WSP4606
N-Ch and P-Channel MOSFET
General Description
Product Summery
The WSP4606 is the highest performance trench
N-ch and P-ch MOSFETs with extreme high cell
density , which provide excellent RDSON and
gate charge for most of the synchronous buck
converter applications .
The WSP4606 meet the RoHS and Green
Product requirement , 100% EAS guaranteed
with full function reliability approved.
BVDSS
RDSON
ID
30V
18mΩ
7A
-30V
30mΩ
-6A
Applications
z Power management in half bridge and inverters
z DC-DC Converter
Features
z Load Switch
z Advanced high cell density Trench technology
SOP-8 Pin Configuration
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
Absolute Maximum Ratings
Rating
Symbol
Parameter
VDS
Drain-Source Voltage
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=100℃
IDM
N-Channel P-Channel
30
-30
V
±20
±20
V
1
7.0
-6
A
1
6
-4
A
A
Continuous Drain Current, VGS @ 10V
Pulsed Drain Current
Units
2
3
EAS
Single Pulse Avalanche Energy
72
59
mJ
IAS
Avalanche Current
21
-19
A
4
PD@TC=25℃
Total Power Dissipation
2.5
2.08
W
TSTG
Storage Temperature Range
-55 to 150
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
-55 to 150
Max.
Unit
85
℃/W
50
℃/W
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
Thermal Resistance Junction-Case1
www.winsok.tw
Page 1
1
Dec.2014
WSP4606
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.034
V/℃
18
28
25
32
1.0
1.5
2.5
V
-5.8
mV/℃
VDS=30V , VGS=0V , TJ=25℃
1
VDS=30V , VGS=0V , TJ=55℃
5
VGS=10V , ID=6A
VGS=4.5V , ID=5A
VGS=VDS , ID =250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=15V , ID=5A
10
S
Rg
Gate Resistance
VDS=24V , VGS=0V , f=1MHz
2.5
Ω
Qg
Total Gate Charge (4.5V)
7.2
Qgs
Gate-Source Charge
1.4
Qgd
Gate-Drain Charge
2.2
Td(on)
VDS=20V , VGS=4.5V , ID=6A
nC
4.1
Rise Time
VDD=12V , VGS=10V , RG=3.3Ω
9.8
Turn-Off Delay Time
ID=5A
15.5
Fall Time
6.0
Ciss
Input Capacitance
550
Coss
Output Capacitance
68
Crss
Reverse Transfer Capacitance
55
Min.
Typ.
Max.
Unit
16
mJ
Min.
Typ.
Max.
Unit
Tr
Td(off)
Tf
Turn-On Delay Time
uA
VDS=25V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=25V , L=0.1mH , IAS=10A
Diode Characteristics
Symbol
Parameter
Conditions
1,6
IS
Continuous Source Current
ISM
Pulsed Source Current2,6
VSD
2
Diode Forward Voltage
VG=VD=0V , Force Current
VGS=0V , IS=5A , TJ=25℃
7
A
A
1.2
V
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSP4606”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.07445
- 50+0.85899
- 600+0.65141
- 1200+0.64164
- 3000+0.53789
