WSP4435
P-Ch MOSFET
General Description
Product Summery
The WSP4435 is the highest performance
trench P-Ch MOSFET with extreme high cell
density , which provide excellent RDSON
and gate charge for most of the synchronous
buck converter applications .
BVDSS
RDSON
ID
-30V
16mΩ
-8.2A
Applications
The WSP4435 meet the RoHS and Green
Product requirement , 100% EAS guaranteed
with full function reliability approved.
z High Frequency Point-of-Load Synchronous
Buck Converter for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
SOP-8 Pin Configuration
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
VDS
VGS
ID@TC=25℃
ID@TC=70℃
IDM
Rating
Units
Drain-Source Voltage
-30
V
Gate-Source Voltage
±20
V
1
-8.2
A
1
-6.5
A
-32
A
Continuous Drain Current, VGS @ -10V
Pulsed Drain Current
2
3
EAS
Single Pulse Avalanche Energy
64
mJ
IAS
Avalanche Current
-16
A
4
PD@TA=25℃
Total Power Dissipation
2.0
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
1
www.winsok.tw
Thermal Resistance Junction-Case
Page 1
1
Max.
Unit
90
℃/W
50
℃/W
Dec.2014
WSP4435
P-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
Reference to 25℃ , ID=-1mA
-0.022
V/℃
VGS=-10V , ID=-8.2A
16
VGS=-4.5V , ID=-4A
25
33
-1.5
-2.0
-2.5
V
4.6
mV/℃
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=VDS , ID =-250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-6A
11
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
3
Ω
Qg
Total Gate Charge (-4.5V)
21
Qgs
Gate-Source Charge
2.6
Qgd
Gate-Drain Charge
6.2
VDS=-15V , VGS=-4.5V , ID=-8.2A
uA
nC
8
Rise Time
VDD=-15V , VGS=-10V , RG=6Ω,
12
Turn-Off Delay Time
ID=-6A ,RL=15Ω,
32
Fall Time
16
Ciss
Input Capacitance
1000
Coss
Output Capacitance
210
Crss
Reverse Transfer Capacitance
150
Min.
Typ.
Max.
Unit
49
mJ
Min.
Typ.
Max.
Unit
-2.0
A
-32
A
-1.2
V
16.3
nS
5.9
nC
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=-25V , L=0.5mH , IAS=-16A
Diode Characteristics
Symbol
IS
ISM
Parameter
Conditions
1,6
Continuous Source Current
2,6
Pulsed Source Current
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
IF=-8A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSP4435”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.88350
- 50+0.81510
- 200+0.75810
- 600+0.70110
- 1500+0.65550
- 3000+0.62700
