11W1250G
11W1250G
    SKYGATE(天宇匹克)
    贴片保险丝63VDC 1.25A 1206
11W1250G 数据手册
FEATURES FEATURES : : 6"Size] * 3216 mm * 3216 [1206"Size] mm [1206"Size] * Normal * Normal Blow Blow * RoHS-Compliant * RoHS-Compliant Products Products t Products APPROVALS APPROVALS : :: FEATURES FEATURES : er the Component Program of U.L. * Recognized * Recognized under under Component the Component ProgramProgram of U.L. of U.L. * 3216 mm [1206"Size] * 3216 mmthe [1206"Size] le No. E195987 * Normal Blow Guide JDYX2, Guide JDYX2, File Blow No.File E195987 No. E195987 * Normal * RoHS-Compliant Products * RoHS-Compliant Products APPROVALS : APPROVALS : * Recognized under the Component Program of U.L. Guide JDYX2, File No. E195987 IES * Recognized under the Component Program of U.L. Guide JDYX2, File No. E195987 11 W 11SERIES W SERIES 100% 4 hours Min. 4 hours Min. 100% 電気的特性 ELECTRICAL CHARACTERISTICS 電気的特性 : ELECTRICAL CHARACTERISTICS : DIMENSIONS : 60 sec Max. 60 sec Max. 60 sec Max. 200% 200% 4 hours Min. 100% 200% 60 sec Max. 200% 1000% 0.001 sec Min. / 0.01 sec Max. 1000% Unit : mm Unit : mm Typical Melting I2t Typical Melting TypicalI2tMelting I2t CURRENT IN AMPERES CURRENT IN AMPERES 2 2 2 Interrupting Rating*1 Rating*1 Interrupting Ampere Rating Ampere Ratingat 10 Voltage In Rating DCRating Voltage (A sec)* DC at 10 In (Aat sec)* 10 In2 (A2sec)*2 1 rupting Rating* Product Code Product Code SPECIFICATIONS : 1 A 63 V TBA 63 V 50 A 50 A TBA TBA A 1.25 A 630.261 V 63 V 50 A 50 A 0.261 0.261 1.5 A 1.5 A 63 V TBD 63 V 50 A 50 A 1.6 A 1.6 A 63 V TBD 63 V 50 A 50 A 50 A 11W 1000 11WG 1000 G 1 50 A 11W 1250 11WG 1250 G 1.25 50 A 11W 1500 11WG 1500 G 50 A 11W 1600 11WG 1600 G A Interrupting Rating* Ampere 2 A Rating 11W Code Voltage Rating 2000 11WGProduct 2000 DC G 2 A 1 50 A A 1.25 50 A A 11W 2500 11WG11W 63 V25001000G G 2.5 A 11W 3000 11WG11W 63 V30001250G G 3 A 1.5 50 A A 1.6 50 A A 11W 3150 11WG11W 63 V31501500G G 3.15 11W 3.5 11W 3500 11WG11W 63 V35001600G 4000 11WG11W 63 V40002000G G 2 50 A A 2.5 50 A A G 4 A 3.15 1.5 A50 AA A 3.5 1.6 A50 AA 4 2 A50 AA A A A 7 A 8 A 10 A 1 2.5 1 A50 AA 31.25 A50 AA 11W 5000 11WG11W 63 V50002500G G 5 A A 11W 6300 11WG11W 63 V63003000G G 6.3 A 6.3 A 11W 5 2.5 A50 AA 3 A50 AA G 7 A 73.15 A50 AA 8 3.5 A50 AA 10 4 A50 AA Typical Melting I2t Voltage Rating DC2 at 10 (A2sec)* 63 V0.80 63 VIn 50 A TBD Interrupting Rating* 50 A 1 TBD 0.80 TBD Typical Melting I2t TBD at 10 In (A2sec)*2 0.80 63 V1.25 63 V TBA 63 V 63 V1.80 63 V 63 0.261 V 50 A 50 A50 A 1.25 1.25 TBA 50 A 50 A50 A 1.80 63 V1.98 63 V63 V TBD 50 A 50 A50 A 1.98 1.800.261 1.98TBD 63 V3.89 63 V63 V TBD 63 V63 63 V4.32 0.80 V 50 A 50 A 50 A50 A 50 A50 A 4.32 63 V63 V 63 V5.00 1.25 63 V7.62 63 V63 V 1.80 63 V TBD 63 V63 V 1.98 6311.52 V 63 V63 V 3.89 50 A 6312.28 V 63 V63 V 4.32 3.89 50 A 50 A50 A 50 A 50 A 50 A 50 A 50 A50 A 11.52 50 A 50 A50 A 12.28 50 A 50 A 5.00 7.62 7.621.80 TBD1.98 A 11W G 8 A A 11W 10K 11WG11W 63 V10K4000G G 10 A 63 V 11W 5000 G 5 50 AA 63 V 5.00 50 A 5.00 63 V 11W 6300 G 6.3 50 AA 63 V 7.62 50 A 7.62 NOTE: 1. 1. DC Interrupting DC Interrupting Rating11W - Measured at voltage, designated timevoltage, constant time of constant than of 50less microseconds, than 50 microseconds, battery63TBD source. 63 V Rating V battery source. A less 7000 -atMeasured Gdesignated 7 50 A 2. . Typical Typical 2Melting I2t - Melting Measured I2t -with Measured a battery with pack a battery at ratedpack DC voltage at ratedatDC10voltage times rated at 10 current, times rated not current, to exceed notI.R. to exceed I.R. TBD 3.89TBD 4.320.80 5.001.25 7000 11WG11W 63 V70003150G 8000 11WG11W 63 V80003500G NOTE: 21 15 CURRENT IN AMPERES CURRENT IN AMPERES SPECIFICATIONS SPECIFICATIONS : : 5 TYPICAL 2.5A 3A 3.15A 3.5A 4A 5A 6.3A 8A 10A 1.25A CURRENT IN AMPERES 6.3 0.001 sec Min. / 0.01 sec Max. 2.5A 3A 3.15A 1.25A 3.5A 4A 5A 2A 6.3A 8A 2.5A 10A 3A 3.15A 3.5A 4A 5A 6.3A 8A 10A 2A 1.25A TIME IN SECONDS TIME IN SECONDS TIME IN SECONDS Unit : mm Unit : mm 50 A 50 3.15 A 50 3.5 A 50 4 A 60 sec Max. AVERAGE TIME CURRENT CURVES : TIME IN SECONDS LAND PATTERN : 3 4 hours Min. TYPICAL TYPICAL 2.5A 3A 3.15A 3.5A 4A 5A 6.3A 8A 10A 2A 1.25A AVERAGE TIME CURRENT CURVES : LAND LAND PATTERN PATTERN : : TYPICAL Ampere50 RatingA Opening Time 0.001 sec0.001 Min. /sec 0.01 Min. sec/ Max. 0.01 sec Max. AVERAGE AVERAGE TIME CURRENT TIME CURRENT CURVES CURVES : : 2.5A 3A 3.15A 3.5A 4A 5A 6.3A 8A 10A TYPICAL : 2A 100% ME CURRENT CURVES SURFACE MOUNT WIRE ELEMENT FUSE % of Ampere Rating % of Ampere Rating Opening Time 1000% 1000% 0.001 sec Min. / 0.01 sec Max. 15 Opening Time Opening Time SURFACE MOUNT WIRE ELEMENT FUSE SURFACE MOUNT WIRE ELEMENT FUSE 4 hours Min. SURFACE MOUNT WIRE ELEMENT FUSE 11 W SERIES % ofRating Ampere Rating Time% of Ampere SURFACE MOUNT WIRE ELEMENT FUSE Opening 11 W SERIES SURFACE MOUNT WIRE ELEMENT FUSE LECTRICAL CHARACTERISTICS 電気的特性 電気的特性 ELECTRICAL ELECTRICAL : CHARACTERISTICS CHARACTERISTICS : : DIMENSIONS DIMENSIONS : : 11.523.89 12.284.32 50 A TBD 63 V 11W 8000 G 8 50 AA 63 V 11.52 50 A 11.52 63 V 11W 10K G 10 50 AA 63 V 12.28 50 A 12.28 3. Operating 3. Current mbient temperature. Operating - AnCurrent operating - An current operating of 75% current or less of 75% of rated or less current of rated is recommended, current is recommended, with further with derating further required derating at elevated required ambient at elevated temperature. ambient temperature. NOTE: . 50for 1Ask designated voltage, time constant of less DC microseconds, Interrupting Rating battery -source. Measured at designated voltage, time constant of less than 50 microseconds, battery source. PICO PICO the sales itemsfor notthe mentioned items notinmentioned this Catalog. in this Catalog. . sales 4. Ask 4than 2 . sales battery pack at rated DC voltage 10 times rated Typical current, Melting not to for Iexceed t -the Measured I.R. with a battery pack at rated DC voltage at 10 times rated current, not to exceed I.R. Consult Consult for PICO the sales details. details. . 2 5. at 5PICO 3. Operating ent of 75% or less of rated current is recommended, with further Current derating - An operating requiredcurrent at elevated of 75% ambient or lesstemperature. of rated current is recommended, with further derating required at elevated ambient temperature. ioned in this Catalog. 4. Ask PICO sales for the items not mentioned in this Catalog. 5. Consult PICO sales for the details. 15 15 15
11W1250G
物料型号:11W系列,包括不同额定电流的产品代码,如1000、1250、1500、1600、2000、2500、3000、3150、3500、4000、5000、6300、7000、8000、10K。
器件简介:这些保险丝是表面安装线元件保险丝,符合RoHS标准,并且被U.L.组件计划认可。它们具有1206尺寸(3216毫米),并且是正常吹制的。
引脚分配:文档中没有明确说明引脚分配,但通常这类保险丝会有两端引脚用于电路连接。
参数特性: - 电气特性:包括在不同电流百分比下的断开时间,例如100%额定电流下最小4小时,200%额定电流下最大60秒,1000%额定电流下最小0.001秒/最大0.01秒。 - 尺寸:提供了保险丝的物理尺寸,例如长度和宽度。 - 典型熔断电流曲线:展示了在200%额定电流下,不同额定电流的保险丝的典型熔断时间。
功能详解:文档中没有详细描述保险丝的具体功能,但可以推断其主要功能是过流保护。
应用信息:推荐在额定电流的75%或更低的电流下操作,并在环境温度升高时需要进一步降额。
封装信息:提供了焊盘图案的尺寸,单位为毫米,这对于PCB设计和组装是重要的信息。
注意事项: - 直流中断额定值:在指定电压下测量,时间常数小于50微秒,电池源。 - 典型熔断I2t:在额定直流电压下,用电池组测量,电流不超过额定电流的10倍,不超过I.R.2。
11W1250G 价格&库存
很抱歉,暂时无法提供与“11W1250G”相匹配的价格&库存,您可以联系我们找货
11W1250G
