WSD4062DN56
N-Ch MOSFET
General Description
Product Summery
The WSD4062DN56 is the highest
performance trench N-Ch MOSFET with
extreme high cell density , which provide
excellent RDSON and gate charge for most of
the synchronous buck converter applications .
The WSD4062DN56 meet the RoHS and
Green Product requirement , 100% EAS
guaranteed with full function reliability
approved.
BVDSS
RDSON
ID
40V
7.0mΩ
62A
Applications
z High Frequency Point-of-Load Synchronous
Buck Converter
z Networking DC-DC Power System
Features
z Power Tool Application
z Advanced high cell density Trench technology
DFN5X6-8L Pin Configuration
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
VGS
Drain-Source Voltage
40
V
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V
62
A
ID@TC=100℃
29
A
60
A
42
mJ
IDM
EAS
a
Pulsed Drain Current
Single Pulse Avalanche
Energyb
IAS
Avalanche Current
13
A
PD@Ta=25℃
Total Power Dissipation
2.1
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
1
Thermal Resistance Junction-Case
1
Max.
Unit
60
℃/W
3.9
℃/W
Note a:Package is limited to 60A.
o
o
Note b:UIS tested and pulse width limited by maximum junction temperature 150 C (initial temperature Tj=25 C).
www.winsok.tw
Page 1
Dec.2014
WSD4062DN56
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
RDS(ON)
VGS(th)
△VGS(th)
2
Static Drain-Source On-Resistance
2
Gate Threshold Voltage
VGS(th) Temperature Coefficient
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
40
V
Reference to 25℃ , ID=1mA
0.043
V/℃
VGS=10V , ID=20A
7.0
10.5
mΩ
9.0
13.5
mΩ
1.5
1.8
2.5
V
mV/℃
VGS=4.5V , ID=15A
VGS=VDS , ID =250uA
-6.94
VDS=48V , VGS=0V , TJ=25℃
2
VDS=48V , VGS=0V , TJ=55℃
10
uA
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=20A
33
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.1
2
Ω
Qg
Total Gate Charge (10V)
76
91
Qgs
Gate-Source Charge
12
14.4
Qgd
Gate-Drain Charge
15.5
18.6
12
16
Td(on)
VDS=20V , VGS=10V , ID=40A
Turn-On Delay Time
nC
Rise Time
VDD=30V , VGEN=10V , RG=1Ω,
9
12
Turn-Off Delay Time
ID=1A ,RL=15Ω.
25
32
Fall Time
6
9
Ciss
Input Capacitance
1150
Coss
Output Capacitance
140
Crss
Reverse Transfer Capacitance
90
Min.
Typ.
Max.
Unit
A
60
A
1.3
V
Tr
Td(off)
Tf
VDS=20V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Conditions
1,6
Continuous Source Current
2,6
Pulsed Source Current
2
Diode Forward Voltage
VG=VD=0V , Force Current
VGS=0V , IS=20A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSD4062DN56”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.54800
- 10+1.45800
- 30+1.27800
- 100+1.14300
- 500+1.05300
- 1000+0.99000
