WSF3040
N-Ch MOSFET
General Description
Product Summery
The WSF3040 is the highest performance trench
N-ch MOSFETs with extreme high cell density ,
which provide excellent RDSON and gate charge
for most of the synchronous buck converter
applications .
BVDSS
RDSON
ID
30V
10mΩ
43A
Applications
The WSF3040 meet the RoHS and Green
Product requirement 100% EAS guaranteed with
full function reliability approved.
z High Frequency Point-of-Load Synchronous
Buck Converter for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
TO-252 Pin Configuration
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
VDS
VGS
ID@TC=25℃
ID@TC=100℃
ID@TA=25℃
ID@TA=70℃
IDM
EAS
Rating
Units
Drain-Source Voltage
30
V
Gate-Source Voltage
±20
V
1
43
A
1
30
A
1
11
A
1
9
A
112
A
53
mJ
Continuous Drain Current, VGS @ 10V
Pulsed Drain Current
2
3
Single Pulse Avalanche Energy
IAS
Avalanche Current
22
A
PD@TC=25℃
Total Power Dissipation4
37.5
W
PD@TA=25℃
2
W
TSTG
Storage Temperature Range
-55 to 175
TJ
Operating Junction Temperature Range
-55 to 175
4
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
Thermal Resistance Junction-Case1
www.winsok.tw
Page 1
1
Max.
Unit
62
℃/W
4
℃/W
Dec.2014
WSF3040
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
2
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.0193
V/℃
VGS=10V , ID=30A
10
12
VGS=4.5V , ID=15A
15
18
1.2
1.5
2.5
V
-3.97
mV/℃
VGS=VDS , ID =250uA
mΩ
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=30A
34
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.8
3.6
Ω
Qg
Total Gate Charge (4.5V)
9.8
13.7
Qgs
Gate-Source Charge
4.2
5.88
Qgd
Gate-Drain Charge
3.6
5.0
Turn-On Delay Time
5
8.0
Td(on)
VDS=15V , VGS=4.5V , ID=15A
uA
nC
Rise Time
VDD=15V , VGS=10V , RG=3.3Ω
8
14
Turn-Off Delay Time
ID=15A
31
62
Fall Time
4
8
Ciss
Input Capacitance
940
Coss
Output Capacitance
131
Crss
Reverse Transfer Capacitance
109
Min.
Typ.
Max.
Unit
24.6
mJ
Min.
Typ.
Max.
Unit
Tr
Td(off)
Tf
VDS=15V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=25V , L=0.1mH , IAS=15A
Diode Characteristics
Symbol
Parameter
Conditions
1,6
IS
Continuous Source Current
ISM
Pulsed Source Current2,6
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=30A , dI/dt=100A/µs , TJ=25℃
15
A
112
A
1
V
8.5
nS
2.2
nC
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSF3040”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.98410
- 50+0.91380
- 500+0.84350
- 1000+0.77320
- 2500+0.70290
- 国内价格
- 5+1.31242
- 50+1.04026
- 150+0.92362
- 500+0.77804
- 2500+0.65384
- 5000+0.61496
- 国内价格
- 5+1.15444
- 50+0.91504
- 500+0.68438
- 1000+0.67411
- 2500+0.57513
