30HT0500
30HT0500
    SKYGATE(天宇匹克)
    FUSE-2P_10.1X2.93MM_SM
    一次性保险丝 250V 500mA
30HT0500 数据手册
-- -pending pending - pending - pending - pending pending - pending --pending pending - pending --pending pending 30HT 30HT 30HT SERIES SERIES SERIES 30HT 30HT SERIES SERIES 30HT 30HT 30HTSERIES SERIES SERIES 30HT 30HT 30HTSERIES SERIES SERIES * Silver plated Phosphor Bronze % of Ampere %Rating ofRating Rating %Rating Ampere of Ampere Rating Rating %% of%of Ampere ofAmpere Ampere % of %%Ampere ofofAmpere Ampere Rating Rating Rating % of %%Ampere ofofAmpere Ampere Rating Rating Rating 100% 100% 100% 100% 100% 100% 100% 100% 100% 100% 100% 100% 250% 250% 250% 250% 250% 250% 250% 250% 250% 250% 250% 250% Opening Opening Time Time Opening Opening Time Time Opening Opening Time Time Opening Opening Opening Time Time Time Opening Opening Opening Time Time Time 444hours hours Min. Min. 4 hours 4 hours Min.Min. 4 hours hours Min. Min. 4 hours 44hours hours Min. Min. Min. 4 hours 44hours hours Min. Min. Min. 111sec sec Min. Min. //sec 120 1120 Min. sec sec Min. /Max. Max. 120 / 120 secsec Max.Max. 1 sec sec Min. Min. /1120 /120 sec sec Max. Max. 1 sec 11sec sec Min. Min. Min. / 120 //120 120 secsec sec Max. Max. Max. 1 sec 11sec sec Min. Min. Min. / 120 //120 120 secsec sec Max. Max. Max. * TIME IN SECONDS TIME IN SECONDS TIME IN SECONDS SECONDS TIME IN TIME SECONDS IN TIME SECONDS IN TIME IN TIME SECONDS IN TIME SECONDS IN SECONDS TIME IN TIME SECONDS IN TIME SECONDS IN SECONDS TYPICAL TYPICAL TYPICAL TYPICAL TYPICAL TYPICAL TYPICAL TYPICAL TYPICAL TYPICAL TYPICAL TYPICAL CURRENT CURRENT IN IN AMPERES CURRENT CURRENT IN AMPERES IN AMPERES CURRENT CURRENT CURRENT IN AMPERES INAMPERES IN AMPERES AMPERES CURRENT CURRENT CURRENT IN AMPERES ININ AMPERES AMPERES CURRENT CURRENT CURRENT IN AMPERES ININ AMPERES AMPERES 1 1 1 111 1 Interrupting Interrupting Interrupting Rating* Rating* Interrupting Rating* Rating* Interrupting Interrupting Rating* Rating* [Ω] [Ω] [Ω][Ω] [Ω] [Ω] Typ. Typ. Typ. Typ. Typ. Typ. 1 11 Interrupting Interrupting Interrupting Rating* Rating* Rating* 2 2 2 222 2 [Ω] [Ω] [Ω] Typ. Typ. Typ. Ampere Ampere Rating Rating Ampere Ampere Rating Rating Product Product Code Code Product Product Code Code Ampere Ampere Rating Rating Product Product Code Code Voltage Voltage Rating Rating Voltage Voltage AC AC Rating AC AC Resistance Resistance Resistance Value* Value* Resistance Value* Value* Voltage Voltage Rating Rating AC ACRating Resistance Resistance Value* Value* 250 VAC VAC 250 VAC 250 VAC600 600 600 VAC 600 VAC 250250 250 VAC 250 VAC VAC 600 VAC 600 VAC VAC 1600 1 VAC 1VAC Interrupting Interrupting Interrupting Rating* Rating* Rating* 2 22 [Ω] [Ω] [Ω] Typ. Typ. Typ. Ampere Ampere Ampere Rating Rating Rating Product Product Product Code Code Code Voltage Voltage Voltage Rating Rating Rating ACAC AC 250 VAC 250 Resistance Resistance Resistance Value* Value* Value* VAC 250 VAC VAC 600 VAC 30HT 30HT 0500 0500 30HT30HT 05000500 500 mA 250 VAC VAC 250 VAC 50 50 A AAVAC 50 A 50 A 600 60 60 A AAVAC 60 A 60 A TBD TBD TBD 30HT 30HT 30HT 0500 0500 0500 500500 500 500 mAmA mA mA 500 500mA mA 250250 250 VAC 250 VAC VAC 50250 A 5050 A 60600 A 6060 A TBDTBD TBD TBD 2 22 Ampere Ampere Ampere Rating Rating Rating Product Product Product Code Code Code Voltage Voltage Voltage Rating Rating Rating ACAC AC 250 VAC 250 Resistance Resistance Resistance Value* Value* Value* VAC 250 VAC VAC 600 VAC 30HT 30HT 1250 1250 30HT30HT 12501250 1.25 1.25 AmA AA A 1.25 1.25 A A 250 VAC VAC 250 VAC 50 50 A AAVAC 50 A 50 A 600 60 60 A AAVAC 60 A 60 A 0.113 0.113 0.1130.113 30HT 1250 1250 1250 1.25 1.25 1.25 A mA 0.113 0.113 0.113 30HT 30HT 0500 0500 0500 500 500 500 mA 250250 250 VAC 250 VAC VAC 50250 A 5050 A 60600 A 6060 A TBD TBD TBD 0500 0500 0500 30HT 30HT 2000 2000 30HT30HT 20002000 30HT 30HT 1250 1250 1250 30HT 2000 2000 2000 500 500 500 222 mA AmA AA A 1.25 1.25 21.25 2 A mA 30HT 30HT 30HT 1250 1250 1250 2000 2000 2000 1.25 1.25 21.25 2 2 A AA 30HT 30HT 30HT 2000 2000 2000 2 2 2 A AA 2 2A A 250250 250 VAC 250 VAC VAC 250 VAC VAC 250 VAC 250 VAC 50 50 A50 5050 AAA A 50 A 50 A 60 60 A60 6060 AAA A 60 A 60 A TBD TBD 0.113 0.113 TBD0.113 TBD TBD 250250 VAC 250VAC VAC 50 A5050A A 60 A6060A A 0.113 0.113 TBD0.113 TBD TBD 250250 VAC 250VAC VAC 50 A5050A A 60 A6060A A TBDTBD TBD TBD TBD AC Interrupting Interrupting Rating Interrupting AC ---Measured Measured Rating at at - at Measured rated rated -voltage, Measured voltage, voltage, atUnit rated Unit Unit at rated voltage, Power Power voltage, Factor Factor Unit Unit Power (100%)Power (100%)Power Power Factor Factor (100%)Power Factor. Factor. (100%)Power Factor. Factor. . Rating Interrupting AC AC Interrupting Interrupting Rating Rating Rating -Interrupting Measured -Measured Measured atRating rated at rated rated voltage, voltage, Unit Power Unit Power Power Factor Factor Factor (100%)Power (100%)Power (100%)Power Factor. Factor. Factor. 1. 1AC 1. 111...AC 1. AC Interrupting AC AC Interrupting Interrupting Rating -Value Measured - --Measured Measured atValue rated atatrated rated voltage, voltage, Unit Unit Power Unit Power Power Factor Factor (100%)Power (100%)Power (100%)Power Factor. Factor. . Typical 1 1 . Resistance . Rating 2Resistance 2Rating 2. 221 2...AC 2 Typical Resistance Typical Typical Resistance Value Resistance ---measured Value -with with measured -voltage, less less measured than than with 10% 10% with less of of less than rated than 10% current. current. 10% of rated ofFactor. rated current. current. Typical Typical Typical Resistance Resistance Value Value Value measured -measured measured measured with with with less less less than than than 10% 10% 10% ofFactor rated of ofrated rated rated current. current. current. . 1 2 3. 2 3... 4 3 4... 5 . 4 5. AC AC Interrupting Interrupting Rating Rating Rating - Measured - --Measured Measured at rated atatrated rated voltage, voltage, voltage, Unitthan Unit Power Unit Power Power Factor (100%)Power (100%)Power (100%)Power Factor. Factor. Factor. . Interrupting 1.AC 1 Typical Typical Typical Resistance Value Value Value measured - -measured measured with with less less less than than 10% 10% 10% ofFactor rated ofFactor of rated rated current. current. current. . Resistance . - An . Operating 332 3Resistance 3Operating 3...2 3 Operating Current Current Operating ---An An operating Current operating Current - An current current -operating An of of 75% 75% current or or less less ofrated of of 75% of rated rated 75% or less current current or less ofis rated is is ofis recommended, recommended, rated current current is recommended, iswith with recommended, further further derating derating with with further required required further derating at at elevated elevated required required ambient ambient atambient elevated at elevated temperature. temperature. ambient ambient temperature. temperature. Operating Operating Operating Current Current Current -operating An An operating operating current current current of operating 75% ofwith of 75% 75% or less orcurrent or less of less of of rated rated current current current recommended, is recommended, recommended, with with with further further further derating derating derating required required required at derating elevated atat elevated elevated ambient ambient temperature. temperature. temperature. .. Typical 2 Typical Typical Resistance Resistance Resistance Value Value Value -operating measured - -measured measured with with less less less than than than 10% 10% 10% ofrated rated ofofcurrent rated rated current. current. 3.....2 3 Operating Operating Operating Current Current Current -for An -the -operating An An operating current current current 75% ofwith of 75% 75% or less or or less of less rated of of rated is current. recommended, is isrecommended, recommended, withwith with further further further derating derating derating required required required at elevated atatelevated elevated ambient ambient ambient temperature. temperature. temperature. . for . Ask 444 4.sales 4for 4 Ask PICO PICO sales Ask PICO Ask the PICO sales items items sales for not not the mentioned for mentioned items theofitems in in not this this mentioned Catalog. Catalog. in this incurrent Catalog. thiscurrent Catalog. Ask Ask PICO Ask PICO PICO sales sales sales the for for the items the items items not not mentioned not mentioned mentioned innot this inmentioned in this Catalog. this Catalog. Catalog. .. Operating 3 Operating Operating Current Current Current -the An -operating An Anitems operating operating current current current of 75% 75% orthis less oror less of less rated ofofrated rated current current current is recommended, isisrecommended, recommended, withwith with further further further derating derating derating required required required at elevated atatelevated elevated ambient ambient ambient temperature. temperature. temperature. 4.....3 4 Ask Ask PICO AskPICO PICO sales sales sales for for-for the items the items not not mentioned not mentioned mentioned inofof this in75% in Catalog. this Catalog. Catalog. . PICO .sales . Consult 555 5PICO 5for 5 Consult PICO Consult sales sales Consult for PICO the the PICO sales details. details. sales for the fordetails. the details. Consult Consult Consult PICO PICO sales sales for the for for the details. the details. details. .4 . Ask 4 Ask PICO Ask PICO PICO sales sales sales for the for for the items the items items not not mentioned not mentioned mentioned in this in in this Catalog. this Catalog. Catalog. 5.5. Consult Consult Consult PICOPICO PICO sales sales sales for the for forthe details. thedetails. details. . Consult 5. 5.5 Consult Consult PICOPICO PICO sales sales sales for the for forthe details. thedetails. details. 25 Si
30HT0500 价格&库存
很抱歉,暂时无法提供与“30HT0500”相匹配的价格&库存,您可以联系我们找货
