WSP10N10
N-Ch MOSFET
General Description
Product Summery
The WSP10N10 is the highest performance
trench N-Ch MOSFET with extreme high cell
density , which provide excellent RDSON
and gate charge for most of the
synchronous buck converter applications .
BVDSS
RDSON
ID
100V
22mΩ
10A
Applications
The WSF08N10 meet the RoHS and Green
Product requirement , 100% EAS
guaranteed with full function reliability
approved.
z Power Management in DC/DC Converter.
SOP-8 Pin Configuration
Features
z Advanced high cell density Trench technology
z Super Low Gate Charge
z Excellent Cdv/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
100
V
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=70℃
IDM
±20
V
1
10
A
1
8.2
A
Continuous Drain Current, VGS @ 10V
Pulsed Drain Current
2
3
60
A
mJ
EAS
Single Pulse Avalanche Energy
42
IAS
Avalanche Current
30
A
4
PD@TA=25℃
Total Power Dissipation
3.1
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-ambient
RθJC
1
www.winsok.tw
Thermal Resistance Junction-Case
Page 1
1
Max.
Unit
40
℃/W
24
℃/W
Dec.2014
WSP10N10
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
100
V
Reference to 25℃ , ID=1mA
0.098
V/℃
VGS=10V , ID=10A
22
28
25
31
1.5
2.0
2.5
V
-5.52
mV/℃
VDS=80V , VGS=0V , TJ=25℃
10
VDS=80V , VGS=0V , TJ=55℃
100
VGS=0V , ID=250uA
VGS=4.5V , ID=6.5A
VGS=VDS , ID =250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
0.65
1.0
Ω
Qg
Total Gate Charge (10V)
28
Qgs
Gate-Source Charge
9
Qgd
Gate-Drain Charge
10
Turn-On Delay Time
12
4
17
Fall Time
5
Ciss
Input Capacitance
1769
Coss
Output Capacitance
164
Crss
Reverse Transfer Capacitance
53
Min.
Typ.
Max.
Unit
mJ
Min.
Typ.
Max.
Unit
5
A
30
A
1.1
V
27
nS
28
nC
Td(on)
Tr
Td(off)
Tf
VDS=80V , VGS=10V , ID=10A
Rise Time
VDD=30V , VGEN=10V , RG=6Ω
Turn-Off Delay Time
ID=1A ,RL=30Ω
VDS=30V , VGS=0V , f=1MHz
uA
nC
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=25V , L=0.3mH , IAS=10A
30
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Conditions
1,6
Continuous Source Current
2,6
Pulsed Source Current
2
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=6A , TJ=25℃
IF=10A , dI/dt=100A/µs , T=
J 25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSP10N10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.63000
- 10+1.53500
- 30+1.34500
- 100+1.20250
- 500+1.10750
- 1000+1.04100
