signal Step Response G= +1, CL = 0, VS = ±15 V Figure 22. Small-Signal Step Response G= 1, CL = 1500 pF, VS = ±15 V 100 70 50 Impedance (:) 30 20 10 7 5 3 2 1 1k 10k 100k Frequency (Hz) 1M Figure 23. Open-Loop Output Impedance VS = ±15 V http://www.hgsemi.com.cn 13 2018 AUG HG277/HG2277/HG4277 7 Detailed Description 7.1 Overview The HGx277 series precision operational amplifiers replace the industry standard HG-177. They offer improved noise, wider output voltage swing, and are twice as fast with half the quiescent current. Features include ultralow offset voltage and drift, low bias current, high common-mode rejection, and high power supply rejection. Single, dual, and quad versions have identical specifications, for maximum design flexibility. 7.2 Functional Block Diagram Input Offset Adjust (HG277 only) +IN -IN + ± Input Offset Adjust (HG277 only) Output Compensation 7.3 Feature Description The HGx277 series is unity-gain stable and free from unexpected output phase reversal, making it easy to use in a wide range of applications. Applications with noisy or high-impedance power supplies may require decoupling capacitors close to the device pins. In most cases 0.1-μF capacitors are adequate. The HGx277 series has low offset voltage and drift. To achieve highest performance, the circuit layout and mechanical conditions should be optimized. Offset voltage and drift can be degraded by small thermoelectric potentials at the operational amplifier inputs. Connections of dissimilar metals generate thermal potential, which can degrade the ultimate performance of the HGx277 series. These thermal potentials can be made to cancel by assuring that they are equal in both input terminals. • Keep the thermal mass of the connections to the two input terminals similar • Locate heat sources as far as possible from the critical input circuitry • Shield operational amplifier and input circuitry from air currents, such as cooling fans 7.3.1 Operating Voltage HGx277 series operational amplifiers operate from ±2-V to ±18-V supplies with excellent performance. Unlike most operational amplifiers, which are specified at only one supply voltage, the HG277 series is specified for real-world applications; a single limit applies over the ±5-V to ±15-V supply range. This allows a customer operating at VS = ±10 V to have the same assured performance as a customer using ±15-V supplies. In addition, key parameters are assured over the specified temperature range, –40°C to 85°C. Most behavior remains unchanged through the full operating voltage range (±2 V to ±18 V). Parameters which vary significantly with operating voltage or temperature are shown in Typical Characteristics. 7.3.2 Offset Voltage Adjustment The HGx277 series is laser-trimmed for low offset voltage and drift, so most circuits do not require external adjustment. However, offset voltage trim connections are provided on pins 1 and 8. Offset voltage can be adjusted by connecting a potentiometer, as shown in Figure 24. Only use this adjustment to null the offset of the operational amplifier. This adjustment should not be used to compensate for offsets created elsewhere in a system, because this can introduce additional temperature drift. http://www.hgsemi.com.cn 14 2018 AUG HG277/HG2277/HG4277 Feature Description (continued) V+ Trim Range: Exceeds Offset Voltage Specification 0.1µF 20kΩ 7 1 2 8 3 0.1µF HG277 4 6 HG277 Hsingleopamponly. Use offset adjust pins only to null offset voltage of op amp—see text. V– Figure 24. HG277 Offset Voltage Trim Circuit 7.3.3 Input Protection The inputs of the HGx277 series are protected with 1-kΩ series input resistors and diode clamps. The inputs can withstand ±30-V differential inputs without damage. The protection diodes conduct current when the inputs are over-driven. This may disturb the slewing behavior of unity-gain follower applications, but will not damage the operational amplifier. 1 k + 1 k ± Figure 25. HGx277 Input Protection 7.3.4 Input Bias Current Cancellation The input stage base current of the HGx277 series is internally compensated with an equal and opposite cancellation circuit. The resulting input bias current is the difference between the input stage base current and the cancellation current. This residual input bias current can be positive or negative. When the bias current is canceled in this manner, the input bias current and input offset current are approximately the same magnitude. As a result, it is not necessary to use a bias current cancellation resistor, as is often done with other operational amplifiers (see Figure 26). A resistor added to cancel input bias current errors may actually increase offset voltage and noise. R2 R2 R1 R1 Op Amp HG277 RB = R2 || R1 No bias current cancellation resistor (see text) (a) (b) Conventional op amp with external bias current cancellation resistor. HG277HG with no external bias current cancellation resistor. Figure 26. Input Bias Current Cancellation http://www.hgsemi.com.cn 15 2018 AUG HG277/HG2277/HG4277 Feature Description (continued) 7.3.5 EMI Rejection Ratio (EMIRR) The electromagnetic interference (EMI) rejection ratio, or EMIRR, describes the EMI immunity of operational amplifiers. An adverse effect that is common to many operational amplifiers is a change in the offset voltage as a result of RF signal rectification. An operational amplifier that is more efficient at rejecting this change in offset as a result of EMI has a higher EMIRR and is quantified by a decibel value. Measuring EMIRR can be performed in many ways, but this report provides the EMIRR IN+, which specifically describes the EMIRR performance when the RF signal is applied to the noninverting input pin of the operational amplifier. In general, only the noninverting input is tested for EMIRR for the following three reasons: 1. Operational amplifier input pins are known to be the most sensitive to EMI, and typically rectify RF signals better than the supply or output pins. 2. The noninverting and inverting operational amplifier inputs have symmetrical physical layouts and exhibit nearly matching EMIRR performance. 3. EMIRR is easier to measure on noninverting pins than on other pins because the noninverting input terminal can be isolated on a printed circuit board (PCB). This isolation allows the RF signal to be applied directly to the noninverting input terminal with no complex interactions from other components or connecting PCB traces. A more formal discussion of the EMIRR IN+ definition and test method is provided in application report SBOA128, EMI Rejection Ratio of Operational Amplifiers, available for download at www.ti.com. The EMIRR IN+ of the OPA277 is plotted versus frequency as shown in Figure 27. 120 EMIRR IN+ (db) PRF = -10 dbm VS = r2.5 V 100 VCM = 0 V 80 60 40 20 0 10 100 1k Frequency (MHz) 10k Figure 27. HG277 EMIRR IN+ vs Frequency If available, any dual and quad operational amplifier device versions have nearly similar EMIRR IN+ performance. The HG277 unity-gain bandwidth is 1 MHz. EMIRR performance below this frequency denotes interfering signals that fall within the operational amplifier bandwidth. http://www.hgsemi.com.cn 16 2018 AUG HG277/HG2277/HG4277 Feature Description (continued) Table 1 shows the EMIRR IN+ values for the HG277 at particular frequencies commonly encountered in realworld applications. Applications listed in Table 1 may be centered on or operated near the particular frequency shown. This information may be of special interest to designers working with these types of applications, or working in other fields likely to encounter RF interference from broad sources, such as the industrial, scientific, and medical (ISM) radio band. Table 1. HG277 EMIRR IN+ for Frequencies of Interest FREQUENCY APPLICATION/ALLOCATION EMIRR IN+ 400 MHz Mobile radio, mobile satellite/space operation, weather, radar, UHF 59.1 dB 900 MHz GSM, radio com/nav./GPS (to 1.6 GHz), ISM, aeronautical mobile, UHF 77.9 dB 1.8 GHz GSM, mobile personal comm. broadband, satellite, L-band 91.3 dB 2.4 GHz 802.11b/g/n, Bluetooth™, mobile personal comm., ISM, amateur radio/satellite, S-band 93.3 dB 3.6 GHz Radiolocation, aero comm./nav., satellite, mobile, S-band 105.9 dB 5.0 GHz 802.11a/n, aero comm./nav., mobile comm., space/satellite operation, C-band 107.5 dB 7.3.5.1 EMIRR IN+ Test Configuration Figure 28 shows the circuit configuration for testing the EMIRR IN+. An RF source is connected to the operational amplifier noninverting input terminal using a transmission line. The operational amplifier is configured in a unity gain buffer topology with the output connected to a low-pass filter (LPF) and a digital multimeter (DMM). Note that a large impedance mismatch at the operational amplifier input causes a voltage reflection; however, this effect is characterized and accounted for when determining the EMIRR IN+. The resulting dc offset voltage is sampled and measured by the multimeter. The LPF isolates the multimeter from residual RF signals that may interfere with multimeter accuracy. Refer to SBOA128 for more details. Ambient temperature: 25Û& +VS ± 50  Low-Pass Filter + RF source DC Bias: 0 V Modulation: None (CW) Frequency Sweep: 201 pt. Log -VS Not shown: 0.1 µF and 10 µF supply decoupling Sample / Averaging Digital Multimeter Figure 28. EMIRR IN+ Test Configuration Schematic 7.4 Device Functional Modes The HGx277 has a single functional mode and is operational when the power-supply voltage is greater than 4 V (±2 V). The maximum power supply voltage for the HGx277 is 36 V (±18 V). http://www.hgsemi.com.cn 17 2018 AUG HG277/HG2277/HG4277 8 Application and Implementation NOTE Information in the following applications sections is not part of the TI component specification, and TI does not warrant its accuracy or completeness. TI’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. 8.1 Application Information The HGx277 family offers outstanding dc precision and ac performance. These devices operate up to 36-V supply rails and offer ultralow offset voltage and offset voltage drift, as well as 1-MHz bandwidth and high capacitive load drive. These features make the HGx277 a robust, high-performance operational amplifier for high-voltage industrial applications. 8.2 Typical Applications 8.2.1 Second-Order Lowpass Filter 2.25 k 2.25 k 1.13 k Input 1 nF ± Output 4 nF + Figure 29. Second-Order Lowpass Filter 8.2.1.1 Design Requirements • Gain = 1 V/V • • Lowpass cutoff frequency = 50 kHz –40 db/dec filter response • Maintain less than 3-dB gain peaking in the gain versus frequency response 8.2.1.2 Detailed Design Procedure WEBENCH® Filter Designer is a simple, powerful, and easy-to-use active filter design program. The WEBENCH Filter Designer lets you create optimized filter designs using a selection of TI operational amplifiers and passive components from TI's vendor partners. Available as a web based tool from the WEBENCH® Design Center, WEBENCH® Filter Designer allows you to design, optimize, and simulate complete multistage active filter solutions within minutes. http://www.hgsemi.com.cn 18 2018 AUG HG277/HG2277/HG4277 Typical Applications (continued) 8.2.1.3 Application Curve 20 Gain (db) 0 -20 -40 -60 100 1k 10k Frequency (Hz) 100k 1M Figure 30. HG277 Second-Order 50-kHz, Lowpass Filter 8.2.2 Load Cell Amplifier V+ 1/2 VOUT = (V1 – V2)(1 + HG2277 R2 R1 ) R2 V– R–∆R Load Cell V1 R+∆R V+ R+∆R V2 R1 1/2 R–∆R HG2277 V– R2 R1 For integrated solution see: INA126, INA2126 (dual) INA125 (on-board reference) INA122 (single-supply) Figure 31. Load Cell Amplifier http://www.hgsemi.com.cn 19 2018 AUG HG277/HG2277/HG4277 Typical Applications (continued) 8.2.3 Thermocouple Low-Offset, Low-Drift Loop Measurement With Diode Cold Junction Compensation IREG ∼ 1mA 5V 12 V+ VLIN 1/2 13 HG2277 Type J RF 10kΩ R 412Ω 4 + VIN 1 IR1 3 11 VREG 10 V+ RG RG 1250Ω RF 10kΩ 14 IR2 XTR105 B E RG 9 8 IO 1/2 1kΩ 2 HG2277 25Ω 7 IRET V– 50Ω – VIN 6 + – IO = 4mA + (V IN – VIN) 40 RG RCM = 1250Ω (G = 1 + 2RF = 50) R 0.01µF Figure 32. Thermocouple Low-Offset, Low-Drift Loop Measurement With Diode Cold Junction Compensation 10.3 DFN Package The HGx277 series uses the 8-lead DFN (also known as SON), a QFN package with contacts on only two sides of the package bottom. This leadless, near-chip-scale package maximizes board space and enhances thermal and electrical characteristics through an exposed pad. DFN packages are physically small, have a smaller routing area, improved thermal performance, and improved electrical parasitics, with a pinout scheme that is consistent with other commonly-used packages, such as SO and MSOP. Additionally, the absence of external leads eliminates bent-lead issues. The DFN package can be easily mounted using standard printed-circuit-board (PCB) assembly techniques. See QFN/SON PCB Attachment (SLUA271) and Quad Flatpack No-Lead Logic Packages (SCBA017), both available for download at www.ti.com. The exposed leadframe die pad on the bottom of the package should be connected to V–. 11.5 Electrostatic Discharge Caution These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam during storage or handling to prevent electrostatic damage to the MOS gates. http://www.hgsemi.com.cn 20 2018 AUG
HG2277M/TR 价格&库存
很抱歉,暂时无法提供与“HG2277M/TR”相匹配的价格&库存,您可以联系我们找货
