WSP4409
P-Ch MOSFET
General Description
Product Summery
The WSP4409 is the highest performance
trench P-Ch MOSFET with extreme high
cell density , which provide excellent
RDSON and gate charge for most of the
synchronous buck converter applications .
BVDSS
RDSON
ID
-30V
5.0mΩ
-17.6A
Applications
The WSP4409 meet the RoHS and Green
Product requirement , 100% EAS
guaranteed with full function reliability
approved.
z Power Management in Notebook Computer,
Portable Equipment and Battery Powered Systems.
Features
SOP-8 Pin Configuration
z Advanced high cell density Trench technology
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-30
V
VGS
Gate-Source Voltage
±20
V
-17.6
A
-14
A
-70
A
Single Pulse Avalanche Energy
72
mJ
A
ID@Tc=25℃
ID@Tc=70℃
IDM
EAS
1
Continuous Drain Current, VGS @ -10V
1
2
300uS Pulsed Drain Current
3
IAS
Avalanche Current
-38
PD@TA=25℃
Total Power Dissipation4
4.2
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
1
www.winsok.tw
Thermal Resistance Junction-Case
Page 1
1
Max.
Unit
75
℃/W
24
℃/W
Dec.2014
WSP4409
P-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
Reference to 25℃ , ID=-1mA
-0.018
V/℃
5
7.2
9
12
-1.3
-1.8
-2.3
V
5.04
mV/℃
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=-10V , ID=-17.6A
VGS=-4.5V , ID=-10A
VGS=VDS , ID =-250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-10A
18
S
Qg
Total Gate Charge (-4.5V)
45
Qgs
Gate-Source Charge
Qgd
VDS=-15V,VGS=-4.5V,ID=-17.6A
Gate-Drain Charge
5
12.7
uA
nC
12
Rise Time
VDD=-15V,VGS=-10V,RG=6Ω,
14
Turn-Off Delay Time
ID=-1A ,RL=15Ω
98
Fall Time
60
Ciss
Input Capacitance
2110
Coss
Output Capacitance
450
Crss
Reverse Transfer Capacitance
330
Min.
Typ.
Max.
Unit
60
mJ
Min.
Typ.
Max.
Unit
-4.0
A
-70
A
-1.1
V
24
nS
16
nC
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=-25V , L=0.5mH , IAS=-38A
Diode Characteristics
Symbol
IS
ISM
Parameter
Conditions
1,6
Continuous Source Current
2,6
Pulsed Source Current
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
IF=-17.6A,dI/dt=100A/µs,TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper, t
很抱歉,暂时无法提供与“WSP4409”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.81350
- 10+1.69650
- 50+1.52100
- 150+1.40400
- 300+1.32210
- 500+1.28700
